Question about Terminator Aquastar 125FX Tankless Water Heater: FX Hood Horizontal Vent
I have a charmglow propane ventless fireplace.When I light the pilot the furnace will run properly until it reaches temp.when it shuts off the pilot goes out and requires relighting
  • rsdriller Apr 19, 2009
    How do you clean the pilot?
  • 25 Answers
Sounds like the pilot is dirty
Posted on Jan 19, 2009
Pilot and burner light then gas shut off model 7900
How many degrees before it reaches desired temp, does it shut off? A thermostat is designed to shut the furnace off a couple/ few degrees before it reaches set temp. It has what is called a heat anticipater, which shuts the burner down, and lets the blower use the remaining heat from the heat exchanger to bring it up to desired temp making it more efficient. If it is more than a few degrees, replace the thermostat. You can jump out the red and white wires to confirm the faulty thermostat. If by doing this, the furnace never shuts down, until you separate the red and white wires. That confirms a faulty thermostat. Hope this helps someone.
Oct 06, 2014 | Coleman Propane Forced Air Heater...
Napoleon Fireplace propane Pilot won't light main burner even though gas flows in?
  • I'm going to assume your fireplace has a pilot light.
  • Follow the little holes in the burner that lead to the pilot light.
  • Make sure the pilot flame is pointing directly at the closest burner hole. (adjust if necessary).
  • Often, you will need to sprinkle a layer of "glowing embers" in this area. The embers will help the gas travel to the pilot light and ignite.
  • Always start your propane appliance on "High" never "Low". Cold propane likes to drop to the bottom of the firebox and accumulate until it reaches the pilot (this is called delayed ignition). Keeping it on "high" will help the fuel travel over to the pilot without buildup.
Jan 21, 2013 | Napoleon 36" Zero Clearance Top/Rear Vent...
I have a Charmglow ventless gas heater after it reaches temp, the pilot light goes out.
I have had a Charmglow for about five years and was doing the same thing. I called a plumber that worked with gas fireplaces and he came out, clean the pilot light and now it works great. Cost was $99.00
Jan 09, 2011 | Heating & Cooling
William forshaire 435 runs well for awhile until
Try cleaning your thermocouple,and resetting it where was, which is located at the pilot flame. this should solve your problem.
Feb 23, 2010 | Heating & Cooling
Charmglow ventless gas fireplace burners won't ignite
is pilot flame on the thermopile good, pilot flame should cover the thermocouple and thermopile if unit has both
Jan 07, 2010 | Blue Flame Charmglow 30K BTU Propane Vent...
Pilot light won't light on ventless fireplace
Ventless Gas logs, Vanguard, VS30PR. Propane gas
Pilot light stays lit various times, sometimes for several days then other times for a few minutes. Lights best when temp outside is below freezing. Pilot flame appears to receive too much air. How do you adjust the pilot flame? Is this done using two screws marked A & E? Do you have suggestions?
Thanks,
Ed
Jan 07, 2010 | Desa International Unvented Gas Space...
I have a Charmglow ventless fireplace. When I light the pilot the furnance will run properly until it reaches temp. then it shuts off the pilot goes out and requires relighting if it relights. I took your...
In any gas heating appliance there will be a thermocouple that sense if the pilot flame is lit (lighted?).
You bypass this with the regulator by holding the button temporarily and that allows you to light the main burner. If the thermocouple is bad (not uncommon- they sit in a hot seat all the time), it will disable the gas supply.
The thermocouple should normally measure nearly zero Ohms on a multimeter; if it doesn't, it's bad.
If the thermocouple checks out OK, then the regulator has failed.
Oct 24, 2009 | Terminator Aquastar 125FX Tankless Water...
Our charmglo ventless fireplace pilot will not stay lit. It started to go off including the pilot lite. Where can we find replacement parts for this problem?
I have the same problem with my Charglo fireplace. The propane company checked preasure and they even replaced the regulator. I am very disappointed with this and am afraid to use it. I have contacted Charmglo in the past and they were useless.
May 18, 2009 | Home Decorators Collection Charmglow...
Ventless gas fireplace can't light
You have the wrong piece of equipment and do not list what I need.
Jan 21, 2009 | Home Decorators Collection Charmglow...
Terminator Aquastar 125FX Tankless Water Heater: FX Hood Horizontal Vent Logo
461 people viewed this question
Top Terminator Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Terminator Kitchen Range Expert? Answer questions, earn points and help others
