Question about Memorex MVD2042 DVD Player
Dvd pauses quite often as its playing
When a dvd is playing it keeps pausing quite often then it will stop doing it...then it does it again...then finally freezes....i played the same dvd on a different dvd player and it doesnt do it....i did clean the lens and the dvd.....but it still does it...what could be causing the problem?
  • FNorm Feb 08, 2009
    I have the same problem with my Sanyo, I dry cleaned the lens, blew canned air in the player, washed the disk and still have the problem with one particular movie, which worked fine when we first played it. The player plays other cheap one dollar movies but has problem with the occasional upscale movie.
    Master:
  • 505 Answers
The entire tray needs to be replaced.
Thanks
Posted on Nov 28, 2008
How do I pause while recording? I can pause while playing back but can't seem to figure out how to pause a recording then resume, it just stops and starts a new clip. Please help. (My handycam is cano
The default is to start a new clip every time you press the stop button, but in settings you might be able to tell the camera to continue with the same clip provided you press record again with a set time. Not sure why you want to do this though - it's much easier to edit using small clips than very large ones.
Aug 23, 2014 | Canon FS100 Flash Media Camcorder
Suddenly stops recodring
I love my Sanyo mp3 recorder I've been using it in church for 4 or 5 years. It never quits it can hold an extra gig with a chip and i can plug it into my computer to upload it in seconds. I say replace the old recorder
Nov 17, 2013 | Alesis Masterlink ML-9600 w/ Audio...
Hi, I recently purchased a Panasonic DVD S48 dvd player. I was assuming when I bought it that it was a multiregion product. This seems not to be the case as it will not play region 1 dvd's that I...
hi Pjkgbr.
this is all i could find out, now if you do try this do so at your own risk.
This hack requires the S48 remote plus a universal remote configured for the S48 with a separate 'Pause' button (or another Panasonic DVD remote with a separate 'Pause' button may work).
I used a cheap universal remote.
1. Select DVD device on remote.
2. Hold magic button until the DVD button blinks twice.
3. Enter device code 0490 (DVD button blinks twice)
Neither the 'Play/Pause' nor 'Frame' buttons on the S48 remote work for this hack.
1. Power on.
2. Open tray.
3. Using the S48 remote press Audio, 1, 9, 8, 2, Subtitle
4. Using the other remote (URC 7562) press Pause.
5. Using the S48 remote press 0.
The DVD front panel should now show the text "on".
The DVD should now be region-free. Region code hack posted by spook65, December 12 2012:
DVD-S48EG-K (Region 2)
This is the process for unlocking, the Panasonic DVD-S48 for
multi-zone.
Please note, you will need a universal remote control which
has a PAUSE button in order to unlock this player.
1. Turn the power ON
2. Open the disc tray
3. Using the remotes, press AUDIO 1 9 8 2 SUBTITLE PAUSE 0
4. Switch the player to STANDBY and then switch ON again.
The display should read ON after you enter PAUSE 0.
If this doesn't happen, switch the player off and start the
sequence again.
The remote supplied with Panasonic player has a PLAY/PAUSE
button rather than a separate PAUSE button. If you use the
PLAY/PAUSE button, the tray will close and the unlock
sequence will be aborted.
To get round this, you need a universal remote set-up to use
with the DVD player. After pressing SUBTITLE on the
Panasonic remote, quickly press the PAUSE button on the
universal remote, then press 0 on the Panasonic remote to
complete to unlock code entry.
or this one.
What is the process for Multizoning a DVD-S38 / DVD-S48 / DVD-S58 / DVD-S68 / DVD-S500 / DVD-S700 DVD Player? Providing your DVD Player is one of the below models, you can multizone the unit yourself using the remote supplied with the product and another Panasonic product remote thas a Pause button on it
Applicable Models:
Multizoning Process:
1. Power on the unit and open the disc tray
2. Using the remote that came with the player, press the following buttons in sequence
3. AUDIO 1 9 8 2
4. SUBTITLE
5. Using the other Panasonic Remote (not the one that came with the player), press the PAUSE button
6. On the remote that came with the DVD player, press the 0 (zero) button
7. If you have followed the above process correctly, the word ON should be shown on the front panel display of the player*1
*1 Please note: The models DVD-S500 and DVD-S700 do not have a front panel display,
so the only way of confirming that the multizoning process has been done correctly, is to
try playing a DVD disc from another region code other than region 4
Dec 05, 2017 | Televison & Video
Video and audio stops and starts repeatedly, like a dvd or cd skipping. It does this for streaming and downloaded videos and music.
The streaming and download speed cannot keep up with the playing speed of the video or music so when the buffer for the incoming data is emptied, the player has to stop until more data arrives. Depending on the player, there may be a setting for the minimum of data present in the buffer before it starts again. If the player is manually paused (by clicking on its pause button), the streaming and downloading should continue until it is completely stored in local cache and after resuming play, it should be without anymore starts and stops. However, player pausing for some type of streaming stops the incoming data stream as there is no local cache so in this situation, there is no advantage to be gained by pausing the player. The incoming speed is determined by the speed of the slowest link that the data must traverse so even if the local link is extremely fast, there may be slower or more congested parts of the internet that are acting as a throttle.
Mar 22, 2011 | Acer Aspire One PC Notebook
When we pause our DVD player, the DVD goes back to the beginning of the movie. Is there a way to keep it at the place we paused?
hit stop and if a screen tell you if you want to start where you left off turn off now or if you want to
start at the beginning then press stop again or words to that effect) Do so
Feb 22, 2011 | Televison & Video
HOW DO YOU BURN A DVD ON A SONY DVD RECORDER RDR
Make sure your Sony input signal is on L1 or L3 (the inputs in back of recorder) or on L2 which is for inputs for cameras(located in front).Once you get a signal, you're where you need to be. Choose your recording mode for recording speed (pull down the flap on the remote control for this button and also the input button).
Choose from between1 hour and six hours. To archive really important stuff, stick with the first 3 speeds. TV recording can be on 3, 4 or 6 hour mode.
Push the record/pause button once. This will put the recorder into the record/pause mode and then it awaits you pushing it again to start recording immediately. Just pushing record will force the machine into a 3 to five second delay before actually recording anything so you might mess up and miss the first few seconds of your input. Suggest you use a dvr-rw or dvd+rw to practice on.
When your recording is done, just push the pause again. It stops recording but allows you to add more on to the first recording without starting a new chapter if you want. Just continue to release the pause button to continue.
If you are satisfied that you are finished, then push the pause button to stop recording. Wait for the info to be written(flashing message on screen). When it stops, you may play the dvd.
Notice- since the dvd has not been FINALIZED, you may only play it back on this unit without finalizing. It will not play on other dvd players unless you finalize it first.
To finalize, look on remote for the TOOL button. Press it once. Now push DISC INFO once. Use arrow keys and enter button on remote for the following. Scroll down to FINALIZE and press enter.
Use arrow keys to scroll to OK. push the ENTER button. Finalizing should take between 30 seconds and 2 minutes.
Warning- if titles or chapters are to typed in, it must be done BEFORE finalizing. Finalizing afterwards cannot be done.
Erasing can be done in part or all if using an RW+ or RW- disc
Dave
azsnoopy1@cox.net
Nov 19, 2009 | Sony RDR-GX300 DVD Recorder
DVD burns properly but keeps pausing and skipping
Decrease the recording speed. Record at, for example, 8x speed. 4x might be even better. This will solve you problem.
Aug 14, 2009 | Computers & Internet
Brand new DVD videos freeze while being played back
THis is a very common problem (you can see quite a bit of complaints like this)...complain to Sony and tell them that it is a common problem...
Apr 12, 2009 | Televison & Video
Screen says loading and after a while, says disk error.Then eject
hi try first to insert a clean up CD, and test your DVD player with an original DVD, if the problem persist , your laser sense is defficient you have to go to fix it to a specialist.
hope this helps you
sserpentio
Re: Panasonic Remote Control for DMR-ES35V
All you have to do is unplug the power cord from the unit, wait 10 seconds, and plug it back in. The reboot will make your remote work again. Actually, it is the UNIT that is faulty, not your remote.
Jun 25, 2008 | Panasonic DMR-ES35VS
Memorex MVD2042 DVD Player Logo
194 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
