Question about SanDisk Sansa e200 MP3 Player
Hardware wont install
I am getting a "This device cannot start. (code 10)" after trying to get it to the usb mass storage device.
I had the same problem with my e260 4GB player. To upgrade the firmware to enable setting USB mode to MSC, try the following;
e200v2:
1. Slide the hold switch to the locked position by sliding switch at the top of the player towards the headphone jack until you see the orange indicator.
2. Press and hold the << (rewind) button.
3. With the << button held down, connect the player to the PC.
Once I did this, the firmware was upgrade, the USB Mode command was available in the Settings. I switch to MSC, plugged in the player again, and now Windows recognozes it.
Posted on Nov 29, 2008
Dvd player doesn t work
The Code 10 error is one of several Device Manager error codes. The Code 10 error will almost always display in the following way:
"This device cannot start. (Code 10)"
Details on Device Manager error codes like Code 10 are available in the Device Status area in the device's properties: How To View a Device's Status in Device Manager.
Important: Device Manager error codes are exclusive to Device Manager. If you see the Code 10 error elsewhere in Windows, chances are it's a system error code which you should not troubleshoot as a Device Manager issue.
Cause of the Code 10 Error
A Code 10 error is generated when Device Manager can't start the hardware device, a situation usually caused by outdated or corrupted drivers.
A device may also receive a Code 10 error if a driver generates an error that Device Manager doesn't understand. In other words, a Code 10 error can sometimes be a very generic message indicating some kind of unspecified driver or hardware problem.
Error Code 10 Troubleshooting
1.Restart your computer if you haven't done so already.
There is always the chance that the error Code 10 you're seeing on a device was caused by some temporary problem in Device Manager or with the hardware. If so, a reboot might fix the Code 10 error.
2.Did you install a device or make a change in Device Manager just before the Code 10 error appeared? If so, it's very possible that the change you made caused the Code 10 error.
Undo the change if you can, restart your PC, and then check again for the Code 10 error.
Depending on the changes you made, some solutions might include:
•Remove or reconfigure the newly installed device.
•Roll back the driver to a version prior to your update.
•Use System Restore to undo recent Device Manager related changes.
3.Reinstall the drivers for the device. Uninstalling and then reinstalling the drivers for the device is a likely solution to a Code 10 error.
Important: If a USB device is generating the Code 10 error, uninstall every device under the Universal Serial Bus controllers hardware category in Device Manager as part of the driver reinstall. This includes any USB Mass Storage Device, USB Host Controller, and USB Root Hub.
Sep 14, 2013 | Dell Dimension E510 PC Desktop
One day, I uninstalled USB Mass Storage Device along with a bunch of other ones (eg. USB Root Hub & some other ones) The USB Root Hubs and the other ones re-installed but the USB Mass Storage Device...
The hubs were most likely the USB hardware that is a part of your computer, but the USB Mass Storage Device is a part of some hardware that you had plugged in at some point (maybe a USB flash drive, maybe a USB external drive). In order to reinstall the Mass Storage Device, you have to plug that hardware back in and let it reinstall. If you aren't aware already, sometimes you plug in one device, but it installs as more than one device (it's actually supposed to). So you won't always have a one-to-one ration of hardware and installed devices, since some of them show up as more than one device. And typically, when plug a new device in for the first time, the computer can only see one device, then it instals that one device, and only then can it see the other (virtual) devices, which it then installs. The next time you plug that device in, it sees & activates all of the devices instantly & silently (not counting the little "plug in" sound it makes).
Aug 08, 2011 | Microsoft Windows XP Professional Full...
Error code 10
How to fix the error
"This Device Cannot Start. (Code 10)"
When working with a USB device in Windows XP
If you have plugged in a USB device (usually a mass storage device) into a computer and it won't work, here are some basic troubleshooting steps to resolve the problem.
First, you want to rule out any problems with the device itself. A good way to do this is to plug the USB device into a different computer to see if it works there. If it does not work in a different computer, then the problem is with the device itself. USB devices, although very handy and portable, can fail just like any other device.
However, if the USB device works in another computer system, then the problem lies with the configuration of the computer where the device did not work.
Follow the steps below to troubleshoot this scenario and make your USB device work again.
1) If you are using a USB cable with your device, check the cable to make sure it matches the speed of the device. Use USB 2.0 cables with USB 2.0 devices and USB 1.1 cables with USB 1.1 devices. Swap cables and check the device, if this does not work, proceed to Step 2.
2) Next, open Device Manager and look under the heading for USB Serial Bus Controllers. If there is a device with a yellow exclamation mark next to it such as USB Mass Storage Device. Double-click on the entry and check the Device Status. If the status shows something like
proceed to Step 3.
3) The easiest way to solve a USB error code 10 in Windows XP is to follow the steps below to remove and reinstall all USB controllers.
A. Click on Start
B. Right Click on My Computer, click on Properties
C.Click on the Hardware tab
D. Click the Device Manager button.
A. Click on Start
E. Expand Universal Serial Bus controllers section.
F. Right-click every device under the Universal Serial Bus controllers node, and then click Uninstall to remove them one at a time.
G. Restart the computer, and allow the computer to reinstall the USB controllers.
H. Plug in the removable USB storage device, and then test to make sure that the issue is resolved.
For more information on Troubleshooting USB device problems, visit the Microsoft Support Article on this subject.
Mar 06, 2011 | Computers & Internet
WITH SERVICE PACK 3 (WIN XP) MY 795 IS "DISCONNECTED" NO MATTER WHAT! PLEASE HELP!!
The iFP-795 is a player that has connection type UMS
(also called MSC): seeing the player as a removable disk:
Go to next site to see the connection type:
http://www.iriver.com/flash/index.asp?code=0300
and click on connection. Scroll down to see the iFP-700 series listed in the connection type UMS.
UMS = Universal Mass Storage
MSC = Mass Storage Class
With XP sp3 the computer Operating System has setup USB connections with new drivers, that support both UMS (= MSC) and MTP connections.
MTP = Media Transfer Protocol
When you experience next making connection:
Connecting the device to the computer Wizard found new hardware pops up.
Only this time the Windows update searching for software will not work on automatic routine: ending up with "Cannot Install this Hardware".
Manual performing the wizard, setting the device to USB connection type:
1. Can Windows connect to Windows Update to search for software ?
Select "No, not this time".
[Next]
2. If your hardware came with an installation CD, or floppy disk, insert it now.
Select "Install from a list or specific location(Advanced)."
[Next]
3. Please use your search and installations options.
Select "Don't search I will choose the driver to install."
[Next]
4. Select the device driver you want to install for this hardware.
Select "USB Mass Storage Device."
[Finish]
Just post a comment if you need more help.
Sep 24, 2009 | iRiver iFP-795 MP3 Player
Sony Walkman NWZ-S736F MP3 wont connect it charges but dosent show up on the content transfer
Uninstall problem MTP device in device manager. Reinstall it as a USB mass storage device. It should connect to the USB port. Unintall that USB mass storage device. Scan for hardware changes. It will find your mp3 player and install it. In the window to choose what action to take, choose sync music. Media player will open and connect. So then, will your other apps.
Jul 11, 2009 | Sony Electronics - Others
My new hardware might not work properly(no detection)
ok
if your storage device not wortking properly.
Go to device manager and uninstall usb drivers from computer then install again.
May 28, 2009 | Mass Multimedia Apricorn Mass Storage...
I installed my sony NWZ as MTP device, but now i want to go back to simpler UMS (standard usb connection) ive tried removing the mtp drivers from device manager, but it always just auto installs... Can...
Since there's no easy option in the Walkman's settings to switch back and forth between MTP and UMS, there's a little trick to un-do the MTP drivers so that the unit becomes a straight USB Mass Storage drag/drop unit. You have to go into Device Manager (Windows XP), find the Walkman in the Portable Devices group, right click, then select Update Driver. Then select "No, not this time", then Next. Select "Install from a list or specific location (Advanced) then Next. Select "Don't Search, I will choose the driver to install", then Next. (Be sure to check the box beside Show Compatible Hardware) Highlight USB Mass Storage Device, then Next. (To revert back to MTP, just do the same thing but choose MTP instead of USB Mass Storage Device.) Personally, I'd never go back to the MTP mode. Having the Walkman seen by the computer as just another USB mass storage device allows the drag/drop transfers to go much faster
May 05, 2009 | Sony NWZ-A829 Digital Media Player
2GB Sansa e250 won't connect to my PC
Hello!!!
Try connecting it to different USB!!
Nov 02, 2008 | SanDisk Sansa Clip MP3 Player
For God's sake help me!!
MAKE SURE YOUR SANDISK IS PROPERLY CONNECTED TO YOUR COMPUTER THEN-GO TO YOUR START MENU-CLICK ON CONTROL PANEL-THEN CLICK ON SOUND SPEECH AND AUDIO DEVICES ON THE BOTTOM CLICK ON PORTABLE MEDIA DEVICES AND FOLLOW THE STEPS YOU COMPUTER GIVES YOU. GOOD LUCK AND I HOPE I WAS ANY HELP TO YOU.
Jun 30, 2007 | SanDisk Sansa m250 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
82 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
