Question about GE JVM1860 Microwave Oven
Charcoal Filter Replacement
I have a JVM1860 which recirculates. I am getting a reminder to replace the charcoal filter, but the instructions are not working. It says to remove the two screws on top of the vent to remove the vent, but there are no screws visible. There are only two screws behind the stainless steel vent door which flips down. I removed those screws but they don't appear to be holding the vent frame on. Please help?
  • 1 more comment
  • MIchael Nyman Jan 15, 2007
    This is directly from the directions that I have, but there are no "two screws" at the top of the grill. Where are these mysterious screws?
  • Anonymous Mar 20, 2014
    Remove vent
  • Dan chore
    Dan chore Mar 22, 2014
    You might check in the vent itself.. I think it is the third vents in from both the left and right. You may need a flash light.
  • GE Master
  • 9,098 Answers
Be sure the oven is disconnected from the wall first. Then open the door. Remove the two screws from the top of the grille. Next, slide the grille to the left to remove it. Before you slide the charcoal filter out, be sure to note how it rests at an angle on 2 side support tabs and in front of the right rear tab. After it's replaced, you can press OPTIONS until you come to the Charcoal Filter Reminder. Then you can press 0 to turn the reminder off, press 1 to set the reminder, or press 3 to turn the reminder on.
Posted on Jan 15, 2007
  • William Miller
    William Miller Jan 15, 2007
    Odd. You may have to call the GE Answer Center at 1-800-626-2005. They're available 24 hours.
2 Suggested Answers
SOURCE: Charcoal Filter Replacement
I have the same model. There are 2 sscrews that hold the grill cover on. One problem might be that your cabinet are covering those screws. They are both located about 1" back from the front edge of the door. The left side is about 3.5" from the left edge & the right side is 8.25" from the right side of the unit. My cabinets are 12" deep & I am able to access the grill cover screws with no problems.
Posted on Apr 03, 2007
Does the maytag mmv1164ww1 micro/hood combo require outdoor venting?
No .. it can also be recirculated . you will need charcoal filters if you do so. There is a specific charcoal filter for each microwave hood. Any appliance part dealer would carry it ( you will need to give them the micro hood model number ) or you can order them online through Whirlpool parts website ( whirlpool owns maytag)
Mar 14, 2011 | Microwave Ovens
How do i install the ge jx81d recirculating charcoal filter
You can download GE owner's manuals and installation instructions here.
It will show you how to do it.
You can find helpful exploded view diagrams and order parts (and accessories like charcoal filters) by entering your full model number from the tag on the oven here.
Jan 23, 2011 | GE JVM1790 1000 Watts Convection /...
The Charcoal Filter (JX81C) used for non-vented GE Spacemaker over the stove microwave (JVM1540SM2SS) does not fit anywhere (after pulling off the grill).
This of course assumes that your oven has the optional Recirculating Charcoal Filter Kit (part # JX81C available here) already installed.
From the owner's manual here:
Nov 27, 2009 | GE Spacemaker JVM1540 Microwave Oven
Where is the charcoal filter?
There is no charcoal filter unless you replaced the standard filter with a carcoal filter. Also, it may have m=been changed to a charcoal filter if the unit was alterd during installation as a re-circulating vent, not vented to the outside via the roof or wall.
The filter (Charcoal or not) is on the bottom of the unit. Put your head under the microwave and look up, there it is.
Apr 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave message says to replace charcoal filter. User manual states charcoal filter is used if unit is not vented outside. Our unit is vented outside
External vent systems have the charcoal filter removed, generally at the time of installation, as it is not needed for this application.
The charcoal filter removes odors from internal recycled airflow.
There should be an aluminum grease filter that you can remove to clean in a warm soapy solution, let dry, and reinstall.
May 27, 2008 | GE Microwave Ovens
How to clean the air filter of my goldstar microwave model # MV1526B/01
That sounds like the charcoal filter. It cannot be cleaned, and must be replaced. From the owner's manual:
CHARCOAL FILTER REPLACEMENT
If your oven is vented inside, the charcoal filter should
be replaced every 6 to 12 months, and more often if
necessary. The charcoal filter cannot be cleaned.
To order a new charcoal filter, contact the Service
Center.
1. Remove the two vent grille mounting screws.
(2 middle screws)
2. Tip the grille forward, then lift it out
To get a new filter, you can try local appliance parts stores or see customer service or find servicers here: http://us.lgservice.com
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Apr 13, 2008 | Goldstar MV-1526 Microwave Oven
Jan 14, 2007 | GE XL1800 1100 Watts Microwave Oven
GE JVM1860 Microwave Oven Logo
389 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
