Question about Braun FlavorSelect KF 180 Coffee Maker
Leaks After seveal years there is a leak from the bottom. My guess is that it's fatal (unrepairable). There seems to be a single screws on the bottom with a strange triangle head to prevent home repairs since neither philips or slot head work. Any ideas?
  • Anonymous Nov 27, 2007
    I have the same leaking problem
  • jlgirton May 11, 2010
    What kind of screwdriver did you use to open up the FlavorSelect? Our's just started leaking recently, and none of our screwdrivers (phillips, flathead, hex) will work to open up the bottom. What did you ultimately do to open it up? Thanks...
Simply drill out the tamper proof screw(tri wing) at the bottom of the coffee maker using a small drill bit first then progressing to a larger bit to get the head off. Once this is done then proceed to unsnap the bottom cover. The whole body of the coffee maker is a snap in design making each part separate from the rest.At the bottom you will notice two connector tubes made out of aluminum. Most likely one or both are corroded. If not serious corrosion exists, tape the holes with aluminum duct tape- two layers will do. If serious, consider buying a new coffeemaker. Usually the rubber ducts are fine; mine were after 10 years of service. If not, you can easily replace these with small sections of radiator hose. Reinstall the coffeemaker and test for leaks. You do not need the screw at the bottom to hold the unit together. It is tight enough.
Posted on Jan 06, 2009
Same problem here. I did get it apart and there are two metal water lines each connected by a rubber fitting that is just slipped on. My guess is that as the rubber connectors get old they start leaking water. I'm going to try putting a small worm clamp on the bottom half of the rubber connectors to see if it stops the leaking.
Posted on Mar 02, 2008
Water leaks out the bottom through through the clutch when filled and running
There are gaskets and shaft seals that can leak. Not an easy task. On my GE washer, I had pinhole leaks near the transmission mounting flange. I used JB Weld epoxy and sheet metal screws to seal the leaks. and of course changed the gasket. That was 8-9years ago. So my investment in time and transmission paid off. A bright light under the clutch and a dark room may show what's leaking. you may be able to temporarily seal with a window caulk from the top or bottom Or a bathtub waterproof sealant. If it's the rubber gasket, a rubberized sealant "may" help. I guess it could also be the pump. I use paper towels tied around things like drain pipes to find leaks, or make sure my work is not leaking.
Mar 12, 2015 | Maytag Centennial MVWC6ESWW 4.0 cu. ft....
99 Altma oil leaking putting oil in and leaks out bottom
The car is 15 years old
What would you like us to guess at?
You can not use it like that
I personally wouldn't put money into a 15 year vehicle
or that model
You know it has to go into a shop
If the motor has to come apart to fix a major leak,
you get rid of it
May 12, 2014 | Cars & Trucks
Front oil seal leak
never guess here.
oil leaks,
no engine stated, nor year, so you wont get good advice.
mines a v6 2.5L
on most suz engines, front leaks can be.
1: top front of valve cover seal. leaks. then gravity does its thing.
2: top cap seal
3: bottom seal
4: pan seal,
5: pump seals.
doing all on a guess. is $$$$$$$$
what we do is clean it all , run for 10 miles, and see what really leaks.
or
use the UV dye kit. and find it.
you have gravity and air currents that form a chaos. there.
so only those 2 work.
Jan 07, 2014 | Suzuki XL7 Cars & Trucks
Water Leaks out of bottom of door
the first thing i would try is to loosen the hing screws couple of turns,push in on the bottom hinge and tighten screws.
Dec 10, 2013 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
My Delta faucet leaks and they don't sell washers for it. Single handle model.
Everything wears out with time. Try going straight to the manufacturer.
May 18, 2013 | Delta Plumbing
I have a moen 7637 single handle kitchen faucet that leaks around the stem. How do I take the lever off.
1) Use a small sharp-pointed knife and pop out the little plastic Moen logo at the bottom of the front side of the handle (and don't lose it!)
2) Lift the lever up a bit (the water may turn on) until you can see a small screw with an allen wrench socket.
3) Unscrew the allen-head screw; the handle will lift straight up.
Look down into the faucet; there's a philllips head screw. The leaking may simply be caused by this screw being loose.
May 01, 2011 | Microwave Ovens
Leaking
first check and make sure that the water is not leaking from the hose connection to the dishwasher or the drain fitting itself. If neither of these is the problem and it is definetly leaking from the housing then replace. I recommend the Badger series disposal with a 5 or 7 tear warranty I have installed them for years and never had a single problem.
Jul 31, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Repair leaky handle
Try removing cap of knob and tighten screw it could be loose. If that is not it it may need a new seal ring.
Apr 21, 2009 | Plumbing
Water leaking from bottom of coffee maker
The water hose on the bottom of the coffee maker is worn, due to the heat. It needs to be replaced. this is the second time for mine.
Mar 24, 2008 | Cuisinart DCC-1200 Coffee Maker
It leaks water out the bottom
Here is how I solved this problem. I had a small needle nose vice grip, the 'nose' is about 1 1/2 inches long. I tried to clamp the oval shaped screw heads in the vice grip in a perpendicular manner, ie the vice grip was extending away from the side of the coffee maker. There is a recess in the plastic where the screw heads are seated so they are flush when tightened. The ends of the vice grip were slightly too large to fit in this recess. So I ground down the ends of the vice grip so it could fit in the recess and grip the oval end of the screw. After clamping it tightly, I used an adjustable wrench to turn the vice grip and the screw to successfully remove them. I replaced them with normal Phillips screws during the reassembly.
Jan 29, 2008 | Jura Capresso Impressa S90 Espresso...
Braun FlavorSelect KF 180 Coffee Maker Logo
573 people viewed this question
Top Braun Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jim Goldsmith
Jim Goldsmith
Are you a Braun Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
