Vertical Distortion The lower 1/2 of the screen has normal display while upper 1/2 is stretched out. My daughter calls this ''Conehead'' distortion. Have tried externsl adjustments to no avail. Is there any chance of recovery from this infirmity
  • cjhhenson122 Nov 28, 2008
    The horizonal picture is to wide
  • 790 Answers
Hi
maybe your unit is in Zoom mode, try to set the Zoom settings...
Thanks!
Posted on Nov 28, 2008
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
Dec 11, 2015 | Sharp Televison & Video
Philips tv/dvd combo picture problems
if stretching is vertical! you have defective parts, like open resistor or change value resistor.
Sep 29, 2007 | Philips 32DV60S 32 in. TV/DVD Combo
Screen stretched out horizontally and distorting picture. None of the settings buttons appear to solve this. I can shift the image vertically or horizontally; but not squeeze it horizontally.
There are adjustments in the size of the items on a screen under the screen properties, settings. If you right click on the desktop screen and then properties you can get there. There is at least one size which causes a distortion of images being displayed. This may be your problem.
Feb 28, 2010 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Vertical Distortion fix for Toshiba 32 inch TV
You have bad capacitors and possibly a vertical IC that is going bad. And check for bad grounds in and around the IC and caps!
Dec 10, 2009 | Televison & Video
Picture images look like conehead midgets
The carat yoke have some spires on short you need to replace him
Jul 04, 2009 | Televison & Video
Distortion in Monitor
Your problem is simply a leaky capacitor on the vertical oscillator circuit on your monitor. Try replacing the ones with 10uF values.
Aug 10, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Color distortion
Move any speakers or electrical devices away from the set. It could also be anything electronic or magnetic. Anything near the set that generates a magnetic or electromagnetic field could be causing the distortion.
Jun 04, 2008 | Zenith A36B41W 36" TV
Screen distortion
Is it a clean vertical line or a fuzzy vertical line? It could be as simple as a cleaning.
Apr 25, 2008 | Hitachi 53SDX89B 53" Rear Projection...
Black horizontal lines across bottom 1/3 of screen
This is due to vertical section failure. Change the vertical supply rectifier diode and supply filters. Then check zener diode leakage in pumpup circuit section. Also check any electrolytic capacitors leakage in vertical section. If it is old model tv change vertical height, vertical lenearity presets also. I hope given details useful to you.
Aug 23, 2007 | GE 27GT722 27" TV
Screen Distortion at certain Refresh Rates
Have you connected the laptop to another monitor and use the same refresh rates that cause the distortion? If the distortion appears on a different monitor, then I would have your laptop examined by a pc engineer, but, if the distortion only appears on the 997DF monitor, I suggest having the monitor checked at a repair shop, also, have you tried connecting the 997DF to a desktop PC, and use the same refresh rates?
Jun 16, 2007 | Samsung 997DF 19" CRT Monitor
Televison & Video Logo
132 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
