Question about Panasonic DMRES15 DVD Recorder
Audio works no video on dmres15
Plays disks ok, tv channels have audio but no video on tv screen
  • Panasonic Master
  • 4,806 Answers
Check all the leads at the back of the unit to make sure they are properly connected
kind regards and please remember to rate us
Posted on Nov 28, 2008
How to I disable the SAP function on RCA FLAT 19 INCH screen?
Hello
From its main Menu, surf towards its sound Menu.
By using UP/DOWN buttons of the remote handset, select SAP
SAP (Second Audio Program) (for analog channels only) Plays the
program's audio in a second language, if one is available. The TV displays
the word SAP in the channel banner when you tune to a program that is
broadcast with SAP information. SAP audio is broadcast in mono. SAP is also
used to broadcast a program's audio with descriptions of the video for the
visually impaired. Press the right arrow button to turn SAP on or off.
OK.
Sep 22, 2011 | RCA TruFlat 27F520T 27" TV
How can i play ps2 on lcd without having a black and white screen ? how can i connect the cables ?.....when i look at the back of my lcd i find three ports (red white yellow) when i use them the screen is...
1) The set of input (Yellow= Composite video, Red= Right channel audio, White= Left channel audio). This set of input is for composite video.
2) The set of input (Red= Red video signal, Green= Green video signal + sync, Blue= Blue signal, Red= Right channel audio, White = Left channel audio (the Red and White will be grouped close together). This set of input is used for Component video for HD signal.
You should try using composite video source (Yellow RCA jack) from DVD player and feed to the monitor and see if it works OK with all color showing that way we acn find out if it is the video source problem or the monitor video signal processing problem. Try the PS2 on the TV if it works OK also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Aug 20, 2011 | Samsung SyncMaster 940MG 19" LCD Monitor
Can not see the Video when I input it, see only a blue screen.
ok hook up the audio video in the OUTPUT on vcr and INPUT on the tv then make sure tv is changed to the right input channel now go to vcr and change that channel to AV,.if AV isnt there you may have to go into menu of vcr and do a channel search,but when you change it to AV on vcr you should see the picture
May 27, 2009 | Televison & Video
Connect Philips DVD to Sansung TV
the red and black are the same as the red and white, these are the audio left and right channels. the yellow plug is the video plug. the next thing you have to check is wheather your tv has video 1 and 2 channels
May 09, 2009 | Samsung Televison & Video
Insert game disk and horizontal lines move fast on screen ???????
Sounds like your TV has multiple video inputs. Make sure the TV is set to the right channel or input. I know on ours if I hit the TV-input button on the tv remote I can change from inputs like s-video, video, cable etc and the Wii only displays properly on one of them.
Mar 28, 2009 | Nintendo Wii Console
Unable to separate VCR playback from Sat. Receiver input,both av2
try to find a multi-video selector swicth that the best you can do
Dec 19, 2008 | Dynex DXR24TV 24" TV
How to Record From a TV Using PV-GS13?
connect a lead via your tv video out audio out jacks. Select tha appropriate channel (You may have to go through the av channel on you tv and tune in the channel you want to record) or, video or dvd player audio out video out jacks. connect other end to your camcorder. Select on the camcorder menu video in audio in. Turn on tv. If connected to video or dvd player, press play. Press record on your camera. When finished recording press stop. Presuming the camcorder is tape, you can buy a tape adaptor to play or record your mini tapes in a standard video recorder, then take them out of the adaptor and play them back on your camcorder. You can also do all this via a computer. Also if the camcorder is disk or hard drive it can be used the same way as a regular dvd recorder to record tv programmes once connected to you t.v. Let me know how you go 26 red
May 08, 2007 | Panasonic PV-GS31 Mini DV Digital...
Cannot view channels higher than 10 and cannot get DVD to come on
Dear althea, I cannot help you with the first problem, but as for the second, "DVD does not come On" and "Do not understand Video 1, 2, & 3 settings." it is very simple. YourTV has the sockets at the front Marked Video 1, Audio L and audio R, The y are in three colors - Yellow for video, red for audio right and White for Audio Left. Similarly, you have 2 such sets of 3 sockets - they are Video 2 and Video 3. This allows your TV to be connectod to three different Video sources - maybe a VCR, A Video game, and a DVD player. To view the pictures generated by your DVD Player, all you gotts do is connect the supplied AV cord from the rear of the DVD player to the front three sockets in the proper order - Video from DVD to Video of TV, Audio L & R from DVD player to Audio L & R of TV. Now press Video on the TVs remote. Press repeatedly till you get Video 1 displayed on the screen. Then, if you now play your DVD player - make sure there is a disc in it - you will be able to view the picture / movie. Good Luck
Mar 05, 2007 | Sony KV-32XBR100 32" TV
External DVD won't play - no manual available anywhere
The tv has a set of imputs for audio and video ,there is a posibility your dvd is not working right,you can also try a vcr by using the rca audio and video outputs of the vcr to the rca audio and video imputs of the tv,that will tell you if the dvd is not working ,the tv should have a switch selector for video and antena or have a channel below 1 called aux.
Oct 02, 2006 | RCA T13208 13 in. TV/VCR Combo
Panasonic DMRES15 DVD Recorder Logo
55 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
