Question about Hotpoint FFA60 Bottom Freezer Refrigerator
The red light remains on...
I've checked the coils inside the freezer for ice and found some,after defrost and switching back on, after a while I found the fan working ok.But the temp remains just under fridge temp level and the red light remains on, even with fast freeze switched on. Help?
  • 237 Answers
The coils should have a nice white frost pattern evenly on the coils (no solid ice block sort of thing). If there is very little frost, or say just chunk of ice in one spot, then you may have a leak in the system where the refrigerant has leaked out. The fan above the coils should be on when the compressor is running to circulate the cold air. It does sound like you may have a sealed system leak and there's just not enough refrigerant to flash into a gas for proper cooling. Check on these items and get back to us.
Posted on Jan 14, 2007
Freezer side not freezing
Check for ice / frosting inside the freezer .... If present you probably have a defrost problem.... This causes the freezer coil to ice up and block the air flow ... the causes could be a bad defrost heater , defrost timer, defrost sensors, or control board. Also make sure that the condenser coil is clean. remove ALL dust with a vacuum and a coil brush .the coil is located either on the bottom or on the back side of the unit... You didn't give the Make and model #
Apr 04, 2014 | Freezers
Maytag model MSD2351HEQ freezer side is not working, refridgerator is cold
f1cdedb3-5e7c-47c1-8d68-7566d4da0a75.jpgSounds to me you may have a defrost failure. In most cases the fresh food compartment will show signs first but your model has an auto damper that may be causing the fresh food section to remain cold. Do you notice frost build up on the rear inside back panel of the freezer? Example HERE. If you do you will need to manually defrost the freezer, remove the rear panel of the freezer and use a hair dryer to melt the ice covering the evaporator coils. Example of ice/frost build up on the evaporator coils HERE The most likely cause for the problem is a defective=> 12002495 Defrost Control Board The defrost board is found inside the fresh food section and inside the control panel. Item 12 in this photo HERE is the defrost control board. Second possibility is the=> 67004948 Defrost Heater Item 7 in photo HERE and is the 67004757 Defrost Thermostat and that item location 3 HERE First the defrost control board needs to be checked for burn marks or signs of heat damage. I am here if you would like me to help you get to the parts I listed above, Thanks Sea Breeze
Aug 09, 2013 | Maytag Refrigerators
Kenmore 253. 9287413 Can't get the freezer to get cold enough. Freezer alarm keeps turning on and the temperature is only 25 degrees inside. Temperature alarm light stays on all the time. Quick freeze...
You can fix this, just follow the procedure given to enable get back your refrigerator going,
Check the temperature setting
Assure that there is enough room for air flow in the freezer or freezer
Check for air flow restrictions in vents
Test the temperature control
Clean the condensor coils
Check the door seals
Test the door switch
Test defrost heater
Test defrost timer
Test evaporator fan
Check for a clogged drain tube
Check for refrigerant leak
Freezer is too cold
Freezer is noisy
Hissing and popping is normal, it is the defrost heater.
Check that the freezer is level
Check the drain pan
Check the condensor fan
Check the evaporator fan
Inspect the compressor mounts
Freezer runs continuously
Defrost the freezer
Freezer starts and stops frequently
Check the outlet voltage
Test the condensor fan
Test the compressor relay
Test the overload protector
Test the compressor motor
Freezer does not defrost automatically
Test the defrost timer
Test the defrost heater
Test the defrost thermostat
Freezer has an unpleasant odor
Remove spoiled food
Clean freezer interior with a solution of h
Clean freezer interior with a solution of hot water and baking soda
Clean the door seals
Remove breaker strips and check for wet insulation
Water on floor outside of freezer
Check the drain pan
If you have an ice-maker, check the water supply hose going into and coming out of the water inlet valve
Water inside the freezer
If you have an ice-maker, check freezer and ice-maker for level
I hope this will help in solving the problem......
May 10, 2011 | Refrigerators
I have an amana fridge model # arb190rcw.nothing remains frozen in the freezer.and i have noticed ice on the back wall of the freezer compartment
Your cooling coils have frosted so much that there is ice forming allover the cooling coils and preventing the actual cooling inthe fridge. First of all shut off the fridge for about 10 hours and wait for all the ice to defrost. Clean up your fridge well and then check inside of the freezer compartment for break in wiring, failure of the heater or the thermostat. Now put the fridge on and see if the cooling comes back.If the set works ok then dont worry till you experience the same fault coming back. In this case your auto defrost timer could be faulty as it is not doing the 8 hours cycle defrosting. Check this out test and replace . Get help if you are not familiar. good day
Jul 31, 2010 | Amana ARB190RCW Bottom Freezer...
Ice maker won't work and freezer is not freezing good
Take a look inside the freezer at the back wall. See if there is ice built up on it. If you have ice or frost on the panel, you either have a bad fan are you having a defrost problem. If I had to guess I would say a defrost problem. Unplug the fridge and remove the panel. Use a hair dryer to defrost the ice. There is a coil inside the ice so DO NOT TRY TO CHIP THE ICE OUT. just take the time and defrost it. After that is done, if you know how to use a multi-meter. You can check the heaters (Found inside the coils) to see if they have continuity. I would bet they don't. If I'm correct, you will need to replace the heater. Until you get the part or have someone to repair it, you can replace the panel, plug it back in and your fridge will work normally for around three days or until the coil builds ice back on it. This will give you time to either fix it or have someone to take care of it for you.
Aug 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer doesnt freeze and red light at top came on
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
thumbs up
Aug 17, 2009 | Freezers
Freezr coil, vent and back panel of kenmore iced and not cooling
HI, Your auto defrost cycle has gone bad. Remove the rear inside freezer panel and check continuity on the defrost heater and bi-metal switch. The bi-metal has to be cold when testing it. If both parts show continuity, you will need to change the defrost timer.
I hope this helps you. Please let me know if I can assist you further.
Vic
May 27, 2009 | Refrigerators
Ice is forming around fan in back of freezer compartment
The defrost system is not doing it's job. I bet if you took the panel off below the fan you will see more ice on the cooling coils. There should be a light coat of frost on the coils but not a heavy ice build up. There is a heating element at the bottom area of these coils which should be defrosting all this ice.
1. A defrost timer turns this heating element on.
2. The heating element melts the ice.
3. A thermo disc attached to the coils will turn the heater off.
One or more of these are not doing it's job.
Dec 16, 2008 | Frigidaire Refrigerators
Hotpoint Ice diamond fridge freezer both green & red lights on.?
bulmer...it takes about two days to fully defrost these units unless you take the freezer section cover off and use a heat source. If you do...be sure to protect yourself against water and electricity mixing....not healthy. See below for another note.
clean the condenser coils below the unit.
check for the amount of gas in the unit. It must be off for half an hour. Remove the back fiber panel. The big thing is the compressor. Clean off the largest pipe coming out of it. Plug the unit in...watch out for the fan! The pipe should frost up and then clear off or stay wet after about 5 minutes. It should not be frosty. If it is, you need refrigerant.
Note: If you do remove the inside freezer panel and defrost, you can see how much refrigerant you have in your unit. Start the unit. Wait 5 minutes and observe the coils. They should be evenly frosted end to end. If approximately so, you're good. If not, you're low on gas.
Dec 17, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Hotpoint FFA60 Bottom Freezer Refrigerator Logo
161 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
