Question about Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television
My mom has a samsung hc-p4752w and my stepfather heard a pop with a burning smell and after that his tv has a double vision look. so i saw on here how to fix the grid which worked fine except the red vertical lines they would not budge. please can you help me fix this i am only in town until tomorrow morning and i wanted to fix it for them tonight if possible any help is appreciated. thanks.
  • 4 Answers
Convergence IC's are bad......
You can mess around with ordering them, and replacing them, and hunting for the bad resistors on the board and replacing those too, or you can order a new board PN BP94-01266a for around $160, and plug it in. You'll have to readjust the convergence manually afterward. Just did it on my set - works beautifully!
Posted on Dec 02, 2008
Samsung hc-p4752w
look for trouble in the low voltage and or high voltage power supply circuits. the popping sound could be an exploded safety capacitor in the horizontal output to the flyback transformer. the horizontal output transistor maybe damaged. chances are the low voltage regulator is also damaged.
Aug 11, 2009 | Samsung HC-P4752W 47" Rear Projection...
My hcp4752 started smelling hot now the colors are
It looks like you have a problem on your convergence panel. Look for burned resistors near the STK-* IC's. One or more of the STK-* IC's may be bad. When the resistors get hot they smell but so do the IC's. You can replace the bad parts or you should be able to replace the entire panel then go thru a convergence alignment.
Jun 06, 2009 | Samsung HC-P4752W 47" Rear Projection...
Samsung hc-p4752w
Burned out? How? Depending on the age of the TV, there are two boards, possibly a third if it's a later model. The most likely culprit is the PWR & DEFL board - P/N BP94-01266a, and it's readily available for around $150, but before you order it, tell us more.....Do you have sound, etc.
Nov 05, 2008 | Samsung HC-P4752W 47" Rear Projection...
Samsung Rear Projection SP43W6HFX- Smoke + Blurred Vision
Convergence IC's are busted.....google it. You'll find loads of solutions!
Nov 02, 2008 | Samsung HC-P4752W 47" Rear Projection...
Line at top of screen
There are problems in the vertical blanking or scanning circuits. This is not something you can fix yourself at home. It involves troubleshooting the deflection amplifiers and scan generator areas to locate the defective components.
You will have to give the set out for service. I would suggest to get an estimate before proceeding. This type of repair can be costly for the labor to find the fault. If it is only generic type parts involved, the parts themselves will not be too expensive.
Jerry G .
Jul 09, 2008 | Samsung HC-P4752W 47" Rear Projection...
Double vision
My television is a hc-p4752w and the color convergence is way off. The red and green are not together and curl away from the top of the screen and bottom too. I tried to auto focus with only making the color separation worse. The tv is about four years old with lots of play time...
I am a aircraft mechanic with some electronics training so I don't mind replacing components I just don't know where to start and have no troubleshooting manual for help. Any help would be greatly appreciated!!!!
Jun 28, 2008 | Samsung HC-P4752W 47" Rear Projection...
Samsung HC-P4752W 47in", is showing double picture
your Convergence ICs need to be replaced you will need two STK392-010 ICs you can get replacements at the following link, and they provide free instalation instructions with pics so you can do the repair yourself and save about 400 dollars. They also have free online instant messageing while you do the repair in case you need additional help when doing the repair. Heres the link.
http://servicemanuals.vstore.ca/
May 21, 2008 | Televison & Video
Junk
The only number that I have is this 800 number for support.
800-726-7864 . Watertown N.Y. Its been ages since I have heard that. I am from Potsdam in St.lawerence county origionally. You are probably going to be better off diagnosing and repairing the set on your own. how is your troubleshooting skills. Let me know if youd like a link for the service manual and some support to try and diagnose that set.
Mar 18, 2008 | Samsung HC-P4752W 47" Rear Projection...
Samsung hc-p4752w
Sounds like convergence amp ic's
i dont have any part number for that model.
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Mar 14, 2008 | Samsung HC-P4752W 47" Rear Projection...
Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television Logo
113 people viewed this question
Henry  Thomas
Henry Thomas
