Question about Nikon Coolpix 8800 Digital Camera
Blured Pictures I just added the sb 600 speedlight to my 8800 camera, and when i take a picture without any zoom used, the picture looks great, as soon as i use the zoom the picture is slightly blured. I checked all the settings I could think of but my thought is when I zoom the flash it should compensate and the picture should be sharp especially using VR. Does anyone have any thoughts on this problem, Thank You Frank
  • 111 Answers
SOURCE:
Why does the flash on my Nikon Speedlight Sb-600 flash twice before it takes the actual picture?
It's called a pre-flash. It's so the camera can judge the settings needed for proper exposure.
Nov 21, 2010 | Nikon Speedlight SB-600 TTL Flash
Speedlight SB-600 TTL Flash: When I set my SB600 (mounted on D70) to TTL or TTL...
the sync speed for the sb-600 is onlt 1/200 on most cameras i think so if your shutter is faster then that then all you will see is black/ the curtans behind the shutter.
basicly just try again with a slower shutter speed
May 07, 2010 | Nikon Speedlight SB-600 TTL Flash
The flash is not in sync with my nikon d40 anymore. It fires first. Pictures come out dark. The camera itself takes great flash pictures
It sounds like you're trying to use the SB-600 off camera, as a slave flash. While the SB-600 does indeed have slave capability, the D40 does not have the ability to function as a commander. Thus, the SB-600 is being triggered by the D40's pre-flash.
As stated above, the D40 does not function in commander mode. You can mount an SB-800 or SB-900 flash unit, which will function as a commander as well as a flash. Or you can mount an SU-800 commander unit.
Alternatively, you can switch the D40 to manual flash mode so as to eliminiate the preflash. However, you will then have to calculate the proper exposure yourself.
Dec 31, 2009 | Nikon Speedlight SB-600 TTL Flash
My sb 600 fires with the camera but it seems not illuminate
Definately a settings problem. The camera will only syncronize on one specific speed. Youe best bet is to use auto. For manual, you'll have to set the shutter speed at the sync speed.
Flash Sync Speed
  • up to 1/250 X-Sync Speed
  • up to 1/8000 FP High Speed Sync
  • Red-eye reduction
    Red-eye reduction with slow sync
    Rear-curtain sync
    Slow sync
    Front-curtain sync (normal) Flash Sync Modes
  • 1) i-TTL: TTL flash control by 1,005-pixel RGB sensor, built-in flash, SB-800, SB-600, SB-400: i-TTL balanced fill-flash and standard i-TTL flash
    2) AA (Auto Aperture-type) flash: Available with SB-800 used with CPU lens
    3) Non-TTL Auto: Available with Speedlights such as SB-800, 28, 27, and 22S
    4) Range-priority manual flash; available with SB-800 Flash Control
  • Mar 13, 2009 | Nikon Speedlight SB-600 TTL Flash
    Flash is not working for a nikon sb-600 speedlight
    zoom the flash all the way in so you can see if the flash bulb is broke
    Mar 06, 2009 | Nikon Speedlight SB-600 TTL Flash
    SB-600 Nikon speedlight
    You can download a PDF from www.nikonusa.com (www.nikonusa.com/pdf/manuals/Speedlights/SB-600.pdf) and print it out.
    Jan 16, 2009 | Nikon Speedlight SB-600 TTL Flash
    Random pictures
    Check in the user guid for your camera about their recomended shutter speed setting for the flash.
    Try using the camera and the flash in "A" (automatic) to start with.
    Jerry G.
    Feb 15, 2008 | Nikon Speedlight SB-600 TTL Flash
    Noise while zooming with sb-600
    sb-600/800 make a distinct motor-spinning noise when zooming, this is normal. Any grinding/clicking noises are not normal.
    Jan 25, 2008 | Nikon Speedlight SB-600 TTL Flash
    SB-600 not talking to D50
    Go to the store and try it out on their camera:-)
    atdlee@netzero.com
    Dec 28, 2007 | Nikon Speedlight SB-600 TTL Flash
    Nikon Coolpix 8800 Digital Camera Logo
    100 people viewed this question
    Top Nikon Cameras Experts
    Ric Donato
    pictureman4u
    Geoff Hone
    Are you a Nikon Camera Expert? Answer questions, earn points and help others
