Question about Equator EZ 3600 CEE Front Load Washer / Dryer
Washer won't spin but motor runs and belt is not broken
My front loader washer is not spinning. The motor runs and the belt is not broken. just tried to start a wash and all it does is just fill up with water and the motor runs...any suggestions PLEASE????
  • Anonymous Nov 18, 2007
    washer fills fine but does not spin and makes a loud sound washer drains fine
  • shoubber Dec 15, 2007
    admeral top load water ok nospin.
The motor bracket is broke, which allows the motor to "jump" causing the belt to come off.
Posted on Oct 29, 2007
Check the filter! If it's full, it won't drain properly.
Posted on Jul 30, 2007
The motor is running but it won't turn the belt on my front loader ge washer
It definitely sounds like the belt is stretched, worn-out, and in need of replacement.
Jul 30, 2014 | General Electric Gfwh2400lww 4.9 Cu. Ft....
My Frigidaire front loader washer drum will not turn or agitate but will fill water and drain water, what is the problem?
Hello acoach194 - If the washer is not agitating try the following steps:
1) Verify a circuit breaker isn't tripped
2) Advance the timer control dial slowly 360 degrees-
If the washer starts spinning, then the motor and drive belt are fine but that there is something wrong with either the timer control dial or the agitator solenoid. Call in a professional for this. If the washer doesn't budge, then verify that the drive belt(s) is attached and not broken by removing the back panel. If the belt is broken, then it will need to be replaced. If it is loose, then it will need to be tightened. A professional will need to do so by loosening up the bolt holding the motor and moving it on its swingarm (much like a car alternator) until there is a 1/2 to 3/4 inch deflection in the belt.
Some washers use reversing motors. It's possible the motor works on the spin cycle but not on the wash cycle. If so, once again call a pro.
3) Visually inspect the lid safety switch- Is it loose or cracked? If so, the washer might work intermittently, stopping at different cycles.
4) Check motor and drive belt- Remove the main access panel (usually in the back). Is the motor spinning, but the drive belt isn't? If so, then you have a drive belt problem.
Dec 17, 2012 | Frigidaire FTF530FS Front Load Washer
Whirlpool top loader washer will not spin
Could be one of several different things depending on the age and model. If its less than 10 years old and is a top load washer its probably a motor coupling (connects the motor to the transmission kinda like a belt) or lid switch. If the water is draining out but the washer is not spinning its probably the motor coupling. If it still has water in it and won't spin, its probably the lid switch. If your washer is a front loader there could be several things going on. Hope that helps.
Aug 29, 2011 | Whirlpool Washing Machines
Front loader wont spin
Hello there:
It doesn't spin If your washer won't spin, check these: If the motor is running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it. A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it. The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle.
May 15, 2010 | Samsung Washing Machines
Will not spin front loader
check under the washer for a broken drum drive belt or parts from a drive coupler that may have broken (type of drive for spin varies with model and make)
Mar 29, 2010 | Kenmore Washing Machines
My washing machine will not spin...
As you don't give the model, I can just give a generic reply.
Most front loaders are belt driven, and some top loaders are.
I think the main thing to look at first is the connection of the drive motor to the tub. If this is a belt - replace it and check the tensioner.
If it is a top loader using a gearbox, then the motor is likely to need either brushes or a new capacitor. Both items should be checked - so -
Belt ok? - Y= go to next question / N = Replace belt
Brushes ok Y= go to next question / N =Replace
Replace Motor Run Capacitor.
Feb 10, 2010 | Washing Machines
Front loader will not spin and drain
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows: If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these: The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it. A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it. The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle
Jan 01, 2010 | Whirlpool Washing Machines
Gallery Series front loader washer not spinning
The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed
For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Nov 27, 2009 | Frigidaire Washing Machines
Does not agitate or spin
Let me make sure I hear your symtoms right..
The washer fills...sound like the motor is running but it doesn't agitate or spin.. then when it tries to drain it bascially gravity feeds out until there is no longer enough water to force it out?
Sounds like the belt is off, or broken.. I am not all that familiar with your model, but I think most GE's are belt drive.
If it were the agitator coupler, the washer would probably still drain..
Pull the front cover off of the washer, you will see the belt and pulleys, make sure it is A: still on the pulleys, and B: tight.
If not, loosen the four bolts on the moter, put the belt on and then slide the motor towards the rear to tighten it.. then tighten the four bolts. They may simply have not tightened the bolts on the motor from factory and the motor slid back loosening the drive belt.
GOOD LUCK!!!
Jun 20, 2009 | GE Washing Machines
How to change the belt in my whirlpool washing
It's probably the washer transmission. Belts aren't common anymore & besides it wouldn't work at all if there was a belt broken.
Jun 18, 2009 | Whirlpool Washing Machines
Equator EZ 3600 CEE Front Load Washer / Dryer Logo
335 people viewed this question
Top Equator Washing Machines Experts
Heartland Ho
Level 1 Expert
lectricjohn
Level 1 Expert
Are you an Equator Washing Machine Expert? Answer questions, earn points and help others
