Question about Epson Stylus RX500 All-In-One InkJet Printer
Epson rx500 print roller doesn't work on one side
Basically my printer works fine until it tries to pull the paper through as it is printing. And well I have barely used the printer and don't want to buy another one. I just need to know how to fix it. or if some knows where can take it to get it fixed.
  • nina20021 Nov 29, 2008
    Thanx i will try that... but how well will that work when one roller doesn't roll at all?
  • 28 Answers
Try to clean the rubber that use to pull the paper or guide the paper in ur hand while the printer is pulling
Posted on Nov 28, 2008
Hi My epson RX500 is not taking the paper, tries but then goes to paper jam
Try putting less paper in the tray. The paper you are trying to use mauy be too heavy a bond (to thick) for your printer to use.
Refer to the manufacturers user guide.
Feb 27, 2015 | Epson Stylus Photo RX500 Printer
Errors with my Printer/scaner
Jessica:
This could be one of a few things... First, Windows 8 is a completely different animal from Windows XP! Try reloading your printer driver in Windows 8. If this doesn\'t work, you need to clean the paper pickup rollers at the front of the printer (where the paper first feeds into the machine. I use a Q-tip moistened (not sopping wet) with rubbing alcohol... gently scrub the whole pickup roller and then the feed roller next to it. Check carefully (with a flashlight) for any shards of paper that might be blocking the paper path. There is also a sensor flag (small finger of plastic) sticking up that the paper must hit to let the printer know that the paper is feeding through. If you do not see the sensor flag, it is either jammed or has been broken off when a piece of paper was pulled backward out of the paper feed area. First reload the printer driver, and try to print. If it doesn\'t print, check and clean the rollers and look for the sensor flag.
May 31, 2014 | HP 1050 Plain Paper Inkjet Fax
Preprinted 4 part paper crunching up when being printed in epson lq680 printer
Mustafa:
The printer is not meant to use multi-copy carbon invoices. The cause of your problem is the double-feed prevention pad below the paper pickup roller. When the first form is fed, the double feed prevention pad will stop multiple paper feeds. With multi-page carbons, the paper feed roller is trying to feed the form, and is pulling the top page of the form into the feed rollers while the double-feed prevention pad is stopping the bottom form from feeding and the top and bottom pages are sliding because of the carbon paper between the sheets. The only solution that I know of is to buy a printer with a tractor feed and pre-printed fan-fold forms with tractor feed strips on the sides of the forms.
Oct 13, 2012 | Epson LQ 680 Matrix Printer
Paper doesn't always feed, and when it does, the paper rolls through without printing
Get a Q-Tip and alcohol. Wet Q-tip with alcohol. Stand in front of the printer and look down where the paper feeds through. On the righthand side you will see a big roller that pulls the paper through and a little one right up under that. Clean both of them with the alcohol and Q-tip. Press the paper feed button and as it trys to act like it is feeding the paper, clean the roller with the Q-tip. Do this until the paper feeds through correctly.
May 16, 2009 | Epson Stylus Photo R1800 InkJet Printer
My printer no longer feeds in Epson Premium Glossy paper S041624
Try to clean the paper pick rollers with a cloth, dam it with little water and try to hange the paper settings by going into printer preferances.
Regards,  raj_p5983
Jan 20, 2009 | Epson Stylus Color 1160 InkJet Printer
Epson RX500, Paper Jam - printing couldn't start
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button, applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time. Worth a try. I have fixed a number of printers this way saving costly repairs. Bud
Jan 06, 2009 | Epson Stylus RX500 All-In-One InkJet...
Roller Marks
Try this to clean the rollers:
Put in blank sheets of paper in then print out from microsoft word a blank document.
This should clean the rollers. Also, there might be special cleaning sheets that you can purchase from Epson.
Oct 29, 2008 | Epson Stylus RX500 All-In-One InkJet...
Epsom RX520
yes i have found a way to get round this paper feed problem, you need a peice of plastic about 3 to 5 mm thick.and about 5cm long a blob of blue tack and stick the plastic strip on the right hand side guide all the way to the bottom. put about 5 sheets of paper in to the guide and adjust the side guide( not to tight). this should help.
Apr 01, 2008 | Epson Stylus RX500 All-In-One InkJet...
Paper either just rolls through without printing or won't catch and sits there
This has occured to a 2.hand printer I just bought. First head was clogged very much. I disassembled the head, used a paper towel soaked in luke warm water to clear off the over-gooed printing head surface. It is quite easy to get the head out and back in. Unfortunately my cyan ran out during clean-cycle, so I can't say if it also cured the passing paper problem.
MDK
Jan 12, 2008 | Epson Stylus Photo R1800 InkJet Printer
Epson Stylus RX500 All-In-One InkJet Printer Logo
75 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
