Question about Sony BRAVIA KDL-40S2010 40 in. LCD Television
Sony Bravia KLV-40S200A LCD TV standby indicator blinks 5 times
Hi, I have a 5.5 year old Sony Bravia KLV-40S200A LCD TV. Today I cannot switch it on. The standby indicator blinks 5 times, and stops blinking for about 3 seconds, then blinks for 5 times...Could someone advise what's wrong with the TV? Is there something I can do to fix it? I have already tried disconnect the AC power, but it didn't help.
    Top Expert:
  • Sony Master
  • 14,553 Answers
Here is a link to the service manual--
http://www.scribd.com/doc/46056922/KLV-23S200A-and-Other
Page 11 explains the error codes--unless you are a tech with a meter etc it will be a shop repair.
A lot of good info including taking set apart correctly.
"abnormal power"
SD TECH
Posted on Jun 02, 2012
    New Friend:
Hi i have a sony bravia ex710 .dont power on .and leds lcd 5 star
Posted on Jan 24, 2013
SOURCE:
  • 2337 Answers
SOURCE: Hi I have a Sony
Diagnostic Test Indicators
When an error occurs, the POWER LED will flash a set number of times to indicate the possible cause of the problem. If there is more than one error, the LED will identify the first of the problem areas. If the errors occur simultaneously, the one that corresponds to the fewest flashes is identified first.
LED ERROR DESCRIPTION CODE
1 Supply Voltage Trouble Panel 5V UNReg (10.5V)
2 DE5V Voltage Trouble FE5V (DCALERT2)
3 Voltage Trouble D3.3V/D2.5V/D1.8V. (DCALERT1)
4 Backlight Trouble
5 Main Supply Voltage Trouble (17.5V.DET)
6 Speaker Applied Voltage Trouble
7 Monitor an Increase in Inside-Temperature (esp. on the panel side)
8 Trident IC Trouble
Posted on Apr 18, 2011
  • 8909 Answers
SOURCE: I have sony Bravia KLV
AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Posted on Mar 09, 2011
gopakumarg43
  • 76060 Answers
SOURCE: Good afternoon, Sirs! I bought an
Hello
Blinking of standby light is Sony TVs are fault indication. Five blinks denotes
AKB circuit (AKB), the timer/standby indicator blinks for about
the video. You must have some knoledge in electronics and ability to follow the schematic diagram of TV otherwise called as circuit. Must have a high quality digital multimeter, soldering iron and a concept of soldering. I'll assist you. Must have confidence and more patience. If you have these, inform me by Fixya. I'm happy to assist you. If not, get it repaired by Sony Authorised service center. Any service center, who takes this set for repair, must have all the testing equipemets like oscilloscopes, clour analiser, pattern generator and AVO meter. Without these testing equpments, trying to repair this set will make things mor worse. OK.
Posted on Apr 09, 2011
  • 608 Answers
SOURCE: Hi I have a Sony Bravia KLV-40S200A which wont
I had a similar problem with my 42 Inch Philips 42PLF5432D/37 LCD HD TV. It would turn on but then shut back off after about 10 seconds. Then it wouldn't turn on at all. The problem was a bad capacitor. Several bad capacitors. They are inexpensive and fairly easy to replace if you don't mind digging around in the back of your set and soldering some new ones on your Power Supply Board. Or take the less inexpensive route and look for a whole new Power Supply Board. Good luck. Hope this helps.
Posted on Dec 08, 2010
  • 117 Answers
SOURCE: Hi, I have Sony Bravia KLV-32S400A Couple of
Dear User,
in your case there is a supply fault..capacitor of power board is weak .kindly change the capacitor ..the sign of capacitor faulty is that capacitor is blow up like oil is coming out form upper side..kindly do the need ful.dnt use the lcd until the problem fixed.
Posted on Feb 04, 2011
I have a Sony bravia KLV 32bx300 LCD tv. From like 2 months the tv isn't turning on , it tries to turn on for 3 times with green light on and it stops starting and tv goes to 6 red LED blinks, when th
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Jan 19, 2015 | Sony KLV-32BX300 SERIES BRAVIA LCD...
What could be the problem with my sony bravia klv 40-bx420 lcd flashing red led 2 times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Sidebar" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Aug 11, 2014 | Sony KLV-40BX420 40 1080p Full HD Bravia...
What can cause the sony bravia to switch on then off immediately.
6 flahes indicates a panel error possibly the backlight controller
Jan 31, 2014 | Sony BRAVIA KLV-40BX400 MULTISYSTEM LCD TV...
Hi I have a Sony Bravia KLV-40S200A which wont turn on. The standby button flashes five times then pauses for about 4 seconds then flashes again. Any ideas?
4 Backlight Trouble
Apr 18, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Hi Am working on a sony lcd tv model no. KLV- 19T400A. The problem is that when I switch it on It tries to power but Enters into self diagnosis with the red LED blinking 5 times.
That is a video fault.
Five blinks
- AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video.
Feb 07, 2011 | Sony KLV32S400A 32 in. LCD TV
Dec 08, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Standby Indicator flashes red 6 times between 2 second intervals
My TV (Sony Bravia LCD KLV-32S310A) goes of after 20 seconds when it is switched on. The standby indicator then flashes (red) five (5) times then there is a two seconds break followed by another six flashes then two seconds break etc. What might have caaused this and what should i do?
Apr 13, 2009 | Sony Televison & Video
Sony BRAVIA KDL-40S2010 40 in. LCD Television Logo
3,602 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
