Question about Electrolux Vacuums
The rotor sweeper is not turning. - Electrolux Vacuums
  • 128 Answers
Need a make and model number - but more than likely the belt came off or broke
Posted on Nov 28, 2008
The brushes on my Dyson V6 sweeper attachment won't turn although it is fully charged.
Your battery may indicate fully charged but if dead it will do that and not work for squat. If charged the motor should run and turn the sweeper with power. If motor runs but sweeper does not check for a stretched belt or one that may have fallen off the pulley.
Sep 06, 2017 | Dyson Vacuums
I need to change my sweeper belt on my Dyson 14 Animal
When turned on and set to sweep the sweeper makes a loud noise like it has something stuck in it but the brush is turning abut not does not have a lot of sucking power. It started the other day when a blanket with tassels got caught and wund up in the brush and sucked up in the sweeper a bit. Tried to pull out while running and came out but made the loud noise. If I take off the brush then it does not make the noise when on. I think it might be the belt grooves are worn and slipping when the sweeper is in the sweeping on mode. Sorry, do not know the technical sweeper terms.
Dec 13, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
The brush on my bissell prolite multicyclonic vacuum won't turn. It seems like it is jammed, but I checked for anything that might be stuck in it and don't see anything. Is there a reset button?
I had the same problem with my old Bissell sweeper ( I bought a new rotating brush each time this happened then I bought a new sweeper the next time it happened -last Dec. 2009.) Unfortumately I bought a new Bissell and now it is happening again to the new sweeper. I do clean the brush often but what has happened is that the hair somehow gets inside the brush via the end caps???This sweeper does have end caps that can be removed for cleaning --although not that easily when they are locked up. I did this yesterday but before I could remove the end cap I had to use a pin, scissors, etc. anything that I could get into the groove to remove lint, etc. that caused it to lock up. Then when I got the end cap to move a little, I pried it off. I found hair, etc. inside where the metal rod is which I don't think should be happening --I used a seam ripper also to try to get some out. I have owned many different brands of sweepers and have never seen this problem before. Then, I put the end cap back on, however, it was not smooth on the inside--almost like it had melted when it locked up. So, the sweeper brush now moves but it is noisy. I guess I will buy another brush -- but this seems ridiculous for a new sweeper--the customer service rep told me that the brush does wear out.... but not on a sweeper that is less than a year old. There is no wear and tear on the brushes. Oh, and the CSR told me that they haven't had people call about this problem --I am guessing they are just buying new brushes or new sweepers. The sweeper def. has great suction but I think other brands do also..
Nov 11, 2010 | Bissell 17G5 PROlite MultiCyclonic Bagless...
The bagless rotor does not rotate/sweeper does not rotate
There is no rotor inside the clear container that turns on a DC07. The stuff spins due to the shape of the airflow. Perhaps your cyclones are completely clogged. you can clean them yourself. see this video http://www.youtube.com/watch?v=2OO3ugkyzxk
Jul 09, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Bissell powerforce bagless vacuum,when turned on dust flies out sweeper
Dust flying out of the sweeper indicates that their is a blockage in the pathway that the dirt normally travels to get into the dirt collection chamber. Turn the sweeper upside down and look for a blockage of some kind. Also, empty out the canister and look to see that the pathway into the canister is clear.
May 18, 2009 | Vacuums
Riccar 8955 sweeper won't run...where is thermal protection switc
thermal reset is located on the back of the machine at the bottom
Nov 24, 2008 | Riccar 8955 Upright Vacuum
Vacuums Logo
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
