Home | Sampo | PME-42S6 42 in. HDTV-Ready Plasma Television | Audio interference
Sampo PME-42S6 42 in. HDTV-Ready Plasma Television
Problem for Sampo PME-42S6 42 in. HDTV-Ready Plasma Television
Audio interference
By dmcsev on Jan 27, 2007
Hi all, I just re-installed all my audio/video equipment after a move, and I'm experiencing a loud buzzing coming from the Sampo plasma TV. Not only is everything in the setup the same as in the last house, but there was no interference last night when I turned everything on. I have the video running from the cable tv port into an HD cable box, then to the tv through component cables. The sound goes from the cable box to a receiver through an optical cable. There are also a DVD and VCR hooked up. Any thoughts on the cause of the interference or possible solutions? Thanks!
Same Problem
May 04, 2009
-   We turned our TV back factory settings and it seems to work but then when we plug in our Cable it does it again. No idea what is going on here but it is driving us crazy. We did change our box and are thinking to going back to the regular digital box since we didn't have this problem before. -   Guest
Jan 06, 2008
-   When we move and reconnected the Sampo plasma, a humming sound is driving me crazy!
We did not change altitudes and everything is connected the same that it was in the last home?
When I turn volume down, I do not hear the humming noise.
Suggestions please?-   tech lacking
Solution #1
posted on Jan 28, 2007
Somewhat Helpful)
tvtek
Rank: Wiz  Televisions & Videos  Expert
Rating: 84%, 1049 votes
Is the sound comming from the speakers on the TV or the back of it? Plasma TV's can doing buzzing sounds when moved to higher elevations.
Comments:
Jan 30, 2007
- Most likely it will never go away period. In fact according to what I understand the life of the plasma display can be reduced somewhat.
Was this helpful?
Yes
No
Solution #2
Not Rated)
Guest
Rank: Apprentice  Televisions & Videos  Expert
Rating: 0%, 0 votes
The sound is coming from the back of the TV, and we did move to a higher elevation (2500' to 5500'). The buzz comes and goes - will the TV acclimate to the new altitude, or are we stuck with this annoyance?
Popular Solutions for Sampo PME-42S6 42 in.
Questions and Unsolved Problems for Sampo PME-42S6 42 in.
Do you recommend Sampo PME-42S6 42 in. HDTV-Ready Plasma Television?
Answer
Answer
my sampo PME-42S6 ha trouble powering on. It will start (blue screen and hour glass appear the turns... (More)
Answer
we have had our tv 4 about 7 years and over the past few months it has been going red! basically if... (More)
Answer
The T.V has all sorts of pink lines and other distortions on the screen if you hit the side of it,... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sampo PME-42S6 42 in....:
Top Flat Panel Television Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Flat Panel Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
