Question about Epson Stylus Pro 4000 InkJet Printer
Comman error after installing the printer driver for winxp and I issue a print the control panel of the printer reads "command error driver ink set settings is wrong
  • nii yaotey Jan 13, 2007
    lost the original drivers and copied one from the net for winxp
    when I used the utility it worked and it clean the nozzle but when I print it reads command error on the printer control panel
What are the comman error in english grammer
Posted on Feb 11, 2008
Heap over flow error
The "Heap Over Flow" error indicates you are basically running out of memory to store graphics commands before a command to print data is issued.
The solution is
1) Windows Printing.
A) Ensure the printers EMULATION setting matches the printer driver uses.
B) If using the T6050 printer driver ensure you have the correct lavel of firmware. The later version of printer driver need to have the latest T6050 firmware installed in the printer.
C) Consider setting the printer EMULATION to EPSON FX then install the EPSON FX100 driver on the Windows Box
Or
Install the IBM Proprinter XL24 driver on the Windows Box and set the printer EMULATION to IBM Proprinter
Using either of these two compatible drivers will 'side step' issues caused by printer firmware / drinter driver compatibility issues as it may be difficult to obtain suitable firmware or drivers due to the age of this device.
2) If you are coding the escape commands yourself you need to check these as they are incorrect if this error is seen
Oct 24, 2013 | Tally Line Matrix T6050 Printer
Tip
How to Repair Canon Printer
Canon printers are available in various models, such as laser, inkjet,photo and all-in-one model which can copy, scan, print and faxtogether. Though, Canon is one of the most trusted brands when it comesto printers, but like all other technical products, its printers canalso ditch you when you are in the most urgent need.
Printer is a good companion if it works nicely, but a worse foe when itstops giving the desired results. Here are some of the tips that youcan follow to fix your Canon printer and get the best out of it.
General Issues
Paper jam: It’s a frequent mishap when more than one sheet ofpaper stuck together in the feeding mechanism. You can manually liftthe cover and remove it.
Ink level: Your cartridge has no ink and you may be getting no print except a blank paper.
Clogged cartridges: This is the most common fault, when yourcartridge head is clogged with dry ink. You can repair it with simplecommand as: Control Panel> Printer>Right Click>Properties>Maintenance> Clean Cartridges.
Driver failure: Software bugs, errors or conflicts may arise onaccount of corrupted printer’s software and hardware. You need toreinstall printer drivers and software. Try to get best compatibledriver for installation.
Alternatively, you can update your printer driver as: "Control Panel> Printers > Right Click > Properties > Update Driver".
Canon-Specific Issues
Waste Ink Error: Here you need to take some setting steps. Pressmenu option of your printer followed by scan/copy to access Servicemore option. Now, press the right arrow to explore "NVRAM". Set ABS-Mlevel to 0. Set ABS-P level to 0. Press "Stop" to exit.
Invalid Cartridge Message: Turn off your printer besidesunplugging the power cable. Recover the cartridges and the print headand dip them in lukewarm water to remove clotted ink. Allow them to dryand wipe with a tissue. Now, reset them in your printer and run thecartridge alignment.
E0D02 error: Ensure your cartridge as well as the attachedsender strip is free from moisture and dust. The sender strip islocated behind the rubber drive belt and runs horizontally across themachine. Make a regular practice to wipe it with a soft cloth.
Learn some printer etiquette's to avoid above issues:
Keep patience: Don’t give print commands for multiple jobs at asingle time, as the printer take the time as per the size of the printjob requested earlier.
Use desired paper: Abstain from printing on card stock, photo paper, etc; use only laser jet paper.
Restrict print jobs beyond 50 pages: Don’t over burden yourprinter. It is advised to print not more than 50 pages in one singlego. Avoid too much color ink: Black and white laser printers are thebest as they need the least maintenance.
on Feb 19, 2010 | Office Equipment & Supplies
Epson stylus pro 9600 error command
Sounds like you have to change the black ink from photo black to matt black
Oct 06, 2017 | Epson Stylus Office Equipment & Supplies
My status reads error and it wont print
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts. Sometimes the power supply unit must be checked as a poor SMPS unit can deliver low voltage and cause issues to the printer function. Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Thank you for using Fixya
Aug 30, 2011 | Brother HL-4070CDW Printer
My printer is taking command but it is not printing anything.
Jul 12, 2011 | Office Equipment & Supplies
Command error on epson 9600
Are you sure it is a 'command error' and not a 'communication error'. I could not find anything on a 'command error' but did find this on a 'communication error'.
Q: Why am I getting a communication error when I try to print?
A: Check the following if you are getting a communication error when printing:
Make sure the type of driver you installed matches the ink type in the printer. Verify the ink type by checking the part number on the ink cartridges.
Make sure the printer interface setting matches the connection type you're using. By default, the printer interface should be set to Auto, which supports all connection types.
Check the physical cable connection and make sure the cable is not be longer than 10 ft. You may want to replace the cable.
You may also get communication errors if the printer name is not set correctly. Contact EPSON at (888) 377-6611 or (562) 276-1305 to get instructions on how to verify this.
You might want to check to see if you have the current drivers for your printer and operating system; a new driver can be downloaded here.
Trust this is helpful.
Dec 14, 2010 | Epson Stylus Pro 9600 InkJet Printer
HP3600 USB printer works but won't print on my HP7058 Laptop
Try removing all ports from your laptop, then reboot, and then create just one USB port. Also, go to your hardware devices and make sure your usb ports don't have any question marks or yellow warning symbols. Be sure first that the drivers for your USB ports are installed and working first. This sounds either a faulty USB cord, which does happen, or USB drivers issues in your laptop. The printer is probably not the problem here.
Feb 17, 2010 | HP LaserJet 3600n Printer
Brother MFC-5860CN printing issues after switch Win2k to WinXP
Are the settings in the print driver set to the highest quality setting? If so, this will slow the print speed down tremendously. Try changing the default settings in the print driver to a lower quality (or resolution) setting.
Dec 20, 2009 | Brother MFC-5860CN InkJet Printer
Win Vista cannot print on Win XP(P) shared lexmark p6250 printer
try to remove printer driver and install again located at control panel..
how to do this?
go to the start and din control panel and din click ad and remove program you can see the new window appear name current install files you can see the printer driver bellow click uninstall. to take effect restart you pc din install again the printer driver.
and chk your tuner or ink maybe if not empty thank you hope i can help you... have a good day!!!!!!
Jul 06, 2009 | Lexmark P6350 Printer
Can't delete print job for an Epson C** printer
I don't know which OS you have. I will assume it is a newer OS like WinXP. You have tried to reboot the PC I'd imagine. Try stopping the print spooler by running the following command from the cmd prompt.
net stop spooler
Then check the print queue and see if you can manually delete the print job. Then issue the command
net start spooler
Jan 30, 2009 | Epson Stylus C88 InkJet Photo Printer
Epson Stylus Pro 4000 InkJet Printer Logo
231 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
