Question about PfaFF Creative 7570
Pressure foot on Pfaff 7570 won't keep pressure on fabric
    Scholar:
  • 41 Answers
Double-check to make sure the feed dog lever (located next to the bobbin case) is fully in the up position.
If the lever is in the correct position and you still have no pressure on the fabric, an adjustment of the upper or lower feed system may be necessary... as there is no user adjustment that can be made to these.
We would recommend that you take your 7570 to an authorized Pfaff service technician (you can locate your nearest dealer on their Dealer Locator). While your neighborhood sewing machine repair person may be quite good, they may not have access to any parts that might be needed.
Hope this helps narrow down your problem.
Happy stitching,
Kim & Linnette
www.sewingexpressions.com
Posted on Nov 29, 2008
Pfaff creative 7570 embroidery unit error message 'raise the presser foot lifter' won't clear even though it is raised?
I had this problem, but ignored it, go through the advised listing on the machine's screen, under 'pressure foot lifter' and see if anything can be adjusted.
Dec 08, 2016 | PfaFF Creative 7570
Have Pfaff 7570. Can I sew 4 holed button?
If it is a flat button that will fit under the presser foot, of course you can stitch it down with your sewing machine. (I like to use gluestick from the school supply bin to stick the button to the fabric.) Be sure to deactivate the feed dogs while you are sewing on buttons.
You'll just need to stitch two button holes and then rotate the fabric & button and stitch the other two holes.
How to Sew on Buttons With Your Sewing Machine Sew4Home
Oct 27, 2016 | PfaFF Creative 7570
Cant get machine to embroider
there are three positions the presser foot can sit in. Up and down are the same on any machine. The 7570 has an in-between position for embroidery. Lift the presser foot and the lower it slowly while pushing gently. It should stop about half way down. The embroidery foot pushes the foot into the down position with each stitch allowing the fabric to move easily to the next stitch.
Jan 29, 2013 | PfaFF Creative 7570
Pfaff 1222se runs continuously,like I have the foot pedal down all the way. It won't stop.
sounds like there is a short in the wiring somewhere and the
machine needs to be serviced to find the problem
Dec 23, 2012 | PfaFF Creative 7570
Model 6091. I can't get the presser foot to go completely down and rest on the fabric. Can you help?
This is a comon problem with the pfaff 7570. The spring that applys the presser to the foot is all gumed up and needs to be removed cleaned and lubricated. I dont know if you want to try this yourself. You will need to remove the top and side covers and upper tension unit. Can be tricky. A pfaff repair shop should charge around $30. I will go over the steps if you want, let me know. But like i said i can be tricky.
Mar 24, 2011 | PfaFF Creative 7570
Pfaff 7550 pressure foot
The presser adjustment is usually above the presser foot near the top of the machine.
It can be a post on the top of the machine, a chrome screw on the top of the machine.
Check with your Pfaff dealer.
I use the walking foot for this technique...no puckers if the quilt is first basted.
Mar 18, 2010 | PfaFF Creative 7570
How to stipple with Pfaff 7550
Make sure you have the presser lifter lever in the proper position. When lowering it, push to the rear and it will stop half way down. This engages the upper tension but keeps the foot from lowering down and touching the fabric.
If this doesn't help please post the exact problem, i.e. thread pulling to the bottom etc.
Jan 29, 2009 | PfaFF Creative 7570
Pressure foot problem
hi there not sure if the manual will help but if you go to this link you might find it.
pfaff 7570 manual Google Search
or go to this link might help you to find out why.
pfaff 7570 presser foot wont go down Google Search
Nov 04, 2017 | PfaFF Creative 7570
Pfaff 6122 Problem
Your machine just needs to be tuned up an the part inside that lower and raises the presser foot needs to be re-lubricated.  Lint, dust, dryness and the machine not being used can cause this issue with most pfaff machines (including my 7570).  A standard tune up from your local PFAFF dealer will remedy this.
Sep 24, 2008 | PfaFF Creative 7570
Button holes
Hi
Are you using a Pfaff 7570 (or other Pfaff machine with Sensor)? If so, definitely use the sliding buttonhole foot and the sensor guide (slides below the needle plate from the back of the machine. This will keep your buttonholes consistent.
The size is regulated by the Stitch/Pattern Length button and Width button. Select the size you think you'll need (in millimeters).
Test sew your buttonhole on the EXACT same combination of fabric/layers & stabilizer that your garment is. Adjust the length/width of buttonhole if needed. I would recommend a bit wider buttonhole due to the thickness/puffiness of the fleece.
Hope this helps,
Kim
Jan 25, 2008 | PfaFF Creative 7570
Sewing Machines Logo
211 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
