F61 in AK 600
I have an f61 problem..
Can you know how I fix that..
loyola53@gmail.com
  • 4,234 Answers
There are a couple of possibilities:
1) The output amp-pac has failed and nneds to be replaced.
2) The power regulator pac is bad and nneds to be replaced.
Either option is somewhat expensive. Unfortunately without seeing the actual machine and taking measurements inside, there is no way for me to be sure what option fits here. I would take this to an authorized Panasonic repair center and have it repaired there. Expect a parts cost in the $50-$75 range.
Dan
Posted on Dec 03, 2008
F61 Error on SA-HT930 Panasonic
As sugested by many experts.I replaced the ic no rsn311w 64d,still the error code f61 appears.Now where is the fault.?
this is for the Panasonic sa-ht 880.
Aug 28, 2012 | Panasonic sa-ht930 Home Theater Audio...
MY MUSIC SYSTEM PANASONIC AK88 THIS SYSTEM ERROR IS F61 PLEASE DIOGRAM OF REPAIR IN MY SYSTEM
As far as the fan is concerned, please reject it as ak-88 is not equipped with 1. the f61 is the errror code for blown power supply ic, you have to get it changed.I have the same system and 2 times i had the same problem. IC is stk 470 0405_28_2012_9_55_21_am.jpg
Feb 27, 2012 | Audio Players & Recorders
Stereo system technics sc-dv150 showing fault f61 how do i
f61 is a bad voltage code. I will probably need an output ic or a voltage ic.
Oct 15, 2009 | Audio Players & Recorders
DISPLAY STARTS OK THEN F61 APPEARS THEN STEREO SWITCHES OFF
Probaby needs the output ic. F61 is an output/power error code. But check that the fans turn before trying to replace or taking it in to be fixed. If a fan is not turning you will get F61 too.
Feb 21, 2009 | Panasonic SC-HT441 Theater System
F61 error
The F61 error indicates that the unit is in "protect" mode. This means that an error condition was detected in the amp section and the unit has shutdown. This is usually caused by a defective amp chip. Expect a parts cost in the range of $60-$90.
Dan
Dec 05, 2008 | Panasonic SC-AK17 Shelf System
Panasonic SA VK550 - F61 eror
Hi, i had the same problem with a panasonic player, when you see the code F61 in the screen it is because the audio output IC is defective,change that and the set will work perfectly. hope it work.
Feb 05, 2008 | Panasonic SC-AK33 CD Shelf System
CODE F61
F61 tells you its a power source problem according to the manual. to all F61 error it is very likley that the str470-050a reg legs desolderd and have broken away from the main body of the regulator giving you the f61 and shut down.
Jan 12, 2006 | Technics SCEH790 CD Shelf System
109 people viewed this question
 Grubhead
Grubhead
