Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony dlp type tv is always very green and no ajustments help
Check crt
Posted on Nov 28, 2008
Sony Wega flashes endlessly and won't turn on.
IF ITS A DLP TV REPLACE COLOR WHEEL THIS MAY BE THE CAUSE OF THE BUZZ AND ENDLESS FLASHING....I ASSUME ITS A DLP COS OF THE MENTION OF BULB IF NOT CHECK TRI BULBS STK AMPLIFIERS IF ITS THAT TYPE
Oct 08, 2015 | Sony Televison & Video
Blue spots on Sony WEGA KDF60XS955
Thats caused by a bad optical block. The cost of that repair will almost always be greater than replacing the TV.Thats a very common issue with alot of Sony DLP models which suffered that optical block issue with the blobs of color usually blue or green
Dec 10, 2012 | Sony Grand WEGA KF50WE610 50" Rear...
Yes my Sony KP43T75GRAY 43 in. Rear Projection TV worked beautiful before I placed it in storage for about 7 months. Now it has a slight green haze on everything. What should I do? I was told to remove the...
The DLP tv alway have problems with it convergence board problems.Tries flash focus button or manual + - convergence R,G,B colors lines alignments up.Still have the same problems,the convergence board is dead or have problems,convergence board must be fix to solved the green haze problems.
Jan 17, 2011 | Sony KP43T75GRAY 43" Rear Projection...
My sony dlp tv looks like 3d. the three sprectrum
This is convergence bord problem and you need to replace the STKs and check all resistors around the two stks and replace the faulty ones. If you are not too confident, its better to seek professional help. some indication of costs are available on www.fixurtvs.com. You can download service manual from fixya site tech support and decide what you want.
Mar 22, 2010 | Sony KP-51HW40 51" Rear Projection...
Sony T.V. has too much green in color .
Went to site http;//esupport sony.com/sxrdsettlement and found out Sony has to replace the optical block which cause the picture to have too much green. You have till June 30,2009 to get it fix.
May 17, 2009 | Sony KDS-50A2000 50" HDTV
Samsung DLP HL-R5667W, seeing little boxes of static flashing
samsung color weel replacments are all the new air bearing type insted of fluid type. if you replace the new color weel , color will look bad. also note when ordering your replacment make shure it comes from samsung and not just a generic model.
the original replacement will come with a set of instroction to reset the dmv ajustments.
find the dmd pcb and look for a2 jumper that is visable through a small squaire remove the jumper. then folow instrustions with new color weel.
hope this helps.
regards,
daniel.
Jan 13, 2009 | Samsung DLP HL-P5663W 56" TV
Sony rear projection convergence
This is a convergence problem that is either bad connections on the convergence ICs or defective ICs. IF you can solder and feel comfortable working inside the set, you can fiox this yourself. Let me know if you wish to attempt the repair and I'll post more details and instructions.
Dan
Nov 06, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KP413SU
id like to help you but there is alot of difference between an old sony kp41 and and new sonyl dlp tv
Dec 04, 2006 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
