Battery replacement Hi Howard, Thank you for your help. I am used to change the batteries of my computers. However on this motherboard Aopen VKM400Am-S, I cannot find any battery. The only metallic disc about the size of a battery is a part of a square chip. The following reference is written on this round element : VIA vt8237 0416CD CHINA 2IA29F2600 Obviously it is not a battery. Is it possible certain motherboards do not have any battery ? Hoping your answer, Regards Alain
  • alain251 Dec 01, 2008
    Great ! Then can you please give me the link where you found the manual with the photo, so that we can talk about the same image.
    Thank you.
  • alain251 Dec 02, 2008
    The link did not work, even when copying and pasting in my browser. I can even not have access to the index directory of this website.
    Now I found where the battery was. It was vertically positionned at the edge of the motherboard, hiden under the hard disk.
  • 341 Answers
Ftp://ftp.aopen.ru/pub/eig/mb/vkm400ams/vkm400ams-eg-e.pdf
I found the motherboard manual on the net.This photo clearly shows the battery
Posted on Nov 30, 2008
  • Howard Lester Dec 01, 2008
    Did the link work for you? It didn't for me. I had to copy and paste it into into my browser from here. Just FYI
BIOS battery type
open cpu motherboard looks bios battery then change
Jul 29, 2012 | AOpen i865G (AX4SG MAX II) Motherboard
Where is the battery that powers the Internet time/ date?
The motherboard BIOS battery keeps the motherboard setting and the date and time correct just like a watch battery. This BIOS battery is usually a 3 volt lithium battery, it is a coin size battery approx. 20mm in diameter most likely a CR2030 battery.
If you have a Internet time program that connects to the Internet, it will synchronize the computer's time with the Internet time.
Feb 13, 2011 | Acer AOpen AK77 Pro(A) (91.89A10.104)...
Date &time change every time I turn on my pc.why? how to fix the problem?
Hi elfridapanot,
The CMOS battery in the motherboard is be weak. Thats why the time resets every time you start you computer. Open up the computer case, and look for a battery on the motherboard. Take it out carefully and replace it with a new battery. Then start your computer and set the date. Next time when you restart, the date will not be reset.
If this information was helpful, please rate it.
Thank you for using Fixya,
Arun Zac
Dec 07, 2010 | Computers & Internet
System Time and Date Change
It is because of CMOS battery is weak
Change it and it will be fine
May 20, 2010 | AOpen vKM400Am-S Motherboard
I have already changed the the power supply, but the computer don´t start no beep, only the the red led on the mother board light
The motherboards green LED light sends 5volt to the bios battery to keep it charged. It is normally called, standby LED.
Pull you're bios battery and check its current voltage. Use a volt meater. It should read 3 volt DC. See page 30 in you're manual. If you don't have you're manual you can download it from the link provided;
ftp://ftp.aopen.com/pub/manual/mb/ax4speun/ax4sgul-ol-e.pdf
You'll need Adobe reader installed to view the manual link. You're bios battery may need to be replaced. On the other hand the relay as shown on page 30 may be defective. If this is so, you will not be able recharge the bios battery. There is no fix for this other than replacing the motherboard.
Mike
Jan 22, 2010 | AOpen AX4SPE-UN Motherboard
How to change cmos battery on aopen xc cube ux45g 1394
Although this question is really old I would like to answer it as I had the same problem a few days ago. This first answer from ikkenom is not really good, it is to general.
If your Aopen XCube UX45G forgets BIOS settings like time, boot order or other options it is very likely that the battery needs to be replaced. To replace the CMOS battery of the XCube UX45G you need a new CR2032 battery. The battery socket is a bit hidden. It can be found next to the IDE ports. See this image: http://www.informationsarchiv.net/uploads/image/8182/xccubeez65-25.JPG . First turn of the power chord, remove the battery as ikkenom described and insert the new battery. The positive pole (+) has to be positioned in the way that this pole can "see" the RAM slots. Turn back power chord, start the computer und reset BIOS settings.
Sep 14, 2009 | AOpen Computers & Internet
Change the battery
It's the round shiny chrome disc on the motherboard. Remember if you change it you will need to reset the cmos in the bios.You can contact me and I will walk you through that part.
Nov 27, 2008 | AOpen vKM400Am-S Motherboard
Remove bios password of ecs A535 notebook
if it is a desktop pc then you can remove the bios password just by removing the cmos battery & putting that back after 10 mins ...
or better if you change it ....
bios password & user defined settings of bios will be stored thus by removing the battery it can resetted ....
if it is the laptop then you must take a backup in the cd with other computer by downloading the iflash bios update utility from the motherboard manufacture site according to your model ..
any doubts reply me
i am always here to assist you
thank you
bye
dnt forget to rate my solution
Jul 02, 2008 | AOpen AX4SG Max Motherboard
Aopen motherboard: MS-6378 VER:3 Faulty
just u clear the cmos and load the defaults settings in bios then  restart the computer.,if not check the cmos voltage +3v,if voltage not appear pl change the battery it self
Was it helpful to u pl give the rating for me
Thank u
Oct 23, 2007 | AOpen AX34-U Motherboard
Computers & Internet Logo
427 people viewed this question
Alun Cox
David Payne
David Payne
