Question about Pitco Frialator Kitchen Appliances - Others
18s pitco/frilator natural gas will not fire up
Pilot lites and stays on, turn on thermostat to 350 will not fire up looks like does not have enough pressure or valve is stuck changed the whole gas valve with a brand new valve have plenty of pressure on gas side still will not light up
  • 1 more comment
  • chefericweil Nov 28, 2008
    i thought that if the pilot stayed lit the thermocouple was good for it is new also and so is the high limit switch.
    should the adjustment be high or lower
    the regulator was faulty as you mentioned problem solved thanks a million chef eric
  • 728 Answers
You might need a new igniter. First, if you know what and where it is, try cleaning it because it might have something spilled on it that causes it not to light and spark the gas. If cleaning it does not do it, then you might have to get a new igniter which should be cheap.
Posted on Nov 28, 2008
    Genius:
  • 1,550 Answers
It is gas pressure problem have a check to see if there is a gas regulator in line with the gas pipe to the fryer if so adjust regulator.
  • 19,396 Answers
The safety valve is controlled by a thermocouple, test and eventually replace the thermocouple.
  • Ginko
    Ginko Nov 28, 2008
    There is a thermocouple that will close the valve in the eventuality that there is not enough heat. This is a safety device to turn off the gas if flame goes off.
    Find and test the thermocouple.
    Let me know your model number if you want to try finding schematics , I will go offline in few minutes, and answer in the next 24.
Instuctions on how to change a pitco fryer from nat gas to propane
Hi there!
You need to order a gas valve conversion kit (from nat to propane), propane pilot orifice and propane burner orifice,
Gas valve conversion kit consists of a replacement spring thicker than of natural gas valve spring, gas valve cap and a sticker.
Pilot orifice for propane has smaller bore than of natural.
Burner orifice for propane has also smaller bore than of natural burner orifice (one for each burner).
You will be able to find these parts on the list of Pitco Distributor when you visit http://www.pitco.com
Regards.
Jul 08, 2012 | Pitco Frialator E24 Deep Fryer
I light the pilot everything is fine then when i go to turn thermostat on pilot light goes small and burners dont light and when i turn back to pilot the gas ignites and goes out
Sometimes certain models turn off if you touch the thermostat before it lites...
We've seen this happen many times, so you would need to light the fryer first, wait until it's stable before turning your thermostat to desired temperature.
Sep 02, 2011 | Pitco Frialator 35CS Deep Fryer
13 year old pitco frialator fryer pilot wont stay on. changed gas valve and thermopile.... pilot light wont stay lite
Hi there.
Check and tighten all wiring connections.
Check the hi limit for continuity across the terminals using an ohm meter, if it has no continuity, you have to replace the hi limit.
Regards.
Aug 21, 2011 | Pitco Frialator 35CS Deep Fryer
When pilot is lit and white dial is turned to ON, fryer will not ignite when the temp dial is turned from off to 350
Make sure the knob on the gas valve is turned to the ON position after lighting the pilot. If the fryer won't come on.... 1. The pilot flame may be weak causing low millivolts. 2. The thermostat is failing. 3. The pilot flame may be good but the pilot generator may be weak causing low millivolts. As this unit operates on less than 1 (one) volt DC.... you can try to jump the thermostat leads on the gas valve to see if it comes on. If it does... change the thermostat.
Tom
Aug 05, 2010 | Pitco Frialator SG18S Deep Fryer
Pitco Fryer will not light up
Check the thermopile, it must be free of dirt or soot so that it can absorb enough heat from pilot flame and in turn can generate the right amount of voltage to energize pilot and burner coils.
Check also the gas pressure, it should be of standard as required on the unit's nameplate.
Apr 15, 2010 | Pitco Frialator SG14 Deep Fryer
Hello I have a Pitco Frialator 35CD Deep Fryer and as of one day ago, when I turn the wheel to turn the fire on (the wheel with the various temperatures) nothing happens? How do I fix it?
Assuming that the pilot is lit, when you turn the thermostat from off to the operating temperature, you should hear a click at some point. If you do not, the thermostat is defective. You can also double check this by detaching one of the two wires going to the thermostat and measuring for continuity between the two terminals. At off it should show no continuity. At 200F or above it should show continuity. This is the most common problem.
If the pilot will not stay lit or if it goes out when you increase the thermostat setting, it is usually a defective or weak thermopile (or thermocouple), or a defective gas valve. If replacing the gas valve, I recommend replacing the thermocouple or thermopile at the same time.
Restate your problem if the pilot won't stay lit or if it goes out when you turn the thermostat up.
Feb 11, 2010 | Pitco Frialator 35CD Deep Fryer
Hi, i am having a problem with a deep fryer. Pitco Frialator 35CS. The pilot is liting, but the burner will not lite. Solve this for me. thanks
Make sure that the gas pressure is standard (as rated on nameplate), thermopile must be clean (no dirt or soot) and the thermostat is good.
Jan 19, 2010 | Pitco Frialator 35CS Deep Fryer
I have a 3 burner pitco gas friolator and dont know how to light the pilot any suggestions
First, never light when the pot is empty, you can fill with water if you have no oil. Open the door, check the thermostat and make sure it is turned off.(The burners will light if thermostat is on) Behind the thermostat you will see the gas valve. Turn knob to off, then to pilot. There is a notch at the pilot position. Now look up in the middle behind the burners and you will see the pilot assembly. Push in on the knob on the gas valve while you hold a long lighter close to the pilot assembly. Once the pilot lights keep holding the pilot knob in for 20 seconds. Now let off the pilot knob. Pilot should stay burning. Now turn the gas valve from pilot to on. Now turn the thermostat to desired temp and the burners will fire off and start heating.
Oct 15, 2009 | Kitchen Appliances - Others
Frilator pilot will light but fryer wont fire up
The thermocouple or thermopile is your culprit. If it is not sending the correct millivolt signal to the main part of the gas valve telling it to open then, the burners will not light. This is the cheapest part to start with. If after changing this out & you have the same problem then, you have a bad gas valve.
Jun 28, 2009 | Pitco Frialator SG14 Deep Fryer
Sg14dont fire up
The thermocouplen is bad .But before you replace it try to reset the hi limit.It you lite and hold for minute and still go out replace the thermocouplen.
Mar 13, 2009 | Vulcan EF3 Deep Fryer
Kitchen Appliances - Others Logo
46 people viewed this question
Top Pitco Frialator Kitchen Appliances - Others Experts
paulcarew
starztruck4u
Dan Webster
Dan Webster
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
