Click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes Right click on usb drive select properties you will have an array of options Select the hardware option then select your drive properties policies restore defaults In XP
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
if still no joy
Right click on your drive select properties then on customize restore Default in W 7
If you need more help with this post a reply
hope this helps
SOURCE: 32Gb kingston pendrive not working. Any data copied get corrupted
Its you pan drive problame and It have 5 year warranty Just replace it and get new one ....
http://www.ec.kingston.com/ecom/configurator_new/partsinfo.asp?root=us&LinkBack=http://www.kingston.com&ktcpartno=DTI/32GB&id=3
When i copy any data to my 32 Gb Kingston pen drive whether any audio or video file or any software, the data get corrupted or may be deleted. some trimes it happen that some of the AV files are working. Why this happened that the data are deleted. I have lost many of my files due to this.It cannot be fomatted also. Please sort my this problem. Thanx
i am using vista operating system
the same should apply with vista as xp
click start click to open on my computer you should see your usb drive F: right click select properties there will be an array of options select the sharing tab option then advanced sharing
permissions make sure you have a tick in the share this folder box then click permissions make sure all three boxes are ticked you full control change and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
also
If you are running a Windows XP OS then you might be able to:
click start right click on my computer select open
Right click the icon of your Flash Drive (It should be F: / E: or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
hope this helps
