Question about Kenmore 27032
Kenmore dryer timer never shuts off.
My dryers timer keeps going around and around until the door is opened ann shuts off the timer. It just keeps drying the clothes over and over again. I replaced the timer thinking it was the problem but the new timer has the same problem. What could be causing this if it is not the timer? The dryer works correctly except it never shuts off!!!! model number ia 110.92281800. It is about fifteen years old
  • 116 Answers
REPL/ YOU BROKEN LID SWITCH ,, IS ON OPEN POSITION REASON FOR NO T SHUTTING DOWN////
Posted on Nov 30, 2008
Dryer runs with no heat and never shuts off on its own
what are you running it on?auto or more or less,if so the timer will not advance to off without heat,usually the heat comes on,the dryer heats up until it reaches temp.the heater shuts off and then the timer will start to advance to off,when the heat comes back on the timer will stop advancing and the heat will come on,it will do this until the clothes are dry,so no heat the timer will not move,now if you put it on time dry the timer should count down no matter what just like a clock.if you open the door and look around the opening where you put the clothes in you'll see a tag with the model number send this and i can help you.
Oct 08, 2013 | Kenmore 63942 Dryer
What's wrong with my dryer & how do I fix it? Kenmore 70 series dryer won't shut off!! It stops when the door is open but won't shut off on it's own.
If the timer just keeps going past the next off and never shuts off then it could be one of two things. First, is the heating still on when door is opened? If it is then the electric heating element is broken in half and one half is getting neutral by laying against the metal heater case which will cause this problem. (assuming a electric dryer). If not then the timer is the culprit and check fleabay for NOS.
May 01, 2010 | Kenmore 62602 Electric Dryer
Dryer shuts off when I open door ,but timer keeps running
I had this same problem with my Kenmore dryer. If I left it plugged in and door shut it would eventually turn over and start up again. But now my timer is working properly but my dryer won't heat up and dry the clothes. I need help....
Feb 26, 2010 | Kenmore 63942 Dryer
Have a kenmore series 70 dryer. Won't shut off
Yes it deffinetley sounds like you may have a timer issue, if your timer stops and the dryer is running, or if the timer keeps going around and around this will be the problem, however there are thermostats inside the dryer and if you have it set on a HEAT and not a TIMED setting the thermostats won't advance the timer because they havent been set.Hope this helps
Thanks.
Nov 22, 2009 | Kenmore Dryers
Dryer wouldn't shut off except with door open, now it won't run
More than likely the cycle timer is bad. Have it replaced and that should put you back in business. Hope this helps. Please re-post with up dates. Good luck. Thanks cj2176.
Jul 10, 2009 | Kenmore 62882 Electric Dryer
Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Mar 25, 2009 | Dryers
Dryer keeps running and timer continues to move around dial.
Change your timer. It has a malfunction in it. it's about a 100 dollar fix. Also your start switch may be bad.
Mar 02, 2009 | Kenmore Dryers
Kenmore dryer keeps on going and going
The timer is bad. It is located behind the knobs and can be replaced really easily. The price for a new timer is about 35 dollars. If this helped please rate
Feb 12, 2009 | Kenmore 64902 Electric Dryer
Kenmore 80 series- wont shut off
it sounds like the timer is bad; expensive
also, the only way to get out something that fell into the blower box it to unplug the dryer and reach into the exhaust hole and try to reach it from there and if that fails then you have to take apart the machine.
Jun 27, 2008 | Kenmore 63942 Dryer
Kenmore 27032 Logo
161 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
