Televison & Video Logo
Posted on Jun 02, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to know what size are the screws for the tv stand for a lg60ps11 there are 7 screw holes on the back of the tv that the stand attaches to and I lost mine
Anonymous
Level 3:
Top Expert:
  • LG Master 14,553 Answers
  • Posted on Jun 02, 2012
Anonymous
LG Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2715667
Points
48227
I found the owner manual online but of course it does not have the info you want.
Suggestion is to call LG customer service to see if they will help you.
5 Related Answers
Anonymous
  • 298 Answers
  • Posted on Mar 07, 2008
SOURCE: Polaroid TV
You are correct. Polaroid does not make the screws available. You will have to obtain locally, per Polaroid.
Steven
  • 15 Answers
  • Posted on Sep 06, 2008
SOURCE: tv stand screws
Check the kitchen drawer next to the fridge for the screws !!
When you get new screws, use lengths 1/2".. any longer and you might hit something inside.
Don't know why this is posted under IS-LCDTV26.. I would pull a screw from my 26" and measure it, but it's most likely different than your 42"
Anonymous
  • 6 Answers
  • Posted on Mar 31, 2009
SOURCE: Lost screws for stand on Vizio VU42L
If you pay for shipping I will send you my screws. Maybe a buck or two will cover it in an envelope. I just removed them last night as the TV is being junked for the parts. Email me.
MBSimonds AT aol DOT com
B52Tony
Tony Nguyen
  • 96 Answers
  • Posted on Jun 18, 2009
SOURCE: what size screw for holes on back of set
go to this size to figure out the screw size. http://www.tvwallmountguide.net/
Anonymous
  • Posted on Jun 19, 2009
SOURCE: Insignia TV stand screws
Had same problem with Insignia TV...#12 - 24 x 1/2" machine screws...found at Home Depot in bagged items (can't use longer because some of the holes don't go all the way thru)
Got this stand as recommended by tv company. Got the stand together but Need something else to attach it to back if tv. Help????
The TV must have come with some brackets or screws that you need to screw at the four silver screw holes then attach the TV to the stand.
How to remove Stand from Sharp LC 46D64U TV
Should be 4 screws that hold the stand into place. There is usually either a difference in the screws or some other identifier at the screw hole that differentiate from the other screws.
2helpful
TV Stand Screws
If you still have the manual or know the manufacturer you might want to try giving them a call. They'll know what size screw was used on that model tv stand. Otherwise, measure the insides of the holes and go to a hardware store; they should be able to help you find the right one. Just make sure they are not too long. Screws are pretty cheap, so I'd suggest buying one of a couple different sizes to try out. They should fit snugly in the hole, but should not split the wood/plastic. You'll want to get four of the same size washers and nuts as well once you know what kind of screw you need. That way they won't loosen. :)
1helpful
What size screws are needed to attach bracket to tv
The stand comes with several different size screws, Did you not get the screws that came with the bracket?
2answers
Need screws for my television stand mount
Had same problem with Insignia TV--may be same size...#12 - 24 x 1/2" machine screws...found at Home Depot in bagged items (can't use longer because some of the holes don't go all the way thru)
29helpful
3answers
What is the screw hole size in back of tv
The screw holes are metric. The set is supplied with M5x25 screws to attach the pedestal, so the wall mount screws will be in that same range.
PROTRON STAND
Is that a problem? Check the hole size and choose a screw with a head that is bigger than the hole size. Typically select a minimum of 4mm diameter screw.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
