Question about GE 28128EE2 Phone
GE28128EE2 Cell Fusion
I have a PROBLEM that makes the BLUETOOTH connectivity feature, the primary differentiating feature of the phone, BASICALLY USELESS. Handling cell calls should be easy. One would expect a cell call to go unanswered until (a) a handset picks up in cell mode, (b) the basestation answering system handles after option-defined number of rings, or (c) the cell service terminates the call. Unfortunately, that isn't how my GE28128EE2 handles cell calls.
When the system is bluetooth bonded to my cell phone, incoming cell calls are routed to the base station speaker after three rings. So, if I don't "pickup" by press blinking "cell" on a handset within three rings, I must physically get to the base station which is "off-hook", speaker active.
Thompson support line suggested a "hard reset". "Hard reset", (remove batteries, power off, wait 15 minutes, power back on) did not fix the problem.
1. Is this behaviour observed on all GE28128EE2 phones?
2. Is there any way to stop the GE28128EE2 base station from directing cell calls to the speaker after 3 rings?
  • t_kirk Dec 01, 2008
    Fixed my own problem... I silenced the ringer on the cell phone and that fixed the issue for me.
    I'm guessing the "bluetooth Hands Free Profile (HFP)" is by default issuing a command to the bluetooth client on the phone to "auto answer." When I silence the ringer on my A780, it sends the message ring until answered.
    Bottom line, if you've got a 28128EE2 that is answering cell calls to the base station speaker, look for "disable headset auto answer" in the bluetooth options for your cell phone.
2 Suggested Answers
SOURCE: Bluetooth disconnects after 5 minutes
I know this sounds silly, but try having your cell phone more than a couple feet away from the base of the DECT phone. Bluetooth can have issues when they are really close together. I have mine setting about 6ft away without problems.
Posted on Jul 04, 2009
How to pair it with galaxy tab 4
This is for the 1900, but should be the same. Go to Bluetooth settings on your Galaxy.
Samsung HM 1900 User Manual
Aha, I found this for the 1500
4 Enter the Bluetooth PIN (0000, 4 zeros) to pair and connect the headset to your phone. Your headset supports the Simple Pairing feature which allows the headset to be paired with a phone without requesting a PIN. This feature is available for phones that are compliant with Bluetooth version 2. The headset also can be paired via the Active pairing feature, see page 14. Connecting with two Bluetooth phones
With the Multi-point feature activated, your headset can be connected with two Bluetooth phones at the same time. 1 After connecting with the first Bluetooth phone, press and hold the Talk button until the blue indicator light stays lit. 2 Press and hold the Volume up button to activate the Multi-point feature. 3 Activate the Bluetooth feature on the second Bluetooth phone and search for the headset (see your phone???s user manual). 12
4 Select the headset (HM1500) from the list of devices found by the second Bluetooth phone. 5 Enter the Bluetooth PIN (0000, 4 zeros) to connect the headset to the phone. ??¢??¢ You can set the headset automatically to reconnect to the recently connected phones each time you turn it on. -- To reconnect to the two most recently connected phones, activate the Multi-point feature. Press and hold the Volume up button in Pairing mode until the blue indicator light flashes twice. -- To reconnect to only the most recently connected phone, deactivate the Multi-point feature. Press and hold the Volume down button in Pairing mode until the red indicator light flashes twice. ??¢??¢ When the headset connects to two Bluetooth phones, some phones may not connect to the headset as the second Bluetooth phone. English
Disconnecting the headset
To disconnect the headset from your phone, ??¢??¢ Turn off the headset. 13
Reconnecting the headset
When the headset is paired with a phone, it will attempt to automatically reconnect each time you turn it on. If the headset does not automatically attempt to reconnect, ??¢??¢ Press the Talk button. Pairing via the Active pairing feature
With the Active pairing feature, your headset can automatically search for a Bluetooth phone and try to make a connection with it. 14
3 Press and hold the Talk button until the violet indicator light turns on. The headset will switch to Active Pairing mode, search a Bluetooth phone within range, and attempt to pair with it. [. . . ] ??¢??¢ To switch between the current call and the held call, press and hold the Talk button. 19
Oct 30, 2015 | Samsung HM1500 Bluetooth Headset
you have to check the compatiblity of this device with yout cell phone.
Connectivity Bluetooth version
  • 2.1 with enhanced data rate (EDR)
Bluetooth profiles
  • Handsfree profile (HFP) 1.5
  • Headset profile (HSP) 1.1
if your cell phone has the above features then follow the undermentioned steps.
you need to search for the device by starting a new search after switching on the bluetooth and make sure that the bluetooth headset BH-104 is switched on.
once the search is completed and your device is found then pair it.
after pairing the device you can use it.
Dec 26, 2010 | Nokia BH-104 Bluetooth Headset
Mad Catz bluetooth will not connect. It has worked before. The bluetooth will turn on and it will have a blue light that will flas two times. Usually when I press the power button again it connects but...
Go into your Phone's settings and make sure Bluetooth is turned on and also make sure that your phone and the Mad Catz Bluetooth are in "discoverable" mode which basically means that the phone will show up to other devices and will also discover the Bluetooth Headset and then you should be able to pair them together.
If this doesn't work, you may want to stop in your nearest cell store and see if one of the reps will help you out. I'm sure they'll either get it working for you or at least guide you in the right direction.
I hope this helps :)
Dec 18, 2010 | Mad Catz PS3 Bluetooth® Headset Wireless...
My bb 8310 AT&T device won't pair with a headset or with my ford fusion
Make sure you have the correct password for your phone. Also look in your fusion manual as to the correct steps needed.
  • Press the Power Button. // This is on a 2010 Ford Fusion.
  • Then you hit the Phone Button.
  • It should say “No Phone Paired” that means that no phone has been paired with this.
You now have a choice of options:
  1. Add Bluetooth device
  2. Connect Bluetooth device
  3. Set Primary Phone
  4. Set Bluetooth On/Off
  5. Delete Device
  6. Delete all Devices
You want to choose Add Bluetooth Device, press OK
  • Then on your mobile, turn your Bluetooth On.
  • Setup Bluetooth – Search
  • Now it’s searching for it, when that gets full, Click Sync.
  • Then you’ll want to enter the PIN number that’s on the screen.
  • Say YES to connect to Sync.
  • Now screen on dash will say your mobile phone
Mar 26, 2010 | RIM BlackBerry Curve 8310 Smartphone
Ge Cell Fusion Bluetooth Connection will not stay connected
I have the same problem. I dont understand what the 'auto connect' feature as you would think it would re-pair with the cell once the bluetooth is disconnected, right?
Aug 04, 2009 | GE Lands Phones
I cant get my phone to play music through my env3
hi kinldy check the features of your bluetooth because certain bluetooth has features of only receiving and making calls alone
Jul 30, 2009 | LG enV3 VX9200 Cell Phone
Motorola bluetooth pairing
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select H700 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Aug 09, 2008 | Motorola Mobility H700 Wireless Headset
Open Questions:
GE 28128EE2 Phone Logo
102 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
