Question about RCA P56923BL 56" Rear Projection Television
Rca p56923bl chirping
I have a rca p56923bl it has a chirp i can get it to cut on by heating the back right coner of the power bord what part do i need to change
  • bogger44in Dec 06, 2008
    hey i changed the part but it didnt make a difrence any other suggestions i can keep it on by leaving the hair dryer on it
  • RCA Master
  • 8,617 Answers
Horizontal Output transistor looks like this attached to a heat sink near the Flyback transformerrca p56923bl chirping - 97bd027.jpg
Posted on Nov 28, 2008
My old 32 inch rca f32665 stopped working as we were watching it. no picture or sound and there is a sound coming from the back where the power cord goes in that sounds exactly like a cricket only its a...
The usual cause is a shorted horizontal output transistor. The way this chassis is designed, the supply makes 140 volts which is always on and applied to the transistor. The heavy load on the power supply causes it to make that chirping sound as it keeps trying to start, then shuts down right away.
The h-out is Q14401, RCA part number 237470. A 2SC5148 can replace it.
Jul 31, 2011 | RCA F32665 32" TV
Rca P52927 TV will not power up and chirps when plugged in. Any help?
while playing ps3 on the tv first a chirping sound, then a loud pop then the set cut off. After the set cut off the red timer light stays on.
Jan 23, 2010 | RCA Televison & Video
RCA p46732ba projection TV no power.
This is a common problem and the set is in shutdown mode. It attempts to fire up three or four times (the chirp you hear) if it detects a fault it shuts down - the most likely cause is the HV (high voltage) block- caution working on it since HV is present - The repair generraly costs $200-400 P# 205064
Google your model # and HV block to see what I mean.
Oct 06, 2009 | Televison & Video
test each circuit on the board one or more of them are going to be bad. it may take some time but it will tell you where the problem may be.that way you wont keep spending money on more parts ron
Dec 07, 2008 | Televison & Video
Rca big screen
Most times when this unit chirps the horiz output transistor has shorted. If I remember correctly the transistor is Q401. Some times the flyback transformer can be bad as well T401.
Jan 28, 2008 | RCA P46921 46" Rear Projection Television
My 52 in
Chirping is usually a problem in 2 areas of this unit. 1st check 3 legged regultor on the right side of the chassis, also 2 small transisters and 2 resisters near and in front of the regulator. RCA has a kit for this problem, the second is check the horizontal output transister is on a separate heat sink along side of the Flyback Transformer, it shorts and pulls down the regulator power supply.
May 28, 2007 | RCA P52960 52" Rear Projection Television
Tv went dead while viewing, will not power back up
You have a short somewhere in the load for the power supply. Probably the horizontal output transistor and the flyback transformer. You need to have it checked out by a tech. You may want to get an estimate. Stargazer
Mar 11, 2007 | RCA F36715 36" TV
My RCA F32650 doesn't have a picture
Replace IHVT aka flyback xformer--part#257805 or Asti 2078.
Dec 29, 2006 | RCA F32650 32" TV
Televison & Video Logo
53 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
