  • 201 Answers
SOURCE: speaker wiring diagram
Hey there retgrunt, the information is at this location to download. the actual number on the guide is not the model you indicate, but the setup I believe is the same. I hope this helps Good luck!
Posted on Jan 28, 2008
  • 93 Answers
SOURCE: Problem w/ Panasonic SA-HT700 speakers
Let me show how to resolve your problem since you are not very good at this system.
A/V troubleshooting 101:
Remember the 2 speakers that you mentioned before that it worked.First,locate the one speaker output that work for you before(ex. front left)you will use this speaker output to connect each one of the speaker and leave the system on either tuner(radio with a proper station=101.3) or a dvd with sound,this way,you are troubleshooting two things for sure A. be sure all your speakers do work and B. your source is working.
After you test all the speakers with the same speaker output which had confirmed the speakers are working,that particular speaker output is working and also your source is working,send me an email and i will show the next step.
However,for any reason,if one of those speaker got no sound from the same speaker output connection,please do not waste anymore time,should take it back to the place you bought it from and get our money back and try to buy the A/V system separately(A/V receiver with speakers in one package, separate dvd player,etc.)
Posted on Nov 06, 2008
SOURCE: Yamaha HTR-6130 Front right and left speakers with no sound
As simple as this sounds, try hitting the speaker a/b button on the front of the unit, next to the headphone jack. I had the same problem, and was about to package the whole thing back up and go back to Best Buy when I hit this button and then the audio test worked.
Posted on Dec 05, 2008
SOURCE: JVC 8 pin pinout - speaker cable
Looking at the connector, there are 3 rows of pins.
Starting with the first row closest to the alignment mark:
[Power On],[Center Speaker],[Sub Woofer]
[Surround Right],[Speaker Ground],[Surround Left]
If you are trying to connect two JVC units, you will need an 8-pin cable that has the SAME pins connected on each side. You will need to test this using a multimeter set to ohms or 'connectivity'.
There are other 8-pin cables out there like the one for apple networking, but they use a crossover pinout where pin 1 on one end = pin 3 on the other end. This is bad. JVC needs pin 1 to = pin 1.
This is a standard connector/pinout setup that JVC uses, so connecting a TH-C3 to a TH-C50 works fine. There is a bunch of intermixing that you can get away with. The only thing to keep an eye on is the power in watts that one unit sends and the other recieves. Worst case is that the speakers are quiter than expected or that you can turn the volume up so high that it can damage the speakers. In all cases, you should get desired volume somewhere on the dial.
If you are trying to wire the speaker set custom, then you will need to take note that an '8-pin' connector is actually a 9-wire connector. Along with the above pinout, you will need to add Case Ground, which is the metal circle that surrounds the pins. To make the speakers turn on, you will need to apply 12v to the Power On pin and ground the 12v source to the Case Ground outer ring.
The system takes 3 to 4 seconds to fully turn on after this connection is made. Speakers should be wired using the center pin for speaker ground and each other pin respectful to each speaker.
Posted on Dec 10, 2008
  • 151 Answers
SOURCE: Connecting an audio/video transmitter to Yamaha HTR 5830 Amp
If you want to get sound out to speakers use the KEFF WIRELESS SYSTEM as this will not break up or cut out.
Hope this helps.
Posted on Jan 06, 2009
I have a Yamaha HTR 6180 reciever and 2 AR 328ps speakers one of the speakers when turned up with shut the reciever down I did a prosses of elemination and took each speaker out of the tower individually...
A capacitor is more like to fail than a coil, so I would also suspect a cap first. Capacitors conduct high frequency more than low frequency, so this may explain the extra load and shutdown on high frequencies.
Jan 21, 2015 | Yamaha Audio Players & Recorders
My yamaha htr 5935 turns off by itself after 3 seconds. I have disconnected all the speakers and it still does it.
I had the XM antenna plug come loose. In the process of trying to re solder it I had to remove the small shield over the plug. With the shield removed the reciever would shut off after 3 seconds. Once I soldered the shield back on it stayed powered up. I hope this helps.
Sep 04, 2010 | Yamaha 5.1-Ch. Surround Sound Home Theater...
14 speakers hooked up to home theater reciever,shuts off .5 vol
Try less speakers.
The impedance will be to low for this amp.
May 10, 2010 | Yamaha P2500S Amplifier
sounds like you have the polairity reversed on the speakers
and yes it does make a difference
check polairity also make sure unit is well ventelated
you wouldnt use your compouter if it was inside a card board box
so make sure the reciever can breath also
recievers get too hot and they start blowing chips off the board
Jul 25, 2009 | Yamaha HTR-5560 Receiver
Problem with sp cable (yamaha)
The speaker cables are the ones that clamp or tighen down on the back of the reciever. All the spkr wires have to have the positive and negative leads correct. Also not aven one little strand of wire can be touching another conductor or you will have this problem. Make sure all leads are correctly ran and hooked up positive to positive and negative to negative from the back of the reciever all the way to the speakers. This should solv your problem.
Jul 25, 2009 | Yamaha HTR-6030 Receiver
Keeps shuting off
If the receiver shuts down after some time operating properly it is likely caused by a heat issue or crossed (shorted) speaker wires. Please make sure that the unit is adequately vented and the air vents/fan on the back of the receiver is clean. If it is then carefully check all of the speaker wires for cracks, damage, and/or crossed wires.
Feb 26, 2009 | Yamaha HTR-5630 Receiver
HTR-6130 will not turn on
Remove all speakers from the receiver and try powering it up again. If it still shuts down odds are it needs repair of one of the output channels.
Jan 31, 2009 | Yamaha HTR-6130 Receiver
Yahama HTR-5560
I own this unit also and have found that it is very sensitive to speaker wire shorts. Please recheck all speaker connections to make sure you have no "stray wires" touching someplace to make a short.
Oct 27, 2008 | Yamaha HTR-5560 Receiver
HTR-5550 will not stay on.
jerry ...
question??? before you stored the unit, was it working fine?
are you using the same sets of speakers like before?
Mar 15, 2008 | Yamaha HTR-5550 Receiver
180 people viewed this question
