Question about KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher
My Maytag quiet series 300 has no lights and won't start.
Its only a couple years old it would light up the control panel at first and would not start now no lights and it won't start. Could it be a fuse?
  • oranjwoman Feb 23, 2009
    Hi, I have the same problem. I found a site that says to check the wiring to the house. My has smelled like something is burning, so think maybe that is the problem. Another site said it is the control panel. Did you ever get yours fixed? What was the problem. Please respond here.
  • Anonymous Mar 10, 2009
    no power
5 Suggested Answers
  • 3 Answers
SOURCE: Maytag Quiet Series 300
Sounds like a thermal fuse that is a less than $20 part. remove the top 6 screws in the door that hold the plastic front panel on. Behind that is a circuit board and a white flat 1" square fuse with two wires going to it. make sure power is off at breaker. Test with an meter to see if any current is going thru. If not, that is most likely your problem, and just follow the fuse replacement kit instructions carefully, including putting the new wires on the new fuse like they say. Otherwise, the original wires going to the fuse will blow it too.
Should take about 20 minutes.
Posted on Feb 12, 2008
SOURCE: MAYTAG QUIET SERIES 300 DISHWASHER MODEL MDB7600AWW
I had the same problem, my dishwasher needed a new brain. Cost around $150 to fix
Posted on Jun 21, 2008
SOURCE: Maytag Quiet Series 300 Will not
You have the control panel locked.  Hold down the heated dry button for 3 seconds.
Posted on Aug 15, 2008
SOURCE: Maytag quiet series 300
Maytag Quiet Series 300. The lights flash in sequence starting from the outside traveling inward. The timer counts backwards from 50 to 1. Then the sequence starts over. and continues over and over. I'm able to clear it when the time reaches 1 or 2. It stays off for a while (3-4 hours) then starts over. I can not clear the countdown until it reaches 1 or 2. After I clear it the dishwasher will work, but until then, no way. This happens with the door open or closed.
Posted on Sep 19, 2008
  • 409 Answers
SOURCE: Maytag Quiet Series 300 Dishwasher leak
hi there,
the leak may be coming from the door gasket or the door vent.
can you provide me with the complete model # please?
Posted on Sep 23, 2008
Maytag Quiet series broken?
Check the door switch.
May 03, 2013 | Dishwashers
I have a Maytag Quiet Series 300 dishwasher that won't start. There is power going to the unit, but the control planner was not function. please help.
I had no lights on my control panel, eventhough power was good.
I replaced the control panel ($265 part), it worked for 2 weeks, then I now have the same problem.
Frustrated, I am probably going to buy new from a different manufacturer.
Whirlpool/maytag does not warranty electronic parts if you do it yourself.
Dec 18, 2010 | Maytag 24 in. MDB9750AW Dishwasher
I have a maytag dishwasher model # mdbtt70awb quiet series 300 when you push any of the wash cycle buttons nothing works. the only button that lights up is heated dry so there is at least power there....
I had the same issue try hitting delay 1hr and start the 1hr was solid not flashing and an hr later it's running just fine. Think I need a new control panel but for now this is working.
Sep 04, 2010 | Maytag Dishwashers
Maytag Quiet Series 300 - Control Panel doesn't work
Mar 14, 2010 | Maytag 24 in. MDB9750AW Dishwasher
Wont start, no lights on control panel,power is on
1 month old call maytag should have a warranty
Dec 13, 2009 | Dishwashers
1.5 year old Maytag Legacy Series Quiet Series 300 Lock Light on
Hold down the heated-dry button for 3 seconds and the light will clear.
Nov 07, 2009 | Maytag 24 in. MDB9750AW Dishwasher
Maytag Quiet Series 300 Dishwasher will not turn off after it com
MY DISHWASHER KEEPS RUNNING, IT IS A WHIRLPOOL GOLD QUIET PARTNER IV
Apr 05, 2009 | Dishwashers
Sep 15, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher Logo
189 people viewed this question
Top KitchenAid Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
