Question about Navman GPS
Navman says acquiring gps signal constantly.purchased 9/11/08 and has been working fine until 27/11/08. weather was fine with blue skies. would appreciate your advice. Thanks Jock
  • Anonymous Feb 21, 2009
    Navman s100 has been working fine now stuck acquiring GPS signal. Don't matter what view of the sky it has, it won't find a signal.
  • Andrew Holder
    Andrew Holder May 05, 2009
    I have the same problem with my week old S200.
    Am returning it to NavMan.
waterppk
  • 42 Answers
SOURCE: Navman 510 keeps losing GPS signal too often.
The antenna may be unplugged. You can check by removing the SD card, carefully unscrewing the four screws from the back of the device and then running your fingernail (NOT a screwdriver) around the seam on the case to split the two halves. The antenna is the small panel on the back of the receiver, it plugs into a computer board on the inside of the receiver. Look inside for a gold colored connector, it should be plugged into one of the boards, if it is not then that's your problem, you need to plug it back into the board and you should be in good shape.
Posted on Nov 18, 2007
SOURCE: unable to register newly acquired
unable to register Navman F10 0n www.navman.com.au/register
how can I purchase accessories and maps?
Brenda
5.6.08
Posted on Jun 05, 2008
WhiteRussian
  • 167 Answers
SOURCE: The GPS cannot get satellite
Shut off the Receiver...
Press and hold Page + Menu + Power...
Then select "Yes" to erase all user data...
Leave it on with a clear view of the sky without moving for about 30 minutes to acquire the satellites.
Posted on Nov 28, 2008
  • 156 Answers
SOURCE: navman s35 keeps saying acquiring gps signnal can
Are you in an area that it can pick up the satellite, like outdoors with no trees overhead, etc.? If so, try external antenna if possible.
Posted on Jun 28, 2009
  • 6 Answers
SOURCE: my garmin gps 12 is not acquiring any satellites.
does it have a clear line of site to the sky? Make sure your outside!
Posted on Feb 28, 2011
Why my location is always in chicago IL i'm in hawaii n i'll use in hawaii Also I can get signal at all...... I just purchased from sam's club. help me.
As GPS units are used, data is gathered which helps them acquire satellites quickly at the start of each use. If a device is used daily it should be able to acquire satellites in a minute or less. Using a GPS device while it is outdoors with a clear view of the entire sky is the ideal condition for acquiring satellites. Please know that there can be several different factors that may cause a GPS unit to not acquire satellites:If your unit is trying to acquire satellites for the first time, it may take longer than normal to establish an initial position. If the unit is powered on and outdoors with a clear view of the sky this should not take more than 3-5 minutes.If your unit has not been used for an extended period of time (more than a month), it may take 3-5 minutes to acquire satellites.If your unit is indoors, it may not acquire satellites. Even standing next to a window indoors will block a majority of the sky which is needed for a device to locate and lock onto a satellite signal.If you have just finished updating the software in your unit or you have performed a master reset, your unit may take 3-5 minutes to acquire while outdoors as the data that is used to locate satellites may have been erased.If your unit has traveled over 500 miles while turned off or not tracking your travel, it may take 3-5 minutes to acquire even in ideal conditions.If your vehicle has a protective coating on its windshield or electronic devices which interfere with the unit receiving signal, your unit may need an external antenna* in order to acquire satellites.If you suspect this to be an issue, try taking the unit outside of the vehicle with a clear view of the sky for 3-5 minutes so that the unit can acquire satellites. If your unit loses satellites once moved back into your vehicle you will most likely need an external antenna*.If your unit is still having trouble acquiring satellites, please ensure that it has the latest version of operating software by using our WebUpdater program. Once your unit is updated please allow the unit to acquire satellites outdoors in a stationary position with a clear view of the sky.*Note: Some units may not be compatible with an external antenna. Please check the Compatible Devices tab on the external antenna's page to see if your unit is listed. OR I set up this link that will take you to ensure that it has the latest version of operating software http://www8.garmin.com/products/webupdater/howtoinstall.jsp
Sep 11, 2011 | Garmin nuvi 1490T GPS Receiver
Updated unit and still acquiring satelites is showing, what can i do?
If your unit is still acquiring satellite, then it means the signal strength is weak, try to get it outside where it can be facing the sky directly so it will be able to acquire satellite. Once you just update your gps receiver, it seems like it is brand new and when it wants to first acquire satellite, it might take longer to do so. But if it has access to the sky directly, it should take about 3 to 5 minutes to acquire.
If your unit is indoor, it may not acquire satellite, even if it is close to the window, it will not, but if it is outside, then it will acquire faster.
Check if you have any protective coating on your windshield or electronic devices which interfere with the unit from receiving signal from the satellite. Try to see if your gps receiver can use an antenna, then connect one to it and your gps will acquire satellite.
Try to reset your gps first before trying any other solution for the unit.
Dec 23, 2010 | Garmin StreetPilot C330 GPS Receiver
My garmin approach 3 will not acquire a gps signal. Why?
There are many reasons for a GPS to fail to acquire signals from the satellites. You should be outdoors with a clear sky the first time you attempt to get it to work. If it's worked before, but stopped working, it may be defective. Garmin recommends many thing to do at this link:
https://support.garmin.com/faqSearch/en-US/faq/content/YyCZrQHhuf6PO6qTKdvvr9
Jun 28, 2010 | Garmin Approach G3 Handheld GPS Receiver
GPS wont aquire a satellite
    Hello there and happy new year
    If Your Unit Cannot Acquire Satellite Signals
  1. For your Garmin GPS unit to acquire the satellite signals it needs to function properly, the unit must be taken outside, away from mountains, tall buildings and heavy foliage where it can get a clear view of the sky. Keep the unit stationary for several minutes while the GPS unit acquires the necessary satellite signals.It may take several minutes for the unit to locate a good solid signal
  2. OK
  3. Hope this is very helpful please keep me posted on this ok?
    Best regards Michael
Jan 01, 2010 | Garmin MAP76 handheldS GPS Receiver
While driving Garmin Nuvi 250 constantly loses satellite signal. The screen says that it is aquiring a signal. It is also constantly refiguring the route.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} As GPS units are used, data is gathered which helps them acquire satellites quickly at the start of each use. If a device is used daily it should be able to acquire satellites in a minute or less. Using a GPS device while it is outdoors with a clear view of the entire sky is the ideal condition for acquiring satellites. Please know that there can be several different factors that may cause a GPS unit to not acquire satellites:
  • If your unit is trying to acquire satellites for the first time, it may take longer than normal to establish an initial position. If the unit is powered on and outdoors with a clear view of the sky this should not take more than 3-5 minutes.
  • If your unit has not been used for an extended period of time (more then a month), it may take 3-5 minutes to acquire satellites.
  • If your unit is indoors, it may not acquire satellites. Even standing next to a window indoors will block a majority of the sky which is needed for a device to locate and lock onto a satellite signal.
  • If you have just finished updating the software in your unit or you have performed a master reset, your unit may take 3-5 minutes to acquire while outdoors as the data that is used to locate satellites may have been erased.
  • If your unit has traveled over 500 miles while turned off or not tracking your travel, it may take 3-5 minutes to acquire even in ideal conditions.
  • If your vehicle has a protective coating on its windshield or electronic devices which interfere with the unit receiving signal, your unit may need an external antenna* in order to acquire satellites.
    • If you suspect this to be an issue, try taking the unit outside of the vehicle with a clear view of the sky for 3-5 minutes so that the unit can acquire satellites. If your unit loses satellites once moved back into your vehicle you will most likely need an external antenna*.
Nov 12, 2009 | Garmin nuvi 250 GPS Receiver
The GPS was working then then just out of the blue
THE GPS SATELLITE RECIEVER HAS FAILED, REPALCE THE UNIT OR HAVE IT REPAIRED
Oct 01, 2009 | GPS
We keep loosing contact to the sattelites. Is there a way to reset it, so we get a constant signal?
Mine did the same, and said no gps no fix. I called the factory, now called Northstar, tech said to reset unit, and it worked. Great signal strength. Turn unit on and access menu, access factory settings,hit factory reset. However you will lose all your waypoints.
Jul 04, 2009 | Navman Tracker 5500i GPS Receiver
Garmin NUVI 650 acquiring satellites
  • Make Sure the GPS has a good, clear view of the sky. “Clear” does not need to be sunny. Overcast skies have no noticeable impact on GPS performance. But buildings and trees do. So take the GPS outside where you have the biggest sky view as you can.
  • Next, wait for the GPS to acquire a signal. If this is the first time you have used it, expect it to take up to 20 minutes to find a signal. Most often it will take less, but prepare for 20 minute. Now for an important step… Once it has found your location, let it continue to sit there for about 30 minutes.
Apr 19, 2008 | GPS
Unable to register newly acquired GPS Navman S80 on your address at www.navman.com.au/register
Also unable to regster my s90i which is giving me wrong directions. Wirimu
Apr 11, 2008 | GPS
Navman icn510 gps reciever problem
How long are you waiting and are you moving while it is trying to acquire signal? These receivers are using older circuitry that may take up to 20 minutes to first acquire a signal from a cold start. If you are moving it may take longer!!! The good news is that after you have initially acquired a location, if you turn the unit off it will only take a minute or so to reacquire after it has "warmed" up.
Oct 22, 2007 | Navman ICN510 GPS Receiver
GPS Logo
739 people viewed this question
Top Navman GPS Experts
Martin Murray
Are you a Navman GPS Expert? Answer questions, earn points and help others
