Question about Coby DVD-224 DVD Player
I put in dvd but it won't play it just goes around inside the pla
What do i do my dvd player will not play my dvds?
  • chip83 Jan 03, 2009
    I have the same problem, my dvd player does not play some dvds, there is nothing wrong with the dvds, they play very good in my computer, probably the dvd player is not working. Please tell me what to do, do I need a new dvd player? The one I got is new.
    Novelist:
  • 152 Answers
Blandenah, As long as you have the cover off of Coby224 please check the elecrolytic capacitors on the power supply board screwed down right next to the Disc Transport mechanism.
Make sure they don't have any swelling of the aluminium can housing. please get back to me on this item if you spot any expanded tops on the filter capacitors. Possibly you could get a
friend with DC voltmeter to check for the three dc voltages unit requires.. +5v for logic +12v -12v for Mechanical things like motors and analog electronics and sensors. If someone checks the voltages, they better be very careful!!!! It is a line operated
switch-mode supply and voltages on the line side could be as high as 200volts DC not to mention the input line being 120vac. It could possibly kill you!! But that's worst-case scenario. Good luck. Please notify me of results of your investigation lmistyrel@aim.com
Posted on Dec 03, 2008
    Sergeant:
  • 217 Answers
First check you any other disc in the dvd player.then also try the same dvd disc in any other player.then confirm exactly the problem.if its the dvd player that is having the problem then it must be because of faulty lens just follow this instructions. Step1Make sure the laser pickup lens is actually the problem. There are a wide variety of reasons that a DVD player might not read a disc efficiently. The disc could be scratched or dirty, for example. Test the DVD player with a disc that you know works before trying to clean the lens. Step2Purchase or borrow a lens cleaner disc and try it first. You can find these things really cheap at any large department store. They usually get the job done well. However, you may need to clean the lens manually if the store-bought cleaner fails. Step3Remove the outer casing of the DVD player. Remove the screws that mount the top casing onto the bottom of the DVD player and slide the top casing off. This will expose the DVD deck, which houses the laser pickup lens. Step4Find the lens. The lens will be glass and under the DVD clamp. The lens will probably have a blue tint to it. If you are having trouble finding the lens, you could shine a light on the components and watch for the reflection. Step5Use a cotton swab and some isopropyl alcohol to gently wipe the lens. Just a quick scrub will do. Dry the laser pickup lens with the other end of the swab. Step6Give the lens a few seconds to dry and replace the covering of the DVD player. Test the efficiency of the player. If necessary, repeat the process.
http://www.ehow.com/Search.aspx?s=How+do+I+clean+the+lens+of+a++dvd+player%3F&Options=0
Posted on Nov 29, 2008
Pioneer dv320-k = no longer region free??
You maybe able to get a region free code for your player from these WEB sites.
REGION FREE CODES FOR DVD & BLU-RAY
www.dvdexploder.com/ www.videohelp.com/dvdhacks www.download-info.com/dvd/index_new.htm
Feb 24, 2013 | Pioneer DV320K Multiregion DVD Player PAL
My dvd gaves me a bad disc
when you play nothing but bootlegs in a dvd player, they tend to burn out the eye inside the player to where it will only read bootlegs. the original movies capabilities won't work anymore. hope this is a help to you my friend.
Jun 21, 2012 | Cyberhome CH-DVD 300 DVD Player
My toshiba BDXK100 won't play DVDs other than Blu-Ray
There may be a issue with the assembly, blu-ray plays with more precision and speed, for some reason it is not slowing down to play the regular DVD's may be a padder motor problem.
Mar 19, 2012 | Toshiba BDX2000 Blu-Ray Player
Samsung htz310 reads NO DISC
probebly a bad laser. sometimes they will play music but not dvds or even the other way around. from what iv read this is happening to people in just a few weeks.
Nov 19, 2011 | Televison & Video
We have two Pioneer DVD V7400s that won't play DVDs. They can, however, play CDs. Bad laser?
Hi, My guess is that the DVDs are not compatible with the DVD player. They must be windows compatible. WMA or WMV (MP4 format) or (avi) Make sure the your DVD player is indeed a DVD player and not a CD player. Good luck.
Jul 26, 2011 | Televison & Video
Just bought an ONN dvd player and will not play burnt dvds. It says it will play DVD-R/RW. Any ideas to why it won't?
Burn your dvds in a proper way. If you burn your dvds as data dvd, it may not work on certain dvd players. Try different software or different PC to burn your dvds. Check the region code of your dvd player & the dvds burnt. They should match. You may find some region-free players.
sonsunny
Jun 19, 2011 | Televison & Video
It won't play some dvd's
sometimes some dvds have tiny scratches that we dont see and if that is case no dvd player will play them I bought a new Bolt dvd and discovered the dvd loose inside and it had tiny scratches where it had moved around inside the box
Oct 01, 2009 | Samsung DVD-R135
Ar 230 will not play most recorded disks that played used to pla
My Cyberhome DVD 300 usede to work fine. I rarely used it since I bought it a Wal-Mart less than six months ago. Lost my manual and codes so I don't know how to solve this problem. A red light is showing with a DVD stuck inside the player. Any ideas??
Jul 20, 2009 | Gateway AR-230 DVD Recorder
I have a dell dimension 2400 series, now i find i cannot play dvds on it i get a note up 2 to say "windows media player cannot play dvd compatible dvd decoder not fitted " what can i do to...
are you trying to play DVDs from a different region ?
PC DVD Drives, are region set to the computer, if you have a region 1 dvd drive, trying to play region 2 dvds et,c. it won,t let you. theres a couple of ways around this. go to Afterdawn ( on the web ) and download a region free dvd device.
Solution 2. try to obtain any updates or re-install windows media player. suggest player version 9 or above.
Mike @ compurepair.
p.s finally is to check that your drive, indeed supports DVD Or certain types of dvd media. i.e DVD+ Or DVD- some only support One type.
Apr 03, 2008 | Televison & Video
Coby DVD-224 DVD Player Logo
163 people viewed this question
Top Coby Televison & Video Experts
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
