ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000 Default 6 Digit Security code: 123456 or 000000
IF Problem not Solved So Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator Enter The Puk code and Yes Enter The pin code and Yes So Puk code Open and Problem will Quickly Solved
Type *#06# at the mobile screen to know IMEI no of your mobile. send the IMEI no to me and i will reply you with unlocking code. IF Problem not Solved So Please New Software install in the Phone Problem will Solved
IF you put PUK code many times depending on the model it wil lock the sim card. This is because to prevent unathorised person using your SIM card.
Default PIN code for nokia mobile is 0000
PUK code will be given by the service provider only.
Please call your service provider or go to service provider office,they will assist you in this issue.And they will have a security check like name,Phone number and other information to check weather the SIM card belongs to you only.Then they will assit you.
Only the sim is blocked, not the phone. The unblocking code is located
on the sim casing when you bought it. It will ask you to enter the code
and new PIN code 2 times but will completely block it if the limited
number of attempts is reached. You can just simply replace the sim and
the phone will work again normally.
SIM pin code: This is a pin code that locks the sim card until you enter the correct code. This protects your account, even if your sim is put into another handset. To reset it, you need the PUK code: Pin Unlock Code (PUK) If you miss key (or forget) your SIM pin code, and enter the wrong one 3-5 times in a row, the SIM will lock up, and you’ll need to enter the PUK unlock code to release it. You should ask your Network Service Provider for this code when you need it. Don’t try to guess it, because after a few wrong guesses, the SIM card will be permanently disabled. Phone Security Code: This locks the handset, as opposed to the sim card. You can also set some handsets to only accept a “new” sim if the phone security code is entered. To reset it, you need the Master code code: Master Reset Code
Sometimes known as the Master Code, this allows you to unlock a handset if you have entered the Security Code wrongly too many times. Which is the one that you want? The default security code for Nokia is 12345
SIM pin code: This is a pin code that locks the sim card until you enter the correct code. This protects your account, even if your sim is put into another handset. To reset it, you need the PUK code: Pin Unlock Code (PUK) If you miss key (or forget) your SIM pin code, and enter the wrong one 3-5 times in a row, the SIM will lock up, and you’ll need to enter the PUK unlock code to release it. You should ask your Network Service Provider for this code when you need it. Don’t try to guess it, because after a few wrong guesses, the SIM card will be permanently disabled. Phone Security Code: This locks the handset, as opposed to the sim card. You can also set some handsets to only accept a “new” sim if the phone security code is entered. To reset it, you need the Master code code: Master Reset Code Sometimes known as the Master Code, this allows you to unlock a handset if you have entered the Security Code wrongly too many times. Which is the one that you want? The default security code for Nokia is 12345
