Question about NEC Dterm DTP 16D-1 Corded Phone
Speakerphone does not work on my phone DTP32D1A?
How do I switch speakerphone back on, the red light needs to be lit on the phone and it isn't
With handset on hook, Press "Feature" 1.
Posted on Dec 01, 2008
Line 1 disconnects people on hold
Try these first and let me know
Intercom does not function correctly
• Make sure line 1 is connected properly and common to all phones on the system.
• Make sure all phone ID’s (station numbers) involved have been assigned.
Transfer does not function correctly
• Make sure receiver phones (stations) have same line connected.
Intercom indicator turns red and green alternately
• The station address needs to be re-assigned due to a duplicate station address in the system. See “Changing the Phone ID (Station Address)”.
Good luck,
Lee
Jun 17, 2008 | GE RCA 4-Line Speakerphone
The speaker phone will not work
If you have the speakerphone option enabled in system programming, you may just have the mic turned off. Try pressing Feature then 1 while the phone is idle. The mic light should light up if it wasn't already lit.
Apr 13, 2011 | NEC DTH-8D-1 Corded Phone
How to change greeting on GE speakerphone 29385ge1.
The 29385GE1 isn't an answering machine. There is no greeting on it.
If you have a separate answering machine connected to your phone line, consult its documentation. If you subscribe to a voicemail system offered by your phone company, contact them for instructions.
Feb 15, 2011 | GE 29385GE1 Speakerphone
How do you switch on/off the speakerphone on the lg ally?
Whilst in a call, you'll find an icon labeled 'Speaker'. Just touch it. It will lit up and the speakerphone function will be acitvated. Then, if you wish to deactivate the speakerphone function, tap over it again.
By the way, if your phone's user guide happens to be missing, feel free to download it from this location.
Please, let me know if I can help you any further.
Regards, Carlos
Nov 20, 2010 | LG Ally Cell Phone
Jabra SP700 will not turn on. Charged until green light came on. Took off charger, and put it back in. Light turned red. Eventually went green again. Will not turn on. Back to red when I plugged in...
You've probably accidentally put it in locking mode. Here's what the manual says about it, and how to get out of it:
Locking mode
To prevent accidental key presses that could turn your speakerphone
on e.g. while carrying it in a bag, the speakerphone can be
turned into locking mode. Press simultaneously the Answer/End
button and FM button for 4 seconds while the speakerphone is
turned on. The speakerphone is now turned off and can only be
turned on again by pressing Answer/End button and FM button
simultaneously for 2 seconds.
Sep 24, 2010 | Jabra SP700 Bluetooth Car Kit
Blackberry bold 9000 speakerphone doesn't work!
Guys- I have had the same problem with my speaker not working and it comes down to the spacing inside the phone. Some people have resolved the problem by placing a small piece of paper or credit card between the phone or the battery back. I actually took the back cover off, the battery off, and then unscrewed the 6 tiny screws to take the back of the phone off. You'll then see two small pins that act as spacers to keep the phone back off of the speaker and you can gently bend them upward a bit more and this totally worked for me. I noticed after I was using a leather pouch to hold the phone, the only way to take it out was the pinch the phone on that area, and was thus "smooshing" these pins down and not giving the speaker the appropriate spacing. You'll void your warranty by doing so - but you should be able to fix the problem.
Aug 04, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
Blackberry curve 8310 answers on speakerphone
Take your battery out for a few seconds. This should reset your phone. We just did it and it worked.
Jul 15, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
AT&T 926 Corded phone
check for a button or sliding switch on the side,top,or bottom for the ringer on/off, [ some phones even have this switch on the back ] as for the speakerphone, you may have to push the speakerphone button, then put the handset back on the cradle for the speakerphone to work.
hope this helps.
wg
Feb 13, 2008 | AT&T 962 Corded Phone (A21076)
Avaya 2410 speakerphone
If the phone programming has been set to 2-way and you have reset the phone. Either by unplugging it and waiting for a few minutes then plugging it back in or from the idle state press the "MUTE" key and then dial R E S E T on the keypad. If after this it will still not work as 2 way then it is most likely a faulty phone.
Jan 24, 2008 | Avaya 2410 Corded Phone
NEC Dterm DTP 16D-1 Corded Phone Logo
77 people viewed this question
Top NEC Lands Phones Experts
Craig Butler
Craig Butler
Oloyede Monsuru
SC Spike
Level 1 Expert
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
