Question about Konica Minolta magicolor 5430 DL Laser Printer
Can't print from Vista to networked printer
I'm trying to set up this printer to print from a Vista notebook. The printer is connected on the local network (192.168.1.50) where it's been for a while, printing from XP machines. I downloaded the Vista 32-bit drivers from the K-M website (though they're labelled Win2k-xp) and followed the instructions to the letter. It didn't install to print to FILE, it did install to print to the correct port.
Konica Minolta Printer Status Monitor Center says Printer is Ready. But when I print anything, either test page or other, the print queue says "Printing - Printer Busy or Error". While I was typing this (and with that message in my print queue) I got someone else to print to it from an XP machine that's been using it for months, and it worked fine.
I can ping 192.168.1.50 from this Vista machine.
Thanks for any help you can offer!
=aw
  • andrew6800 Nov 28, 2008
    Okay I fixed it. It's embarrassingly simple but I had installed using the PostScript instructions instead of the GDI (Windows printer?) instructions. :(
    It still installed printing to port not FILE (the latter is wrong but how they claim Vista will do it). Test page printed fine.
    =aw
    Thanks for your suggestions. Actually it's printing though I haven't tried any advanced features. Details in my comment posted last night to my orginal problem.
    =aw
  • 28 Answers
The software that u are using is not copatible with the prenter. try to set up a pier to pier conection by using other ip address. use MSHOME in your work group then try to put 10.0.0.01 then put 10.0.0.2 as DNS ang default gateway. then do it to the vista notebook just change the ip address by using 10.0.0.3. let me knoew if its ok
Posted on Nov 28, 2008
How to set up wireless printing with disc
Here are the minimum details needed to answer this kind of question:
1. Operating System :
Windows XP, Windows 7, Windows 8, Windows Vista?
2. Printer make/model:
(this is important to determine the wireless properties of printer)
3. Network Connection:
(is the laptop connected to the same network as the printer)
If you are working with a new printer (see item 2) and you have a network on which you have your notebook connected, there are so many possible ways to connect the printer to the network that it's hard to say.
If you are working with an established printer that has wireless services running, you may need to know either the Network Name of the printer or the IP Address of the printer.
Your best bet is to make use of hp's extensive Wireless Printing Center (see link below).
Wireless printing center
Feb 26, 2014 | HP Pavilion dv6000z Notebook
Tip
How resolve cannot "Connect to Network Printer" with Windows Vista
One of the more interesting errors in Windows Vista happens when you try to connect to a shared network printer. Most of the time you'll receive an "Access is Denied" error when trying to connect even though you can see the printer on the network and everything else is working properly.
Everything else on the network appears to work properly, shared files, internet access, etc. However, you just cannot access the ahared printer and print.
The solution is to add the printer as a local printer and then try printing. Follow the directions below to accomplish this.
1. Go into Control Panel 2. Underneath the Hardware and Sound category, click on Printer 3. Click on Add a printer from the top menu 4. Click on Add a Local Printer 5. Choose Create a New Port with type of port remaining Local Port, then click Next 6. In the Port Name box type the path to the printer you wish to connect to and Click Ok
Ex. \\mycomputer\myprinter
If the computer you wish to connect to is named Bob and the printer is called HP then the path would be \\Bob\HP
7. In the Install Printer Driver screen, select your printer from the list or choose Have Disk and find the location of the printer drivers on the computer then click Next and then click Finish. 8. You should now see the printer installed in the Printers window. 9. Right-click on the printer and click Properties 10. On the General tab, click Print Test Page to test the printer.
You should now be able to printer from Windows Vista to this networked printer without any problems.
on Jul 20, 2010 | Computers & Internet
Vista driver
The print driver solution for this product is included with the Microsoft Windows Vista operating system and is already on the computer. No special driver download is necessary for this product.
Please follow the simple instructions below to easily get the product working with Microsoft Windows Vista Operating system.
Installation Instructions
Direct Connection (Parallel & USB connector)
  1. Verify that the printer is turned ON.
  2. Connect the Universal Serial Bus (USB)/ Parallel (IEEE 1284) cable to the printer and to the computer
  3. Click on the Close button when the message "Your devices are ready to use" is displayed in the screen.
  4. The printer is now ready to accept the print job.
Wired Network & Bluetooth Connection
NOTE:For Bluetooth connected printer, please ensure that the printer's access mode is set to public mode for detection.
  1. Verify that the printer is turned on.
  2. Click Start > Control Panel and then select Printers .
  3. Click on Add a printer .
  4. Click Add a network, wireless or Bluetooth printer . A list of detected wired network or Bluetooth printers will be displayed.
  5. Select the printer you want to install and click Next . Follow the on screen installation instruction to complete the printer driver installation.
Wireless Connection
  2. Ensure the printer's wireless network setting is set to the correct wireless profile matching the local wireless network/computer's wireless card setting.
    If you have previously configured the printer's wireless network setting, matching local wireless/computer's wireless card setting, please proceed to step 3.
    if you have NOT previously configured the printer's wireless network setting to match local wireless network/computer's wireless card setting, please follow the steps below.
    To set wireless network settings in an infrastructure network
    Connect the printer to the computer with the cross cable (included with the printer) or connect the printer to the network with a network cable.
    Press the configuration button once to print a configuration page.
    Open web browser, and type in the IP address that has been assigned to the printer.
    Configure the printer's wireless setting to match local wireless network/computer's wireless card setting.
    Unplug the cross cable/network cable.
    Activate the printer wireless network, activate the computer's wireless network profile.
    Proceed to step 3.
    To set wireless network settings in an ad hoc network
    Do the following to reset the printer's network settings:
    1. While pressing the Configuration Page button, press (Resume button) three times.
    2. Wait about 20 seconds, and then press (Power button) to turn off the printer.
    3. Disconnect the power cord from the printer.
    4. Wait about 20 seconds, and then reconnect the power cord.
    5. Press (Power button) to turn on the printer.
    6. Open the configuration utility for the computer's wireless network card, then create a new wireless profile with the following values.
      • Communication mode: ad hoc
      • Network name (SSID): hpsetup
      • Security (encryption): disabled
    7. Activate the wireless profile.
    8. Wait two minutes for the printer to obtain an IP address, then print a wireless configuration page to verify the following for the printer's network settings.
      • The IP address is NOT 0.0.0.0
    9. If one of the above conditions is not true then repeat the preceding steps. Proceed to steps 3 below.
  3. Click Start > Control Panel and then select Printers .
  4. Click on Add a printer .
  5. Click Add a network, wireless or Bluetooth printer , a list of detected printers will be displayed.
  6. Select the printer you want to install and click Next . Follow the on screen installation instruction to complete the print driver installation.
Dec 15, 2013 | HP DeskJet 450wbt InkJet Printer
Network printer printing rubbish when printed from Vista
The problem with dot matrix printers is that these are very old printers and you may not find a printer driver for them that run with Vista. If the incorrect printer driver is installed, the printer will print rubbish.
The only suggestion I can offer is to try various generic printer drivers until you find one that works. Connect it to the LPT1 printer port first and when you get it to work then set it up on the print server.
Also try Panasonic support and ask if they have a printer driver for this model printer that works with Vista.
Oct 22, 2009 | Panasonic Office Equipment & Supplies
Computer can's see Print Server in Add Printer Wizard The WGPS606 installation -- part 1 -- seemed to go fine. It sees our wireless network, we assigned it an IP address, it sees the printer connected to...
Make sure the printer has been connected locally first and that the print drivers have been installed. This should then allow you to add the printer via the set up.
Regards gaz
Sep 28, 2009 | NetGear WGPS606 (WGPS606NAR) Print Server
Printer wont print from notebook even tho it prints from desktop on a home network, My notebook is a hp pavillion 6915nr with windows vista home premium oper system
To get it to print from your notebook you will first have to install it on the notebook as a network/shared printer. To do this you'll run the add hardware wizard/printers making sure the printer is on and connected to the network. Once windows installs the printer driver you should be all set. Hope this helps.
Sep 10, 2009 | Office Equipment & Supplies
Can't add 2 vista computers to Dell wireless printer adapter 3300
Is the printer a networked printer or is the printer attached to a computer?
Jun 04, 2009 | Dell Inspiron E1705 Notebook
Toshiba E-Studio 160 network print?
Go to Control Panel -> Printers. Select Add Printer... When it prompts for a local printer or a network printer, select network. Follow the prompts from there.
Mar 29, 2009 | Toshiba E-Studio 160 All-In-One Laser...
Dell 3300 Printer Adapter and Vista
Vista is tricky when adding networked printers.
Add printer by using a local device, not a networked device.  Assume the printer is connected locally to the machine.
Feb 01, 2009 | Dell Inspiron E1705 Notebook
Taking Time to Print
that is a network problem between the laptop and the PC. Look for your network settings and adjust them.
Use a tool like pctools to identify your network problems. Vista and Xp sometimes have a problem
Apr 19, 2008 | HP Pavilion dv6000z Notebook
Konica Minolta magicolor 5430 DL Laser Printer Logo
471 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
