Question about Acer Computers & Internet
I need a replacement dvd drive ribbon cable for an Acer Veriton L460. This is the ribbon cable that connects the internal dvd drive to the motherboard. the current one got pinched when ram was added. Unable to locate one anywhere on the internet. Can anyone help?
  • 96 Answers
You can go to almost any office supply store and they should have some kind of selection for 'ide' cables. they are relatively cheap as well.
Posted on Nov 28, 2008
  • 341 Answers or Best Buy. 40 pin ribbon cable right?
Acer pc model veriton l460 fuse , not start up
Describe your problem in more detail so someone can offer diagnostics.
May 31, 2014 | Acer Computers & Internet
Acer veriton l460 not power upp
please follow the following steps
1) Cross check the power cable
2) Cross check the power adapter
3) Cross check the power supply
May 31, 2014 | Computers & Internet
Change the hard drive
Open the case. Remove the drive. Replace drive and attach cables. Close case.
Nov 10, 2012 | Acer Veriton L460-UD4501P Core 2 Duo E4500...
Why does only 1 memory slot works?
It sounds like you might have a faulty Ram stick. Have you tried switching out the sticks and see if one of them is faulty? Please let me know if you find a solution..
Nov 08, 2011 | Acer Veriton L460-UD4501P Core 2 Duo E4500...
Hi, can i install a 720 GB internal hard disk for my acer veriton? my present configuration are windows 7 pro,32 bit 160 GB HDD. thanks in advance.
I found a pdf manual here and it shows that this computer does not have SATA ports, but does have 2 IDE ports, so if it's an IDE hard drive you want to install then you should be able to. However, your 2nd IDE port is likely used by a cd/dvd rom drive, so unless you are replacing the hard drive rather than adding one, you would need to remove the disc drive. There are very affordable external usb disc drives available.
Aug 23, 2011 | Acer Veriton 7200D PC Desktop
Functionality of dvd drive in acer veriton andthe need for drivers for using this hardware
what type of dvd drive do you have on the acer,if its an lite on combo then they wont accept some types of cd or dvd discs,i had the same problem, and ended up buying an other dvd drive.
Aug 18, 2010 | Acer Veriton 3600 (V3600GT00150) PC...
Windows 7 Pro upgrade on a Acer L460-ED5200C originally running Vista Bus. goes to the last step - restoreing applications etc. and freezes. What can we do??
You need to run the 'Windows 7 upgrade advisor' from Microsoft.
This will run all your components and programs against the requirements of Windows 7, whether it be W7 Basic or W7 Business.
Once completed it will list any problems you may face when installing or upgrading to Windows 7.
Here's the link to the Upgrade Advisor.
Feb 03, 2010 | Acer Veriton L460-UD4501P Core 2 Duo E4500...
Dvd writer will not read any disc can i replace the internal cd/dvd writer with any other
Yes, you can replace your DVD writer with any other model, but there are 2 types, SATA and IDE.
The IDE drives connect with a wide , flat ribbon connector, and the newer, SATA drives take a smaller cable.
They are easy to swap out, and are basically plug and play!
Oct 24, 2009 | Acer Computers & Internet
Installing an internal dvd/cdwriter
Take apart computer
Look at the cable connecting the existing dvd/cdwriter in your computer, and follow the ribbon until you see a similar looking cable
Consult the PC manual to find out the # of pins you need to change and their position
Connect the new internal drive to the second ribbon
Reassemble your computer
Best to consult your product manuals for the PC, your BIOS, and the internal CD/dvd writer, and/or a techy-geeky friend.
Sep 04, 2008 | Televison & Video
Computers & Internet Logo
109 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
