Question about Lexmark Office Equipment & Supplies
The Printer USB Port appears to have failed. Have changed out the USB cable and tried every USB port on the computer. Still the Printer does not communicate with the computer. Have uninstalled and started from ground zero with latest drivers. Printer is a Lexmark X6150.
  • qhodge Dec 01, 2008
    Was helpful. Found that the Printer Port is bad. Printer will need to be replaced as you stated. Thanks
    Scholar:
  • 174 Answers
Does other usb devices work on computer..if yes then could be an issue with printer port.
try to disconnect the power and usb cable from the back of the printer and press and hold down the power button for 30 sec and then reconnect the cables and try again...open the backdoor and try to move the rollers in upward direction.Make sure the unit is connected directly to the walljack.
if still does not work..printer needs to be replaced.
Posted on Nov 28, 2008
Set-up won't recognize that the USB cable is connected to both printer and computer and therefore printer won't work. What's up with that??
1. Confirm the USB port on the computer you are connecting your printer to is being recognized by your computer. The easiest way to do this would be to plug a known good USB Memory stick into the USB port you want to use. If you can read the contents of the USB Memory stick then the port should work. Remove the Memory stick, start the printer installation program (Make sure you don't the printer connected), want until the setup program tells you to connect the printer before you attach the Printer's USB cable.
If the printer isn't recognized try a different USB port, when picking a new USB port to try select a higher priority port, for example in increasing priority from, an external USB hub, a powered external hub, a monitor based hub, USB ports on the front of the computer, up to the USB ports at the computer rear. For USB ports on the same circuit select an USB 2.0 before an USB 3.0 port
Aug 04, 2015 | HP OFFICEJET PRO 6830 E-ALL-IN-ONE PRINTER
How connect a tcp ip printer.
Hi Kumar,
You can modify or change port in the printer driver to connect it through LAN cable. Please notice whether you use static or dynamic ip address. Please follow below step.
In the following step we will modify your existing USB connection. Check it out!
Step:
  • Open printer driver list.
  • Right click on the printer drive name (e.g Canon IR2270).
  • Select Properties.
  • Click Ports tab.
  • Click Add Port, then select Standard TCP/IP Port.
  • Click New Port.
  • Click Next on add port wizard menu.
  • Type IP Address (for static ip setting) or Printer Name (DHCP), then click Next (computer will search the printer).
  • When the printer has been found, finish the wizard.
  • Close Add Port menu.
  • Now you have new port represented by IP Address or Printer Name (with checked box active) in port list .
  • Click Apply.
Bingo! Now your printer ready to print via LAN. Sometimes printing right after setting this new port not always succeed. Don't be panic. Restart both of printer and the computer.
Next time you want to connect the printer via USB port so you change port back to USB. Just simply check on the check box next to USB Port in port list and click apply. You may need to restart both printer and computer too :)
Have a nice day!
Printer Clinic
Jan 13, 2014 | Canon iR2270
Printer not talking to desk top.
Please check usb cable first, make sure that it is ok. Then check usb port,move the usb cable to other port. Then check if usb cable and port are ok, try to connect other printer or device by using that usb cable and port. If works well means the usb port on printer got a problem. But if still not work the problem could be on usb cable or usb port on computer.
If you are sure that both the printer and computer are ok, try to reinstall the printer driver. Good luck!.
Source: Printer Clinic - Where printer problem get solved
Sep 18, 2012 | Canon Pixma MX310 All in One
My computer is saying it is not connected to my Lexmark x2670 printer but I have everything connected. I need my printer! Help please.
Cannot Communicate; install USB; Install cable; installation USB; Installation cable; Cannot continue installation; Unable to press Continue; Unavailable Continue button; Continue button not active; Opaque Continue button; Gray Continue button; Continue button grayed out; USB connection not recognized
Solution
What you will see The Continue button is gray (i.e. Continue), preventing further driver stallation. connect the Installation Cable; using the supplied installation cable, connect to any USB port on this computer. Back Quit Continue There are several possible reasons for an inactive Continue button. Try the following suggestions in the order provided to resolve this issue: Action
1 Make sure the printer is turned on:
2 Confirm a solid connection of the USB installation cable on both printer and computer. HINT: The USB port is identified by this symbol:
3 Keeping Step 2 in mind, disconnect the USB cable from both printer and computer and then reconnect the USB cable at both ends.
HINT: Listen for audio alerts or notification icons or balloons in the Windows notification area. For example, or or .
4 If your computer has multiple USB ports, try connecting the USB installation cable to a different USB port.
NOTE: Passive or self-powered USB hubs may cause a problem.
5 If one is available, try connecting another USB device to the same USB port to see if it is recognized by the operating system.
6 If one is available, try a different USB cable that is under 10 feet.
NOTE: Some port replicators or docking stations for laptops or notebooks may cause a problem.
7 Confirm that you are installing the correct software driver for your printer model. For example, a 7600 Series driver works with the X7650 and X7675 All-In-One.
8 Turn off the printer, and disconnect and reinsert the power supply and power cord. Click here for image.
9 Click Quit to exit the installation. Remove the CD from the CD or DVD drive. Then reinsert the CD and try to perform the installation again.
To save time you can skip or close the hardware setup wizard if you have already completed these tasks. 10 Confirm that Device Manager recognizes the device. To open Windows Device Manager: Click on Start and then Run.In the Run dialog, type devmgmt.msc. Click OK.11 Next, disconnect the USB cable from the printer and reconnect it. Watch the Device Manager indow while you do so. The appearance of the items in the screen should change as Device Manager tries to recognize the device. Click here for image.Macintosh users: System Profiler is the Device Manager equivalent. Click here for instructions on accessing System Profiler, and look under Hardware > USB for the printer.12 Does Device Manager show a change in appearance?-If Yes, contact Lexmark Technical Support for additional assistance. -If No, there may be a problem with your computer and its USB support. The computer must recognize the USB cable in order for installation to work. 13 Reboot your PC and try these steps again.
Oct 02, 2011 | Lexmark X2670 All-In-One Printer
How do i change the language bak to English? And how do i print from my macbook laptop onto the printer
TO CHANGE THE LANGUAGE:
From the printer control panel, press the 'Spanner' icon.
Press the right arrow button, and then press OK
Press OK again.
Press the arrow buttons until the language that you want appears on the display, and then press OK.
If you are sure, press the right arrow button, and then press OK to change the language.
To print from your macbook laptop you may have to install additional software onto your laptop from the installation CD. Insert the CD and wait for the 'Welcome' screen to appear. (Note if the 'Welcome' screen does not appear after a minute, then click the CD icon on the desktop). Double click 'Install' and follow the screen instructions.
Some additional notes that may apply to your machine(s):
If the printer is connected to a desktop computer through the rear USB port and you decide to connect a laptop computer to the printer through the Quick Connect laptop port, then the Quick Connect laptop port connection overrides the rear USB port connection. The active print jobs on the desktop computer may be cancelled. Pause or cancel active jobs on the desktop computer before switching between ports.
To summerise:
Pause or cancel active jobs on the desktop computer.
Connect a USB cable to the laptop computer and then to the Quick Connect laptop port on the front of the printer.
Warning-Potential Damage: Do not plug in or remove the USB cable from the Quick Connect laptop port while a memory device is being accessed by the printer.
If you have not yet installed the printer software on your laptop then install it now.
Hope this helps
Jul 14, 2011 | Lexmark X6675 All-In-One InkJet Printer
INSTALATION
Try to connect the printer by using another USB Cable and in different port may the USB port in computer side or the usb cable is damaged that is why fail to send signal to your acer then try againt to install by using add hardware wizard
Jan 17, 2011 | HP DeskJet F380 All-In-One Printer
Hi I have a new brother printer and it was working fine. I have gone to use it again and it keeps saying the printer is offline...yet I have registered again and everything is the same. Help
check that the printer cable is inserted fittingly, on the computer and on the printer, if alright,change the port from which the printer cable is connected,am assuming it is usb. if still not responding, turn off the printer, reboot the computer, and turn it on, if it fails, unplug the printer from the computer and uninstall the driver. reboot the computer and reinstall, while installing, it may prompt you to plug it in. if it does not, do not worry, just plug the printer cable after the installation is through, the computer should recognize a new device and go on to auto install, if it does not, then you have bad usb port port or controller drivers. to be certain, plug any other usb device onto the port(s), if positive, buy a new usb card and install on computer and connect printer
Oct 17, 2010 | Brother MFC-7440N Laser Printer
My lexmark 4300 series says incorrect port detected
Hello!
Yes the problem is with your printer port setting, to view or to correct the printer port setting,
- go to CONTROL PANEL
- click or open Printer or Faxes
- right click your Lexmark printer and click properties
- a menu will appear, choose or click PORT tab
- at the Port tab listing, choose USB port and click ok after choosing the right port.
then you should be able to print properly after the right configuration.
Hope I was able to help.
Jul 23, 2010 | Lexmark All-in-One Printer with PictBridge
Samsung ML-4500 with IEEE 1284 to usb cable not working
Windows XP/VISTA (do not install the CD)
1) Plug the cable into the USB port on your computer.
2) A prompt that says "Found New Hardware" will appear. Windows will then install the USB printing support driver automatically. You do not need to install the driver from the CD.
3) Plug the cable into the printer.
4) If your printer is already installed, click on Start, then Printers & Faxes. Right click on the printer you are connecting to and click on Properties. Click on the Ports tab and check the ‘Virtual printer port for USB’ port. Click OK.
5) You should now be able to print.
With XP, the biggest clue is to FIRST plug the cable into the usb slot, THEN the other end of the cable into the printer.
May 14, 2008 | Computers & Internet
Pixma 160
Chances are you reconnected the printer to a different USB port and your default is still set up for the other port...
Look at your printer settings and chances are it set up the printer again for the new port.
Either change your default printer or move the cable back to the original port.
Jan 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
37 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
