Question about Philips 32PT6441/37 32" TV
Horizontal lines across the top 3 inches of picture
My television, purchased about two years ago has recently developed white lines (sometimes colored) that run along the top three inches of the picture. They can distort words that appear at the top of the screen, but usually don't interfere with picture. What is causing this? Is it repairable?
  • 1 more comment
  • princessskye Nov 28, 2008
    There are a series of small lines that started with one going directly across the top of the screen. Additional lines have since appeared.
  • Anonymous Dec 23, 2008
    Likha,
    I do thank you for the help..Do you really think this will also repair my problem... I have already had the circuit board replaced..
    Thanks,
    Ron
  • google_998 Mar 02, 2009
    Along with the white lines on the top part of my TV screen, I am also facing audio & video disruption problems. Are these two problems connected? My TV model no. is Philips 27PT6441/27 27"
  • 790 Answers
Hi
what line started? from Left to right? or from top to bottom?
Thanks!
Posted on Nov 28, 2008
  • carlos fernandez Jr.
    carlos fernandez Jr. Dec 01, 2008
    Hi
    you have defective vertical circuit section! this problem needs to replace the filter capacitor that is 100uf 35v. or change the 10uf 50v.
    Thanks!~
I have a Samsung 50 inch 3D Plasma TV (model number PN50C7000YF) that has recently started developing black horizontal lines across the top of the screen all in a 3 inch horizontal area. Every week I get...
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 15, 2014 | Samsung PN50C7000YFXZA PN50C7000 3D Plasma...
Horizontal white lines across top problems of my television.
This is probably bad/leaky capacitors in the vertical circuit, around the vertical IC, or the power supply that feeds the vertical. Sometimes you can see domed/ bulged caps or what looks like liquid on the circuit board around the leaky ones. The legs on some caps can even corrode to the point the leg is missing. Care must be taken when replacing them because the acid from the caps can eat away foil traces on the circuit board. All acid must be cleaned off board to prevent further corrosion of parts
Sep 01, 2009 | JVC AV-32850 TV
Horizontal white lines across top of TV screen
Vertical hold circuit is failing.
Check capicitor in vertical hold circuit. You should have solid knowledge of electronics repair before attemping repair. TV's can emmit harmful radiation, and produce voltages up to or in excess of 30kV.
Oct 07, 2008 | Televison & Video
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
White horizontal lines at top of picture
Yes, definitely worth fixing. The problem lies in the vertical deflection voltage-doubler circuit. The usual fault is a single capacitor of 100uF/35V that has failed. It is normally connected to a rectifier diode right at the vertical IC. Replacing the capacitor (no more than USD4.00 in price) usually gets it working perfectly again. If you are finicky around technical work, then a reputable local repair shop in your locality should do it quickly for you and charge only labour.
Jan 17, 2008 | Toshiba MD24FP1 24 in. TV/DVD Combo
Screen white line problem.
There are two capacitors in the vertival output circuit that need replaced
Oct 19, 2007 | Toshiba MW27FN1 27 in. TV/VCR/DVD Combo
Horizontal Lines in picture
CHECK C2P08 100 UFD 16 V OFF PIN 3 OF IC2P03 (3.2 VOLT REGULATOR) ON THE SIGNAL PCB. HOPE THIS HELPS!
Jan 12, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Picture deterioration
Your whole problem my freind is dryed up capacitors. You should go, if you have the technical ability to replace these capacitors, to http://servicemanuals.net, download the schematic diagram, and start replacing the waveshaper capacitors in the vertical drive circuit.
Sep 23, 2006 | Sony KV-35V35 TV
Philips 32PT6441/37 32" TV Logo
448 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
