Question about Maytag SAV365ZAWW 3.3 cu.ft.
Washing machine will not spin dry but washes properly
Observing from front lower panel removed:
Washes properly with upper and lower plastic "clutch" engaged.
When put into spin mode the upper and lower clutch assembly attempt to engage, slip, chatter, and the drum barely turns.
It appears that there might be a locking pin that should drop into place to hold the drum shaft to the driven pulley in the spin mode.
Thankyou,
    Sergeant:
    Champion:
  • 311 Answers
If nothing is worn in that pulley/cam area then the transmission has gone out. Thanks, please leave feedback or contact me again for more info if you need it.
Posted on Nov 29, 2008
Simpson eziset750 washing machine that washes but don't spin
Lid switch / drip dry botton on / wash/spin solenoid fried /
Aug 12, 2013 | Washing Machines
Machine wash ok but would not spin to take the water out of the clothe
Usually, this problem is due to a clog in front of the drain pump not allowing water to drain properly.
Remove the front lower panel by removing the 3 screws along the bottom (front).
The large plastic (3") cover of the "coin-catcher" in front of the pump then needs to be removed. It is easily seen facing you when you remove the front lower panel. **WARNING** All the water from the tub will come flooding out. I like to use a shop-vac with the nozzel placed at the bottom of the cap as I unscrew it SLOWLY!!!
The coin-cathcher (lint filter) is part of the cover and you will find it loaded with years of ****.
Jeff
Apr 27, 2011 | Kenmore 43142 Front Load Washer
The washing machine washes and rinses then it will not spin when we open door it floods - help please
Remove the lower access panel and clean out the drain pump.
Also use less soap to help prevent this problem.
Apr 04, 2011 | Whirlpool Washing Machines
Amana washing machine (ALW880QAW). Does not work in spin cycle. Washer works ok in wash cycle, and in draining water, just the new belt is too loose when it switches to spin. It just burns up the belt....
probably the lid switch is faulty,remove screws behind control panel,then pull control panel toward you and lift up and lay back,now remove 2 screws in the lower front panel by the floor and remove the cover,then 2 more screws to remove upper front panel above the lower one,then 2 more screws in front hold the top on then raise top up like a car hood and the lid switch will be under the top cover
Mar 23, 2011 | Amana ALW880WH Top Load Washer
Machine washes o.k. but does'nt spin dry (hoover soft wave auto - washer 1000 )
If you have not already done so, I suggest you remove the motor, and check the brushes for wear.
Please rate my solution.
Thanks.
Oct 08, 2009 | Hoover AAA160 Front Load Washer
Ge washer
remove top cover by 3 screws on rear then 3 screws in plastic control panel back. remove screws holding console on, lift up to remove, screw in dispenser area as well. remove lower kick panel and lower front panel screws. remove door lock screws and wire clip around boot. remove 2 upper front panel screws. there is another wire clip around boot at tub.
Apr 22, 2009 | GE WBVH6240F Front Load Washer
Machine wont go into spin cycle
The pump fiter is probably blocked.
Remove lower rear panel of washer.
Locate, and remove large black hose on bottom of tub.
Remove plastic filter inside, and clean.
Refit filter and hose.
Should now be o/k.
Before you do anything, lay the drain hose down into a bucket or bowl, and drain all the water out, so you do not have a flood when you remove the hose.
please rate my fixya solution.
Thanks.
Feb 01, 2009 | Hotpoint Aquarius WD640 Front Load...
CLUTCH MAY NEED TO BE REPL/ IF DOES NOT SOLVE REP/ TRANSMISSION
Nov 28, 2008 | Maytag SAV365ZAWW 3.3 cu.ft.
Fills washes rinses but wont spin properly or empty out washer, ends cycle half done, wont pump water out or spin out. i can hear the machine hum while trying to do so. Please any ideas. THanks
its likely the pump is blocked (hence the humming) with a coin or some foreign object. To check, lower the outlet hose to ground level to allow the water to empty. Tip machine back & lean against a wall, remove the pump & remove object if there is one! Reassemble & try machine again
Oct 19, 2007 | Hotpoint Aquarius WF215 Front Load Washer
Washing Machines Logo
155 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
