Question about Dryers
My Dryer controls are locked how can unlock the controls
    Sergeant:
    Champion:
  • 324 Answers
Push the button that has the picture of a little lock for about 7 seconfd
Posted on Nov 28, 2008
Whirlpool duet dreyer control lock On --can't program dreyer
try unplugging for a couple of minutes and it should reset to factory settings.
Mar 07, 2018 | Whirlpool Washing Machines
Tip
The front light lit on my Whirlpool dryer is showing control locked
Hi.
If the front light lit is control locked, that means that your Whirlpool electric dryer had been set in control lock mode.
Control lock is a special mode that will prevent user from changing settings or using control until the dryer gets unlocked again.
The machine is set to control lock mode by holding down the CONTROL LOCK/UNLOCK button for several seconds. In the same way you can stop the control lock mode when the machine is already set to Control Lock.
When the dryer is running and Control Locked is on, the dryer can still be stopped by pressing the Pause/Cancel button, but cannot be restarted until the control is unlocked.
If the front light lit is control locked but the dryer door opens and it does not turn off, then you are probably in this situation. In that case, the door will be opening , but the machine still stays locked.
Disconnecting the machine from power, either unplugging power cord or tripping circuit breaker, won't help. The control lock system is designed to stay on in case of power failure.
If the machine is control locked, try unlocking it with the following procedure.
To unlock: Press and hold the CONTROL LOCK/UNLOCK button for 3 to 5 seconds to turn the control lock feature off.
If that does not work, try disconnecting power for five minutes to reset the machine, and eventually do unlock again. As said, cutting power alone will not cause the machine to unlock.
If the machine is still not responding, the lights stay on all the time, the dryer panel does not respond to control unlock procedure, and the door does not lock anymore, then it may be a defective control board.
If you are in this situation, before replacing the control board more parts, including the door lock must be tested. In that case the best option may be contacting the Whirlpool support number listed on the Dryer use and care manual, usually in the last pages.
In this case try resetting control lock as explained above, as told the dryer is more likely control locked and then stopped.
Regards.
Ginko.
on Feb 01, 2010 | Whirlpool GEW9250 Electric Dryer
I have a code of loc coming on and my dryer wont work how can I fix this issue??
The control panel is locked. on the control panel, there will be either a "lock" button that you hold down for 3-5 seconds to unlock, or it will have "lock" in small letters with a line pointing to 2 of the option buttons. hold the 2 buttons it points to for 3-5 seconds and it will unlock. the control lock is a child safty feature that will not allow any the washer to work until it is unlocked. P.S. to put the control panel into the lock mode, is the same way as you unlock the control panel.
May 29, 2015 | Frigidaire ATF6000ES Front Load Washer
Dryer is on LOCK CONTROL how do Iget it off?
The model number did not cross but here is what the manuals say for a Duet dryer:
CONTROL LOCKED
This feature allows you to lock your settings to
prevent unintended use of the dryer. You can
also use this feature to prevent unintended
cycle changes during dryer operation.
To enable the Control Locked feature:
Press and hold the End Of Cycle Signal button
for 3 seconds. The control is locked when a
single beep is heard and the Control Locked
status light is on.
• When the dryer is off, it is not necessary to
press the Control On button before activating
the Control Locked feature.
To unlock the Control Locked feature:
for 3 seconds to turn this feature off.
NOTE: When the dryer is running and Control
Locked is on, the dryer can be stopped by
Let me know if this does not work.
Kelly
Jan 22, 2011 | Whirlpool Washing Machines
Control locked
If you want to enable the Controls Lock/Unlock Feature:-
To enable the Controls Lock feature when dryer is running: Press and hold the CONTROLS LOCK/UNLOCK button for 3 seconds. The control is locked when a single beep is heard and the Controls Lock status light is on. This feature allows you to lock your settings to avoid unintended use of the dryer. You can also use the Controls Lock feature to avoid unintended cycle or option changes during dryer operation.
■When the dryer is off, it is not necessary to press the Control On button before activating the Controls Lock feature.
For unlocking: Press and hold the CONTROLS LOCK/UNLOCK button for 3 seconds to turn this feature off.
NOTE:- When the dryer is running and Controls Lock is on, the dryer can be stopped by pressing the Pause/Cancel button, but cannot be restarted until the control is unlocked.
Good Luck and have a nice day
Rating the solution is highly appreciated.
Jun 29, 2010 | Whirlpool GEW9250 Electric Dryer
Control lock on
To enable the Control Locked feature when dryer is
running:
Press and hold the CYCLE END SIGNAL button for 3 seconds.
Locked status light is on.
On button before activating the Control Locked feature.
To unlock:
Press and hold the CYCLE END SIGNAL button for 3 seconds to
NOTE: When the dryer is running and Control Locked is on, the
dryer can be stopped by pressing the Off button, but can’t be
Jun 01, 2010 | KitchenAid KGHS01P Gas Dryer
How do you turn off the control locked key?
running:
Press and hold the END OF CYCLE SIGNAL button for
the Control Locked status light is on.
To unlock:
Press and hold the END OF CYCLE SIGNAL button for 3 seconds
can’t be restarted until the control is unlocked.
May 29, 2010 | Whirlpool GEW9250 Electric Dryer
Control locked light is on
This feature allows you to lock your settings to prevent
unintended use of the dryer. You can also use the Control Locked
feature to prevent unintended cycle or option changes during
dryer operation.
running:
To unlock:
Here is a manual.
Apr 10, 2010 | Whirlpool GEW9200L Electric Dryer
Machine is stuck in control lock
This feature allows you to lock your settings to prevent unintended use of the dryer.You can also use the Control Locked feature to prevent unintended cycle or option changes during dryer operation.
To enable the Control Locked feature when dryer is running:
Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Locked status light is on.When the dryer is off,it is not necessary
to press the Control On button before activating the Control Locked
feature.
To unlock:
Press and hold the END OF CYCLE SIGNAL button for 3 seconds to turn this feature off.
NOTE:
When the dryer is running and Control Locked is on, the dryer can be
stopped by pressing the Pause/Cancel button,but can't be restarted
Apr 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
HAVE A WHIPOOL DRYER IT SAYS CONTOLS LOCKED DON'T KNOW HOW TO UNLOCK IT
Locked light is on, the dryer can be stopped by
Aug 03, 2009 | Washing Machines
Dryers Logo
263 people viewed this question
Top Dryers Experts
Marvin
Marvin
