Question about Mitsubishi VS-50805 50" Rear Projection Television
Buzzing noise I have a Mitsubishi VS-50805 television that I just purchased. When I listened to it at the house from the guy I bought it from it sounded fine. After they moved it to my house and we set it up a very loud buzzing noise is coming from the back. We removed the back panel and the noise is coming from a small black part with the serial number P754-1 on it. Has anyone encountered a problem like this and can it be fixed?
    Scholar:
  • 186 Answers
It could be a high voltage transformer. The serial number won't help me locate the part, but there should be a part number on it. Anyways, this could be the transformer on it's way out. When they are on their way out, sometimes they will amplify the noise through the system and buzz through the speakers too. If you find a part number, check it out on partstore.com to see what a replacement would cost.
Posted on Jun 12, 2008
My vs-50805 turns off when it wants for as long as it wants ? How do I fix it ?
In general two possible reasons--sets of this age often develop bad solder connections on the boards--normal with age, heat and expansion and contraction of the the boards.
You can also have a issue where some Glycol has leaked from one of the tubes onto the circuit boards under them--I can tell you where to look and what to look for if you do not know.
Jun 15, 2012 | Mitsubishi VS-50805 50" Rear Projection...
I have audio but picture blacks out
You may have a bad ground on your vertical IC to begin with! Other repairs would include a bad ground on a coil or the horizontal transformer. The biggest problem is, Yes you have some bad grounds. Repair will be, to find the cracked rings underneath the boards and resolder. Take this note to your local TV Tech, this is your best defense in keeping the the repair cost down! Knowledge, in this case, is on your side now. Good Luck in your search!
Jul 03, 2010 | Mitsubishi VS-50805 50" Rear Projection...
I have a mitsubishi VS-50801 rear projection TV that has a very distorted and glichy picture
Ur tv convergence are dead.Ur tv convergence board require changing the 2 STK convergence ICS,and some or all it resistors.The shop will cost u $300-$350 for parts and labors.
May 19, 2010 | Mitsubishi VS-50805 50" Rear Projection...
Mitsubishi VS-50805 HD 1080 Series
check the convergence ic's unplug the main convergence board plug then try the set again if the set comes on get a convergence kit here
http://www.tvrepairkits.com/xcart/home.php?partner=larry
May 16, 2010 | Televison & Video
I have a mitsubishi model vs-50805 projection tv and my picture has a 3d effect u can see the letters in the menu in 3 colors
the problem with this unit is in the convergence ic's need to replace and check for bad resistors and pico fuses in the circuit
Jan 25, 2010 | Mitsubishi VS-50805 50" Rear Projection...
VS-50805 Replacement Lamp Bulb
Did you find a bulb? My green bulb is dying and I need to find a replacement and I am being told the factory does not sell the part anymore. Any guidance would be appreciated.
Erbys
Jul 25, 2008 | Mitsubishi VS-50805 50" Rear Projection...
Mitsubishi VS-50805 Service Mode
Sounds like you gotta call that guy back or report him for damaging your set.
Sep 13, 2006 | Mitsubishi VS-50805 50" Rear Projection...
Mitsubishi vs-50805
You said you checked the convergence ICs and they're okay - WHAT did you check? Check temperature. Also, try rapping on the heat sink they're mounted on, see if that shuts it down or causes flickers in picture. If those provide no further insight, your problem is bad capacitors on the power supply/waveform generator/deflection board, you will need ESR equipment to check them and good soldering skills to replace. Unit will require in-shop service. A repair bill over $250 is a swindle - we did one for half of that last week.
Jul 12, 2006 | Mitsubishi VS-50805 50" Rear Projection...
Mitsubishi VS-50805 50" Rear Projection Television Logo
424 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
