Question about GE JES1142SJ Microwave Oven
Power went out on microwave.
No power microwave seamed to heve a serge though it was not being used.
  • 2 more comments
  • sandyward Nov 30, 2008
    It just power, no lights, no sounds..dead. I checked the breaker box, cord, everything's OK. It just died and it's not even 2 years old. What a piece of ****!
  • sandyward Dec 02, 2008
    It's a GE JES1142SF...which looks like the exact same thing they now refer to as a JES1142SJ.
  • mstrazze Dec 26, 2008
    Fuse keeps blowing on GE microwave JES1142SJ. We replaced the fuse 3 times in the last 2 days!
  • William Miller
    William Miller May 11, 2010
    Please reply back with your brand and model number so we can help you.
I had the same problem. This was the fix. 1.remove the three security star screws(star with hole in center). 2. using voltage meter or voltage sensor check for power coming from plug through fuse and then the red wire(there's only one) coming from the fuse board that goes to the top of the oven to that round black thing(flame sensor).3. check for continuity of the sensor to make sure sensor has not tripped (if no continuity then sensor was tripped and needs replacing).4. on mine the sensor was fine but I noticed that the voltage was not passing through. The problem was at the connectors. I noticed that the connector was loose and had some signs of arcing. I cleaned and properly connected( this is key because on mine the connector did not pass between the tension loops on the connector). This worked for mine and I hope this works for you.
Posted on Aug 11, 2009
My microwave does not have any power. The electric outlet works, so I am wondering if there is a reset button somewhere. Model number: WP1000AP30-3. Serial number is FMD0210400437. Thank you.
If you have checked plug fuse there is an internal fuse but you have to remove cover to find it.if you do remove cover "MAKE SURE THAT IT IS UNPLUGGED" AS IT CAN KILL YOU"??????????????
Oct 21, 2017 | In Microwave Ovens
Think my fuse blowed
Generally, Microwave ovens have a glass fuse on the main filter board inside the microwave itself. Attempting to replace this yourself (opening the microwave covers) is not advisable. There are several components inside a microwave oven that run at 2000-3000 volts and though it is unlikely, there is a chance the capacitor on the high voltage side is still charged and presents a LETHAL hazard. A repair of this nature should be referred to a qualified technician.
Sep 05, 2013 | Magic Chef MCD1311ST Microwave Oven
We heard a "buzzing" sound and it stopped when I
I had a similar problem. Everyone said must be the magnatron or the fuse ....turned out to be a burned out (visually melted) thermal cut out switch ($12) on the top side of the microwave. Had to get down inside the top of the microwave. The cut out switch was tucked away right up against the the microwave box. Hard to diagnose your problem without looking at the unit in question though, could be several different things. However, my philosophy when it comes to repairs...start with the cheap stuff first!
Jan 10, 2011 | Frigidaire FMV145K Microwave Oven
We lost our electrical power, when it came back on, the electrical panel (clock).. began blinking. The clock re-set with no problem. But, now the microwave won't work. I simply get a message that says...
Sorry to read about your problem, I hope this helps you out.
Anytime the power comes back on, their is a serge of power and things get blown up.
in the future, when you know you have a power outage.. turn off your main breakers,, then after the power comes on, then turn your power, you will not get the serge.
now go to you oven breaker and reset both switches, and see if your door lock corrects.
If you still cant get the microwave working, i have to give you this warning, and only say you have a defective control board.
Microwaves must be serviced by technicians due to the inherent dangers involved in repairing these appliances. Internal capacitors can retain a lethal electrical charge even though the unit is completely unplugged. A microwave radiation leakage test must be performed on the unit following any internal component repair.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 04, 2011 | KitchenAid Microwave Ovens
Went to warm up a food item and after 3 seconds the microwave shut off like the circuit breaker tripped. time face went blank, light inside does not light up and stove top lights do not light. circuit...
You have a fuse behind the screen panel. You have screws inside the microwave holding the panel. you have 1-2 at the bottom. You may also have to remove the vent. It has 2-3 screws which will be inside the vent. These can be removed from the front. Once these are removed the panel will pop off and you will see the fuse The fuse can be bought at a radio shack. BE SURE TO UNPLUG THE MICROWAVE! Good Luck
Dec 04, 2010 | GE JVM1631 Microwave Oven
Went to use microwave and it just went dead. Household power is fine and breakers are good. Replaced main fuse behind switch panel and got power back for clock etc.. When I went to run it again, it went...
short circuit in high tension power supply
Apr 26, 2010 | Maytag MMV5100A Microwave Oven
Unit lost power
there is an internal ceramic (white) fuse in the microwave just under the cover on the right side
May 04, 2009 | Microwave Ovens
Oven will not work; has no power due to power serge from local utility. Is there a fuse inside the oven? GE repair men says bring in to shop;the manual says laymen should not atempt repair, but the cost of...
hi my name is mark, most microwaves have fuses in them. if you are comfortable taking things apart you can fix it. you will need hand tools, a meter to check the fuse. radio shack sells inexpenive ones. unplug the microwave when you disassemble oven. first make sure the circuit breaker to the oven is not tripped. hope this helps. thank for your question.
Mar 16, 2009 | GE JES1290SK 1.2 Cu. Ft. Countertop...
Microwave door shattered
Give is the entire model # on the sticker inside the microwave and I should be able to help.
Oct 20, 2007 | Neff H7871N2GB Convection / Microwave Oven
GE JES1142SJ Microwave Oven Logo
785 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
