Question about Yamaha HTR-6130 Receiver
HTR-6130 When setting up the stereo system to play in the enhanced 5 channel mode using the basic set-up. I can not get 5 channel stereo to stay engaged. After the 2 tone checks on few speaks, is say yes that we are in the 5 channel mode but once i press the 7 enter bottom on the remote, it goes back to the 2 channel mode and only plays the right front and left front speakers. The instructions does not address this condition.
    Problem Solver:
  • 20 Answers
I think the problem you are having is that you are not getting a true 5.1 channel source. You have to be using a digital cable from the source to get the 5.1 speakers to show on the receiver. I had the same issue for a day then figured it out.
For example to get 5.1 speakers from my PS3 blu ray I had to connect the hdmi to the receiver then to tv and then also an opitcal cable to the receiver from the PS3 to get the 5.1 channels.
Posted on Jan 11, 2009
    Scholar:
  • 107 Answers
Read your instructions book again, when you press 7 that mean you are enter in select speakers you must use 7 then narrow UP DOWN and LEFT RIGHT when you finish you must save by press SET
The easy way to set it up is connect your receiver to TV then you can see the complete MENU on your TV screen
Or you initializer the unit to go back to the default mode, which will set to 5 speakers if you wish to do this look on same model I was post earlier how to initializer the receiver
Posted on Dec 03, 2008
How to connect a turntable connected to a yamaha a450 stereo amplifier...can I attache the a450 to the htr-6130 ?
If the turntable is newer kind you can connect it in any Stereo input like CD, VCR , etc.
If the turntable is older model you can only connect it to PHONO input (if amp has one) and make sure earthing cable is connected on Amp
Remember input is only stereo (unless your model has digital input) and select sound effect eg Pro Logic for enhanced sound,
Aug 26, 2014 | Yamaha HTR-6130 Receiver
Yamaha HTR-6030. Using two optical cables for cable tv and xbox/wdtv-live box. On some cable channels and also on my xbox, no sound will play if I use it "straight". If I use "simulated...
Please don't panic and think that there is anything wrong with your Yamaha receiver. A lot of people are having this problem with set top box reception. Time lag / phase differences caused by satellite transmission can make your Receivers digital decoders go nuts !!!.The working principal is too complex to explain on this page. I have had clients call up and say on some channels only one speaker works in a 5.1 setup !!!!.You noticed DD and DTS signals are working fine.
Mar 12, 2011 | Yamaha HTR-6030 Receiver
Is there any way i can use all channels regardless of source? i would like to understand what i need have as an input source inorder to use all 5.1 or at least 4 speakers
The answer is yes - and no. By definition, audio sources are encoded or recorded in a specific manner. If I record a stereo signal, there really are no rear channels or center or bass specific channels. To be most faithful to the original, you play back stereo in stereo and 5:1 in 5:1 and so on. There ARE several units designed to "synthesize" additional channels from sources that do not contain all the info specifically. Some multi-channel receivers/amps incorporate such circuits and you can "derive" rear channels from stereo inputs and so forth. If not, you may need an additional box (device) to turn 2 into 4 or 5, 3 from 2 and so on. Your choice but that's how it works.
Oct 22, 2010 | Yamaha HTR-6130 Receiver
I have a Yamaha HTR-6130 connected to a Samsung 550 plasma tv. I find the speaking sound in movies and tv programing to be too low relative to other background sounds. Any way to raise the relative...
If your running the receiver in 5.1 using a center channel, go into the main menu of the receiver and select "speaker settings" toggle to "center channel" and adjust the gain to taste. If you need more help, post a comment and I can help you some more
Jun 25, 2009 | Yamaha HTR-6130 Receiver
I'm trying to hook up my Acer Aspire x1700 to a Yamaha HTR - 6130 AV Receiver using the Optical digital audio cable plug. Not getting any sound, not sure what source to set on the receiver.. talks about...
You can set the receiver to any source that uses a optical connection. Then make sure that whatever you select whether it be CD/DVD you also have the source connection set to optical too on the receiver setup menu.
That being said, after that is done you will need to set up the computer to output audio. That usually just involves changing the output mode on the computer and adjusting the levels...open the Acer audio managment application, choose the audio output mode to stereo or dolby digital and turn everything up on the computers level controls. Then, when you open whatever software you're going to use to play your discs you may also have to adjust the volume level there as well.
Apr 30, 2009 | Yamaha HTR-6130 Receiver
WE PURCHASED A YAHAMAHA HTR-6130 TODAY
You may need to set up the receiver for your speaker configuration. There should be a setup menu on the receiver, and that will allow you to tell the amp what speakers you are using, and what inputs you are connecting what devices to. You may also need to set your DVD player, cable box and TV for the audio stream you want to use. PCM or Bitstream to be more precise. Also make sure that the sound output is set to Dolby Pro Logic or Dolby Digital and the input signal is in stereo or surround.
Best Wishes.
Dec 29, 2008 | Yamaha HTR-6130 Receiver
Yamaha HTR-6130 Front right and left speakers with no sound
As simple as this sounds, try hitting the speaker a/b button on the front of the unit, next to the headphone jack. I had the same problem, and was about to package the whole thing back up and go back to Best Buy when I hit this button and then the audio test worked.
Nov 23, 2008 | Yamaha HTR-6130 Receiver
Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Is Yamaha HTR-640 a receiver? Try HDMI from PS3 to receiver or Sony HDTV. If HDMI from PS3 to receiver the you need and HDMI from receiver to out Sony HDTV. You could connect everything to receiver and HDMI out to HDTV. You can not have an HDMI cable AND an optical cable coming out of the PS3, only one or the other.
Dec 30, 2007 | Yamaha HTR-6130 Receiver
Yamaha HTR-6130 Receiver Logo
161 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
