Question about JVC HR-A592U S-VHS VCR
Machine won't stay on
Whenever I eject a tape the machine tries to pull it back in. If I take the tape out, the machine shuts down. It also shuts down if the tape rewinds and reaches the end. I can still use the machine otherwise and it works fine as long as there's a tape in the machine.
  • 50 Answers
Hi I'm not familiar with your model, but what it sounds like is a bad "end sensor" on your machine. There are photo sensors on either side of the cassette basket which is what holds the tape in the machine. There is a light source that ends up inside the cassette when loaded, which shines both left and right. There is a section of clear tape inside the cassette at both the beginning and end of the tape. When the sensor on the left side sees light through the clear tape, the VCR knows you have reached the end and goes into rewind, when it sees light on the left side, it knows you have reached the beginning of the tape, and stops rewinding. This sensor is also used in some models to sense when you insert a tape in the basket. In that case, if the right side end sensor goes bad, the VCR always thinks you are trying to load a tape, so it doesn't want to give them up, and when you rewind, it never senses the beginning of the tape, so it will shut down when it reaches the beginning, and could even snap the tape. I'm 99% positive that is what is wrong with your VCR, it is an easy fix, but unfortunately, you won't likely find a repair shop that will sell you the proper sensor. I hope this helps in some way. Good Luck!
Posted on Mar 27, 2007
Does not eject
Best to get the service manual, this will explain the best way to get the tape out of the machine without causing further damage to the drive system.
However if you can't find it, take the top off and remove the tape very carefully. Try and determine how the tape can be removed without force, possibly by moving the mechanism by hand.
The video shuts down to prevent the problem causing further damage.
Feb 04, 2014 | Fisher FVH-4913A VHS VCR
Shuts off when trying to play or record
This could be due to the VHS tape sticking on the tape reel, that triggers the overload and the shutdown. Try fast forwarding if possible.
Nov 01, 2017 | Emerson EV787 VHS VCR
My VHS tape is stuck and won't eject or plsy
The transport mechanism ff/rewinds and drives the tape back into the cassette when eject is used.
Most likely a bad belt or the drive idler wheel (rubber or geared). Unit would have to be taken apart to "see" what is not happening.
Oct 22, 2012 | Televison & Video
Vhs is stuck in machine. Won't play and won't eject.
There are any number of reasons why it won't play. The loading basket is jammed, the video tape has got tangled up in the mechanical section of the vcr or the loading gears are stripped. Unplug machine and remove top, [screws side and back] if the tape is spewed carefully remove by cutting it and clean tape particles, for any other problem have a technician check it out.
Jun 28, 2012 | Sony RDR-VX530 DVD Recorder/VCR
VHS Tape won't stay in compartment
Going to have to look inside but expect to find that tape is not going all the way into position and having the tape pulled out and up against the drum with the video heads.
If it does not fully load a transport problem exists--drive idler and or belts.
Faintly possible also is something that does not belong inside got in past the door and is jamming it up.
Apr 24, 2012 | Panasonic DMR-EZ485VK DVD Recorder/VCR
Model is Sylvania DVC 840G, DVD/CD player with VCR. Have limited space. VCR on seperate shelf in cabinet, had to put two TV converters on top of VCR (top each side) so we could watch TV and tape a...
The tape mechanism belts have stretched and the unit is not running properly. When this happens, microprocessor is programmed to eject tape and shut down unit.
Apr 11, 2017 | Sylvania Televison & Video
My tape does not completely eject, stays flush with machine then pulls it back in. it never comes complelely out to grasp.
Does the tape door open? Mine would not eject because the door did not open. I removed the door & it works OK without it.
Sep 07, 2010 | Zenith ZHX-313 System
MAGNAVOX DVD/VCR RECORDER
I have been using my machine with no problems, until recently. The machine will not stay on more than a few minutes when I try to use it, either watch a tape or tape a show. It starts, then just shuts down. When the machine is turned back on it ejects the tape????
Can you help, please.
Thanks
Sharon
Jul 07, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Tape keeps ejecting
You can check tape player for any type of object lodged in it. Maybe unplug and turn upside down to here anything inside. Or even any broken tape that come off inside. The only other thing is that the belts inside are worn and will not put device back in play mode.
Dec 22, 2007 | Sony SLV-N55 VHS VCR
Standby
If both decks have a disc or tape in it , the unit shut down because of a power supply glitch or a mechanical trouble shut down the system control system. One way to possibly get them out is unplug unit for a few hours or overnight even better. Before you plug back in press the eject button and hold it in while you plug it in. Dont let go untill the tape comes out. Now if it comes out then unplug the unit anf replug back in and wait a few secs. to let it reset and do its thing. then see if it will turn on and try to eject the disc. if this dosent work then its a power supply problem and its going to need serviceing unless you know your way aroundservo controls and power supplys . Remeber always unplug these units as they do have voltages on the primary side of the transformer that can bite ya. Good Luck
Jun 05, 2006 | Sharp DV-RW340U DVD Recorder/VCR
JVC HR-A592U S-VHS VCR Logo
175 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
