Question about iRiver Audio Players & Recorders
I have a HP-120, and got fried due to incorrect charger plug. What can it be done?
  • 12 more comments
  • laintencion3 Nov 28, 2008
    Technically I do not know if its fried, reading from forums and to the symptoms it seems that way...
    I have read that there is something that can be done... will like more feedback...
    Its an MP3 Player iRiver HP-120, Thanks!
    Once I turn it on, it will stay at the logo screen, I have read that something can be done, more suggestions pls...
    Ok, so I used the wrong charger, how do we know whats fried??
    How do we know how much of it its fried?
    More suggestions pls...
    more info pls
    more...
    Ok pls read the post, its not an HP computer, its an iRiver MP3 Player...
    If you are only going to suggest to throw it away pls don't post...
    more pls...
  • iRiver Master
  • 13,433 Answers
Since the board is fryed, yes most likely due to incorrect voltage etc. Replace the mainboard or then you need to do very deep testing on it.
Or throw it away and buy a new one.
Posted on Nov 28, 2008
    Sergeant:
  • 291 Answers
Check out the board as u said its fried that means on the board u can definalely checkout the place with burns where it is fried.check out with the multimeter as which circuit track is got burned out or got short.as its very dificult to do it your self.u can call a technician at your place or take it to the repair center and get the area of fault located and try to make it proper.as if it is just minor short circuit due to extra current passed and got short due to over voltage.then it can be replaced.
or there r two options
1)replace the board completely.
2)go for new device completely.
  • 162 Answers
Since your knowledgable enough,
flash the firmware
and if that doesn't work, accept the fact.
  • 1,879 Answers
Try connecting it to a computer and update or re-flash the firmware.
  • 10,515 Answers
Try this. the iriver doesn't boot at times ( wrong charger or using the right charger abroad), unlatch the battery and hold down the power button for about 20 seconds. also reset the instrument. hopefully that might work for you.
  • 734 Answers
Its need a repair,, because if you used ‘fried’ word, no one can help you,, better purchase a new.
  • futureloginn
    futureloginn Nov 28, 2008
    Your problem is occurred due to sum short circuit in the charger,, so, your iriver charger supply AC current to iriver,, that would caused “FRIED”
  • futureloginn
    Thanks
  • 849 Answers
As the most of experts suggested to go for new one. before buying new, you may try all possibilities could be done with your device. visiting of hp repair center is the best choice.
good day
  • Muhammad Saeed
    Muhammad Saeed Nov 28, 2008
    chcek virus with a updated virus remover.
    Novelist:
  • 167 Answers
All you can do is take it HP Repair & Service Shop to have it repaired. The repair priced may be reduced if it is still under warranty.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, may I suggest that you consider:
  • the expenses involved if you will seek the services of a tech or send it to an authorized service center for repairs. With this in mind, it may no longer be economical to repair;
  • consider a DIY (do-it-yourself). research, ask around, post questions on forums;
  • learn basic electronics, that way you can perform tests and diagnostics yourself;
  • borrow a DVM or VOM (multi tester);
  • look at it this way, whats the worst thing you could do if you venture a self repair?
  • nothing to loose, its dead anyway (sorry) but everything else to gain; knowledge and skills, and perhaps even repair it.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
  • Louie  Role
    Louie Role Nov 28, 2008
    Your post/query:
    • wrong charger, how do we know whats fried - you would need to open up the unit and use a DVM or VOM to check for shorts or open components. Of course the ICs normally could not be checked though;
    • Once I turn it on, it will stay at the logo screen - tells us that the internal power supply is generally functional, how correct the internal voltages are, again you would need a DVM or VOM to check and compare to known good readings. This would then require access to a service manual and or a schematic diagram. Further, this signifies that the firmware is not initiating correctly, it is not loading its operating system. Possible explanation could be corrupted firmware, some of the critical components are not responding hence the firmware is waiting for a response and therefore will not proceed to next step, boot;
    • something can be done - of course something could be done. Anything and everything could be fixed. There is just always "but" somewhere.
    Genius:
  • 1,239 Answers
Hi  is the whole circuit is fried up or the battery.if battery The batteries in the iPods are only meant to last for 18months.After this period there is a good chance that your battery will start to lose it charge and eventually not charge at all. You very may well need to replace the battery in it if it is over 18 months old.
Hope this helps and good luck!
Jaxon
  • ABHISHEK.C
    ABHISHEK.C Nov 28, 2008
    you can try to turn the hold button on and off that sometimes works
  • ABHISHEK.C
    here it is
    The problem with your Player is that its Firmware has been crashed....So you need to reinstall the Firmware using Philips Device Manager software given along with the player....But you cant retrive those data coz once you reinstall it all the data will be erased.....To do it is very simple.....just go into the repair Tab In hp120 Device Manager and Follow the instructions...
  • 728 Answers
You can get the correct charger and try it on the mp3 player, and if it works, then it is not fried, and if it does not work, you will have to get a new one. If it is fried, there is nothing you can do because it has messed up and burnt most of all of the electrical components inside the mp3 player that is used in the operation of it.
  • Jazz Boyce
    Jazz Boyce Nov 28, 2008
    Try connecting it to the computer and see if it can be recognized. If it can, then back up all of your data and update your firmware. This should reset it to where it can pass the logo and you can actually play music. It should also be able to charge through the usb cord. If it is not recognized, then something inside it is messed up.
  • 4,806 Answers
I'm sorry to tell you this but you have shorted the unit out by connecting the wrong power suppy to it! there is no way the unit will ever work again, if you have a SD card take it out and back it up, then you may aswell throw the mp3 away after that and buy a new one, the repair costs alone will far exceed the price of a new one. like you said you have fried the unit, which means its dead
best regards and please don't forget to rate us
  • Lee Hodgson
    Lee Hodgson Nov 28, 2008
    there is nothing that can be done, this is because the internal parts of the device are micro boards, once they have shorted thats it!!!!!! its beyond economical repair and is fit for the trash
    Novelist:
  • 183 Answers
Best thing is to replace it because it is damaged now
  • Inderpal Singh
    Inderpal Singh Nov 28, 2008
    call HP on 18004746836 to get it replaced or repaired
    Scholar:
  • 71 Answers
Not much really sorry to say, it has probably blown the internal power board which is a replaceable part through hp but unless you are good with electronics it may cost you more than its worth to fix.
Ebay has many of these units for sale that you could dissect for the needed parts to fix yours.
    Scholar:
  • 174 Answers
Call HP on 1800 474 6836
  • 1 more comment
  • debroy
    debroy Nov 28, 2008
    get a new one or call hp 1800 474 6836
  • debroy
    debroy Nov 28, 2008
  • debroy
    debroy Nov 28, 2008
    call hp
  • 96 Answers
If it really got fried, there isn't much recourse. you could always buy another, and turn the broken one in for a refund or exchange, and give the second one away as a gift, or pocket the money.
Harley twincam 120 sounds like spark knock on accel after reaching 2500 rpms
Hi Tom, and the usual suspects are:
1. Fuel octane rating too low.
2. Faulty spark plugs.
3. Incorrect spark plug for the kind of service.
4. Excessive carbon deposit on piston head or in combustion chamber.
5. Ignition timing advanced due to faulty sensor inputs (MAP, CKP, CMP)
Good luck.
Apr 21, 2013 | 2004 Harley Davidson XL 1200 C Sportster...
Can i use 220v source to energizer charger chvcm4
you will need a reducing transformer 220volts to 120 volts, you can find one at Radio Shack or Fry's Electronics., European countries uses 220volts, and the plug configurations are different from those of the USA.it is recomended to take one of these transformers with you when you travel abroad.
Apr 13, 2013 | Energizer Rechargable Battery with Charger
To hard wire the charger for a 220 v 20 amp ..after i run the 4 wires into the unit (black to black red to red green to green ) where do i put the white it just has to places left one is marked with a...
Without knowing what kind of charger you're wiring, I have a couple questions: I'd like to see the circle and square icons you are describing - and I'd like to know the name and model of the charger you have. Failing that; I can offer a couple things: First, you should attempt to obtain the wiring information for the device.
I would tend to agree that "black to black red to red green to green" are most likely going to be correct, where, red and black are both line voltage wires on a 240 volt system - and green is ground or "equipment ground".
White wires, are generally "neutral" or the common point between the two line voltage wires. As such, it has a 0 volt (or very, very low) potential to ground Many 120/240 volt systems also ground this common neutral point, but this does not happen all the time - and should not be done unless required by local electrical code and electrical system.
Most 240 volt devices do not make use of a neutral wire, unless the device or appliance needed 120 volts for a part of it (the clock or frying pan outlet on old electric ranges comes to mind). If a neutral were introduced, it would really become a 120/240 volt device instead of a device that could be wired straight 120 or 240 volt. If the charger you have is indeed a 240 volt device - and does not need a 120 volt circuit, you should be able to omit the neutral connection. If I knew the info I'd like to have in my first paragraph, would make me feel much more comfortable offering this advice.
I hope this helps & good luck!
Sep 20, 2011 | GPS
I have a philips bodygroomer BG2020 with charger ratings of 110-120V in and 3.7V, 95mA 3W out. I move outside the US and require a 240V AC input charger. I got a rplacement charger from Philips whic was...
I think the difference of 0.6 volts on the 220 volt charge will not cause any damage as the currect factor is low. this is due to the fact that the incremental voltage of 0.6 will compensate for the difference.
The other option for you is to use a step down transformer 220to 120 volt( 50 mA rating)
Jun 29, 2011 | Philips Health & Beauty
I have a hp g60, i have a really weird issue. Some times my laptop stops charging suddenly and the small led next to my charging input slot does not show any light. I checked my charger its showing...
Kind of vague. It could be the port on your laptop where the charger plugs into. It could be bad, or could have a bad connection to the motherboard due to use or manufacturing defect. When the charger stops charging then it has to use the battery power. This morning the battery may have had a low charge causing the laptop to shut down. Did you notice the battery's power level before it shut down? If you are wiggling the end of the charger that is plugged into your laptop to get it to start charging again, then that is most likely your problem. Do not wiggle it , for it could fry your motherboard. If that is the case then that port needs to be re-soldered.
Jan 24, 2011 | HP G60-230US Notebook
Can the Magic Wand Rechargeable Massager be charged from a 220 volt power?
If your wand is N American then "don't do it" 220 through a 110/120 will fry all the magic out of it. You could get a step down transformer 220 to 110. Plug that into the 220 socket and plug your magic wand charger into that.
The cost would not be worth it though ... buy some more magic that is 220. be happy ... not sorry :-)
Nov 17, 2009 | Hitachi Rechargeable Wireless Magic Wand...
"Black screen of death" iriver H10 6GB color
sounds like incorrect charging voltage and amperage may have fried some of your components.
Could try selling it on ebay as-is to make some money toward another unit.
You can get a top notch 20gb refurb unit from ebay sellers (like metromania) for $40-60. I have 2 refurbs and 1 built from parts from as-is units.
Mar 07, 2009 | iRiver H10 MP3 Player
fired mean no more, u have to buy a new MP3 player, before buying new, you may try all possibilities could be done with your device. visiting of hp repair center is the best choice.
Nov 28, 2008 | iRiver Audio Players & Recorders
Iriver iHP-120
You can get a replecement on Ebay or at Maplins the spec is
In: 100-240V~50-60Hz 360mA
Out: 5V~2A
be careful I once fried an IHP-120 by using the wrong charger. I replaced the battery but taht wasn't the issue. I had it replaced with a IHP-140 and now my old charger has gone too. I got a replacement through the company I bought it from but they have none left.
Nov 08, 2007 | iRiver iHP-120 MP3 Player
131 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Shawn DuRee
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
