Question about Intel D845GVSR Motherboard
I have an audio device problem
After installing my audio drivers only one side speaker is ON right or left.
I am tried more speakers but this problem is still constant.
In case of headphones this problem is same.
what i have to do please suggest me.
  • Anonymous Nov 28, 2008
    I have the same problem still now
    Master:
  • 505 Answers
Go to the sound properties window. Click on the speaker ooption and make sure the slider is somewhere in the middle so as to get sound from both the speakers.
Thanks
Posted on Nov 28, 2008
I have no sound at all, not sure wot to do. says something about no audio devices are installed,
hello jenz8860, try open device manager (run type devmgmt.msc), if u find question mark on your audio device then u need to install audio driver.
to install audio driver use motherboard driver, insert to CDROM, right click the audio device on device manager then update driver. choose recommended option then click next and follow the instruction. your audio device will automatically installed. if it success installed then u need to restart your PC.
if there is no problem in device manager, high possibility it's on hardware problem, try to see cable connection between speaker and PC (use back panel connection, don't use front panel audio, this to make sure the connection is good), if it's ok then mostly problem came from your speaker. try to use another speaker.
hope this useful, regards.
Aug 26, 2011 | Audio Players & Recorders
Sound comes out of all speakers but the sound from the left speaker plays through the left, right, and sub. instead of just the left speaker. so i have guitars coming out of the sub and bass coming out of...
you might have to select stereo speakers in the drop down list
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
hope this helps
dont forget to vote
Jan 31, 2011 | Kinyo PS-107 Computer Speakers
Audio sound is not normal
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
also
hope this helps
Jan 28, 2011 | Packard Bell Speaker Computer Speakers
My lap sound problem..
Some things you need to check
1. Cable connection of the speaker to your computer and the power cable if its plug in correctly. Normally the Audio cable of the speaker is plugged into the green audio port on the computer.
2. You speaker is on mute. Check the speaker icon located on the lower left side of you desktop. If its on mute then try to un-mute the volume and test the speaker.
3. The driver is not installed properly. Check the device manager if there is a Question/Exclamation mark on the Audio devices.
4 If everything are Ok. try to plug the Audio cable of the speaker to any of your Portable sound devices like Ipod. If that still does not work then you need to replace the soundbar. Contact Dell for a free replacement if still under warranty.
Thank you.. Hope this helps..
Jan 04, 2011 | Dell AS500 Sound Bar Computer Speakers
There is a sound problem. i installed window xp recently , after that i installed drivers everything is done but sound driver is not performing so please tell me solution right now
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers if you have tried this you might try
control panel,administrive tools,computer management,device manager,sound,right click select properties to either troubleshoot,uninstall,rollback driver or scroll to sytem speaker right click select properties you will see at the bottom use this device enable/disable this device
hope this helps
Nov 26, 2010 | AMD Sempron 2800+, 1.6 GHz (G54222)
No sound coming from the left speaker.
control panel,administrive tools,computer management,device manager,sound,right click select properties to either troubleshoot,uninstall,rollback driver or select system devices from the device manager scroll to speaker right click to update driver,disable,scan for hardware changes or select properties to troubleshoot,then select driver to uninstall,rollback,uninstall then reinstall
hope this helps
Nov 24, 2010 | Altec Lansing ATP 3W Computer Speakers
Computer dont recognizing audio device (no sound device?) after installation of windows 7. a tried to deinstall and reinstal realtek hd audio drivers, and its still the same??
hope this helps
Nov 10, 2010 | ASUS M2N68-AM SE2 Motherboard
Crackling when i manipulate the volume control... little or no audio out of the speakers intermittently
hope this helps
Nov 01, 2010 | Klipsch ProMedia Ultra 20 2 Speakers
Problem in my speaker........
goto CONTROL PANEL>Sounds & audio Devices(icon). goto VOLUME, far left menu option.Just under VOLME you should see a ICON of a speaker & the name of the audio device\driver. [If you don't u don't have a audio device INSTALLED] Make sure that the MUTE is not checked.,place a check ['place volume icon in the taskbar] ( that is the RIGHT bottom)On the left bottom of the same"volme" click "speaker volume" and raise the volume. GOTO >SOUNDS(sbmenu)>program events(windows>Asterick,Close Prgram,critical Battery Alarm,Critical Stop,Default Beep,etc,etc)
UNDER:: sounds, look & see if a sound is "taged", just to the right there is a "right" arrow that should be BLACK. When you touch the "arrow" the sound that u "taged" should sound.(1st) goto AUDIO >Default device: you HAVE to see some type of "audio device" e.i. Sound Blaster, Conexant AMC ,ABC Bananers,some type of audio device! If not, left click mouse DARK "arrow" down to see if you have some type of adio device\driver.If so chooze it.(2nd) goto VOLUME AND raise the volume.(3rd) Go back to "sounds" & while you click the dark arrow facing right, connect the speaker jack to the back of the "FEMALE" port.Sometimes they are not marked and you could connect to the wrong port.example: mike in instead of speaker out. understand!
Jul 18, 2008 | Audio Players & Recorders
Intel D845GVSR Motherboard Logo
26 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
