Question about Kenmore 55692 / 55694 Side by Side Refrigerator
Hollow Ice- Slow Ice!!
Over the summer the plastic tubing that runs from the water source to the back of the refrigerator sprung a leak. So I cut the tubing above the leak eliminating where the hole was and rehooked everything up. No Problems... Theone problem that there seems to be is that the machine now produces ice slower then it did before this leak and the ice cubes seem to come out hollow.... Any advice on how to fix the would be greatly appreciated I thank you in advance....... Apps
  • Steven Alperstein Jan 20, 2007
    Checked to make sure that there were no pinches in the line and I reset the line to make sure that there were no pinches. The machine seems be making ice faster but the cubes are still hollow. I also noticed that the tray where the cubes are made does not seem to be filling up all the way across. Only the first couple of slots seem to be filling with water. Is there a way to increase the water flow to the icemaker???
  • 237 Answers
Hollow ice is a dead give away that there is not enough water filling the trays. Check that the line isn't pinched from pushing the unit back in place, etc. Also check any filters or filter screens in the water line to the ice maker.
Posted on Jan 14, 2007
  • Marc Wilson
    Marc Wilson Jan 26, 2007
    If the trays not filling fully across then there is a flow problem or a water pressure problem. There is a small screw on the side to adjust the fill time but never move it more than 1 full turn. That's not usually the solution, the solution is to see why the flow rate is so low (plugged line, low pressure, restricted line, etc.).
We have the maytag refridgerator that has the ice maker. We had it for 2 years without using the ice maker moved then we decided to get the line to get it up and running. Upon the ice being made we noticed...
I would replace the plastic tubing ASAP. After 8 years using the plastic tubing we found our finished basement ceiling leaking water. When we looked into the source we found a hairline crack spiraling along the plastic tube. This must have leaked for several months. The very fine water spray ran down the wall and through the supply line hole in the floor and onto the ceiling. Replace the plastic line with a steel braided one. You wont have any issues with taste or breaking.
Jun 19, 2010 | Refrigerators
Ice cube maker not working. I saw water frozen in the plastic shute leading to the ice trays.I used a hair dryer to melt the ice in the shute. The white gear IS turning. Still no filling of water. Door...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
Jan 02, 2010 | Whirlpool ED2FHEXN Side by Side...
Water from ice maker running through freezer and on to floor
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube and divert the water. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Dec 03, 2009 | Amana Refrigerators
The water dispenser unit has a tube coming into the back of the fridge. Anytime you dispense water, it will also leak from this tube in the back. Also, about once a day or so, it will sound like water is...
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube. You can thaw the fill tube and replace the water inlet valve.
Sep 27, 2009 | Jenn-Air JFC2087HRS Side by Side...
Ice maker leaking inside freezer compartment, water dripping down from unit
Sep 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
1. I am getting black spots in the ice cubes.
multiple probems you have my friend the black in the cubes is the telfon coating on the mold of the imkr and the best thing to do is replace the complete icemaker then this will solve the leak issue as well the mold is cracked and for the some how the 1/4'' tube has sprung a leak pull away from wall take off the back panel and have some one try to get water from the dispenser then you find the leak then its off to the menards to buy a plastic 1/4'' push connector about 5.00 once you got the coupling shut off the water to the tube that goes to the frig once done use a razor to cut the bad part of the tube (don't use sissors or ****to cut tube it will squeeze the tube and not allow it to seal properly in you new coupler you just bought) then after you cut off the bad part out just push into the coupler it will go in to the coupler about 1/4'' into the coupler install the other side turn water back on and test again...... congrat's you fix it but your not done unplug the frig get your vacuum and clean the dust bunnies out of the rear of the unit once done plug back in and make sure you see the fan blade turn freely and nothing is holding it up did it turn ............. ok then put back on and push the frig back to the wall allow at least 2'' away from the wall
Sep 06, 2009 | Amana Refrigerators
Makes ice fine but the water drips down the back of the freezer running into the ice tray - help
Jul 10, 2009 | KitchenAid Refrigerators
Slow water, hollow ice in refrigerator
Sounds like your water inlet valve is malfunctioning. This is a dual solenoid valve located in the back, behind the cardboard cover.
Jun 05, 2008 | Refrigerators
Kenmore 55692 / 55694 Side by Side Refrigerator Logo
160 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Bill
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
