Question about Pass & Seymour 663LASLGCC SWITCH QUIET 3WAY LID LA
7810p lid switch
How do I close the lid and keep the computer on(HP 7810p)
  • 35 Answers
Go into display properties and then screen saver and power settings and there should be a setting for what you want it to do when you close the lid
Posted on Dec 01, 2008
My hp pavilion dv7 keeps running after the lid is closed
Change the settings in the Power section to shut-down when lid is closed. Power Settings, Advanced Settings, Change setting to shut-down when lid is closed.
Oct 29, 2012 | HP Pavillion Dv7-6165us 17.3" Amd...
Cover on/off switch a problem..... shuts off when moved, difficult to keep " on ".
go to control panel then go to power options then go to advance options then click on the "when i close lid of my portable computer" and select do nothing, ok done
Sep 17, 2010 | HP Compaq Presario CQ50-110US Laptop
Hp Photosmart c4180 - Keeps saying "remove cartridge on the right" I have removed and replaced with new cartridge however the problem persists please help.
Pick up the printer. Carry it outside. Lift the lid on your trash can. Gently place printer in trash can. Close lid. Wait until garbage day. Open trash can lid........problem solved. Reminder.. never buy HP again.
May 20, 2010 | HP PhotoSmart C4180 All-in-One Color...
HP Elitebook 2530p power lights stays on after
are you switching off, or just closing the lid? On most laptops, closing the lid just hibernates and constantly uses power, it can be changed in the control panel power options.
Mar 26, 2010 | HP EliteBook 2530p Notebook
Hp deskjet printer 6840 wont print .keeps on saying top cover is open when it is actually closed.
Pop off the right side cover - it is just held with clips. At the hinge, you will see that the cover switch arm that is supposed to move up and down as the cover opens & closes (in the slot in the geared hinge) is probably broken off. It is in the up position when the lid is closed, and down when the lid is open. I cut the shaft of a Q-tip to length and wedged it into the space to keep the cover switch up all of the time and still allow free movement of the lid.
Geezer Geek
May 20, 2009 | HP DeskJet 6840 InkJet Printer
Printer lid open light is coming on when printer lid is closed
The printer lid error can appear if any of the following are true:
- top lid is open
- rear duplexer or flat panel is not installed correctly
- cartridge bay area door is open
All of these conditions are detected by a series of sensors or circuits in the printer design so with regard to the lid and cartridge bad door you need to make sure that nothing has broken off that closes the switch.
I'd lay odds that it's most likey the rear panel/duplex unit. I'd recommend taking this out as per the manuals instructions and then reinserting it, carefully so that it fits in place properly.
Hope that solves your problem.
Martin
May 19, 2009 | HP Officejet Pro K850 InkJet Printer
Computer will not go into STBY or Hibernate when lid is closed
if the option is checked, and it doesn't work, the switch under the screen to base closing needs to be adjusted/replaced. i would double check settings and intallation disk if this does not work.
Jan 27, 2009 | HP Compaq nx6110 PC Laptop
HP color laser 2550L prints only in yellow
Hi Mmgrafde,
Press the Go and Rotate Carousel buttons simultaneously. This will calibrate the printer. See if this works.
Otherwise....Remove all cartridges and drum. Switch off printer. Close the lid. Switch on printer and wait until any churning stops. Insert the drum and close the lid. Wait until any churning stops. Put in one cartridge at a time, closing the lid and wait till it stops churning each time. With the last cartridge put in, it will churning longer (calibrating). Try to print from your computer.
It could also be that the toner could actually have run out for the other colors.
Rgds
S88
Jan 01, 2009 | HP Color LaserJet 2600n Printer
Problem with HP dv6426us(Altec Lansing) speakers.
try and lower the sound on your laptop and than close it. but if it keeps on happening, than try and emailing the company that the laptop is made from.
Jul 29, 2008 | HP Pavilion dv6000z Notebook
Lid switch location??????????
HP DV 5000 LID switch location is here:
If You want test lid switch, just connect A+B together for a monent!
If the monitor flashes on...? Lid switch is faulty.
It is too dificult to change the lid switch, so the easiest way is connect these pins together forever. :))
Dont forget to turn off your notebook... he wont sleep anymore ;))
Greetings from Latvia.
lauris@bttehnologijas.lv
Feb 01, 2008 | HP Compaq Presario V5000T Notebook
Pass & Seymour 663LASLGCC SWITCH QUIET 3WAY LID LA Logo
85 people viewed this question
Top Pass & Seymour Electrical Supplies Experts
ken skalski
Ottoniel
Mike
Are you a Pass & Seymour Electrical Supply Expert? Answer questions, earn points and help others
