Question about GPX MW6815DT MP3 Player
SD card issues.
My player doesn't seem to want to cooperate with my 2GB SD card. It puts songs on my 128 MB card, but not on my 2GB. What's the problem?
I had a similiar problem with my laptop. All I had to do was to update the drivers and now it works fine (it would not even recognize the card before). Hope this helps.
Posted on Nov 21, 2007
SOURCE:
Camera says new sd card is full
put it in a computer and see what it reads,it might need formatting .
Jan 25, 2018 | Kodak EasyShare C330 Digital Camera
My coolpix 3200 will not accept a SD card. it rejected the 128 mb card and I replaced it with a 4g card that it doesn't like either. It also will not allow me to format any SD cards
The 3200 works with SD cards. Your 4GB cards is actually an SDHC card, which is electronically incompatible. You need to use SD cards, 2GB and smaller.
Oct 21, 2010 | Nikon Coolpix 3200 Digital Camera
Where can I get a memorty card SD 128 MB for my Kodak Easy Share C 743? Can I also use a larger memory card such as 2 GB or 4 Mb? A. N. sparklersconc@yahoo.com
You can use SD cards up to 2GB in size. You cannot use SDHC cards bigger than 2GB. You should be able to get SD cards at any office supply or electronics store. You could probably even find them in most supermarkets and drug stores, though they might cost a little more.
Mar 08, 2010 | Kodak EasyShare C743 Digital Camera
I have intel 845 glly desktop board with 256 mb SDR. When I added 128 mb SDR in the second slot it is not recognising it. How to add 128 mb SDR with 256 mb SDR. When I fix 128 mb ram in first slot and...
1st try to exchange the cards in the slot.
2nd try another card
3rd ur RAM slot may not be ok
4th ur RAMs may not be compatible
5th ur new RAM card may not be ok
use same type of RAMs, and same size...
if u have 256, add 256
if u ahve 128 add 128
if u have SDR then dont add DDR
getting compatibility is little difficult...
some times no combinations can work...
note...technology keeps changing...so a old RAM card that was bought years ago may not be compatible with a new RAM card....
even i got all my old RAM cards(256+128) removed and got 2 - 512mb of the same type fixed...even i had issues with my RAMs for 6 months...
Dec 27, 2009 | Intel D845GLLY Motherboard
What kind of memory SD card would work for Panasonic DVD Recorder DMR-ES46V? I was hoping to put in a 8 gig memory card but those are all SDHC. Will those cards work in this unit?
This info is straight from the panasonic website. The owners manual and more info for the unit can be found here.
Hope his helps!
Suitable SD Memory Cards
8 MB, 16 MB, 32 MB, 64 MB, 128 MB,
256 MB, 512 MB, 1 GB, 2 GB (Maximum)
Mar 16, 2009 | Panasonic DMR-ES46VS DVD Recorder/VCR
Player error when songs on micro sd card are inserted in phone
i could be that the songs are not formatted correctly
Feb 27, 2009 | PNY 2GB microSD Memory Card
Nikon Coolpix 4600: Problem: It won't take any photos, it reads: THIS CARD CANNOT BE USED. The card is 128 MB. I purchased a new card: 2GB but it won't work also. My manual says to clean the contacts...
1) Have you formatted the cards?
2) Try the cards in the card reader in your computer to see if they can be read.
3) Try the "switch off camera - remove and replace battery - switch on camera" trick with the original 128 Mb card in place. This will reset the camera's memory.
4) Note the type of card is important - not all cards can be used in a camera (especially some of the latest bigger ones) - check the type of cards supported by your camera.
I found this at the Nikon USA site (note that the 2 GB card is not listed - as said "Cards are not all the same" and use different drivers to operate them):
Question Which Secure Digital Cards are approved for use in the Coolpix 4600/5600? trnsp.gif Answer The Nikon Quality Department has tested the following cards and approved their use in the Coolpix 4600/5600:
SD memory cards:
SanDisk 16 MB, 32 MB, 64 MB, 128 MB, 256 MB, 256 MB*, 512 MB, 512MB*, 1 GB
Panasonic 16 MB, 32 MB, 64 MB, 128 MB, 256 MB*, 512 MB*,1 GB
Toshiba 16 MB, 32 MB, 64 MB, 128 MB, 128 MB*, 256 MB, 256 MB*, 512 MB
*High speed type of 10 MB/s or over
Other brands and capacities of cards may work, but Nikon cannot guarantee their operation. Check with the manufacturer of the third-
party card for compatibility information. Nikon recommends keeping one of the approved cards available for troubleshooting.
May 07, 2008 | Nikon Coolpix 4600 Digital Camera
Incompatiblity of R300 & Toshiba 2 GB SD Memory Card
Epson Printers & All-In-Ones:
MEMORY CARD TYPE MAXIMUM CAPACITY TESTED Compact Flash 4 GB Secure Digital 1 GB Sony Memory Stick 1 GB MagicGate Memory Stick 128 MB xD Picture Card 512 MB Smart Media 128 MB
These are the Epson tested memory cards that will work, also includes the suported memo capacity..
Hope this is helpful, pls dont forget to rate solution.
Apr 08, 2008 | Epson Stylus Photo R300 InkJet Printer
TEAC MP-360-2GB
Does all your 310 files are in root directory? If yes, then this is the problem caouse in specification is written that in root directory have to be no more than 256 files.Try to create sub directories and place files there, anyway when you start the player they are shown on screen continuously, this means that you don't have to navigate trough directories.
Nov 30, 2006 | Teac MP-111 MP3 Player
AAC Files Transfer
Yes look in the net to get a mp3 converter toacc then just drag those files you converted to your SD card it will work. search google mp3 to acc.
Jul 19, 2006 | Panasonic E-Wear SD SV-SW20 (128 MB) MP3...
GPX MW6815DT MP3 Player Logo
77 people viewed this question
Top GPX Audio Players & Recorders Experts
Joe Negus
Joe Negus
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
