Question about HP 12c Calculator
Flashing asterisk in left bottom of screen.
Also, the numbers are rounding up and the numbers are not
expressed out. I need them to go out 4 digits.
When I calculate payments, they show with a negative sign.
  • kakima May 11, 2010
    The flashing asterisk is the low battery indicator.
    Negative payments indicate outgoing. Positive payments indicate incoming.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • HP Master
  • 102,366 Answers
The flashing asterisk is the low battery warning.
Press f 4 to see four digits.
Payments with a negative sign indicate payments you make. Payments with positive values indicate payments you receive.
Posted on Feb 18, 2010
Silicon scientific atomic watch
Should be 4 buttons, 2 on left and 2 on right. Press bottom left 3 times and hour offset digit will be displayed. Press and hold top left until hour offset digit starts to flash. Press either top or bottom right to adjust offset hour to correspond with your time zone. Eastern -5, central -6, mountain -7, pacific -8. These are negative numbers, not positive. Then press top left button once, then press bottom left button to return to time display.
Jul 31, 2016 | ATOMIC Watches
Flashing asterisk, BOTTOM left corner.
That's the low battery indicator.
Pull the batteries out, wipe them clean, wipe the battery contacts clean, and try again. Swap the positions of the batteries. Try the old batteries again. If you have another set of batteries, try them.
Jun 16, 2014 | HP 12c Calculator
I bought a Polaris trail boss 250. I need the serial number. Could it be *1560086*
The serial number on most Polaris atvs are on the left side bottom frame behind the front wheel and will consist of 17 digits. Older Polaris atvs, however, did not have to use the 17 digit VIN because there wasn't a standard set in place. For these atvs check the right frame support by the shift lever. There should be a number stamped in place and will have asterisks before and after like the number you have posted. I can't be for sure if the number you have is correct, but it sounds pretty good. You can call a polaris dealer with the number and they can put it into the polaris website to check for sure.
Nov 06, 2011 | Polaris ATV
Dear friend, i have just got a brand new telememo gift n am not having the manual. Please help me set the time and other adjustments in it.
Press and hold the top left button until the seconds digits flash, indicating that you have accessed the time-setting screen. Press the bottom right button to reset the seconds to "00" and then press the bottom left button to advance the flashing to the hours digits. Adjust the hours digits to the desired time using the top and bottom right buttons. Press the bottom left button to advance the flashing to the minutes digits, and set them to the desired time with the top and bottom right buttons. Press the top left button to exit the time-setting screen.
Have a nice day.
Mar 09, 2011 | Watches
How do I ente 8x - 1 over 10 on my TI 84 plus silve edition
I am not sure what the cross (x) means: is it a multiplication or the variable x, so I took a screen capture of both cases.
The top case is obtained as follows the asterisk is the multiplication sign to thr right of digit 9; the small minus is the change sign key the minus sign in parentheses under digit 3 and to the left of ENTER key.; the forward slash is the division sign, above the multiplication sign.
This small minus called change sign makes a positive number negative and a negative number positive, hence its name. If your expression starts with a negative sign that is the one to use. Use it also for negative exponents.
As you can see the result is -.8. Notice how the - before the dot is small with respect to the regular minus, as in the last expression.
For the last expression on the screen capture, there is nothing special, except that you have two ways to enter the variable X.
1. Press [ALPHA] [STO->]
2. Press the key [X,T, Theta, n] to the right of the green [ALPHA] key.
Hope it helps.
If x is the multiplication sign
8[x] [(] (-)1
Oct 06, 2009 | Texas Instruments TI-84 Plus Calculator
How to unlock the motorola c139
Press the "Menu" button and then the asterisk "*" in quick succession.
Pressing these same two buttons again will lock the phone.
(Note: the "Menu" button is the button in the center of the up, down, left, and right arrows. The asterisk "*" button is on the bottom left of the keypad.)
Dec 24, 2008 | Motorola Mobility TracFone C139-4 Cellular...
I need to flash my ipod the screen froze when i remove the cable from the p.c.
First make sure your hold switch isn't on. It's on the top or bottom and slides back and forth. It needs to be switched to the left. Once it is to the left, here's how you reset:
You can reset your ipod by holding down the menu and select (round button in the center) buttons down for at least 10 seconds. You'll see an apple logo flash, that's when you stop pressing the buttons. It will shut off, then back on.
Jan 18, 2008 | Apple iPod nano
Frozen on the ok to disconnect screen
Jan 12, 2008 | Apple iPod nano
HP 12c Calculator Logo
1,677 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
