No sound from microphone input or line input. says this device is working ok.latest drivers from driver detective. Aspire m3100 with win xp.All controls blanked out.
  • 2 more comments
  • tjohns Nov 28, 2008
    all controls blanked out
    sound works for cd but the controls for lineinput are greyed out, so cant adjust them.
    mike volume control and lineinput volume are all greyed out.When i plug lead into linein it recognizes the input conection but no sound comes from speakers.just downloaded latest drivers from driver detective but no difference
    Have realtek high definition audio driver version 5.10.0.5717 latest update.
    tried to use lp lineinput programe, error says Cant find audio output mixer line for headphones (high definition audio (00471290)
  • 905 Answers
Go to control panel / sounds and audio properties/( can you move the volume button?) if so then click the advanced button there and then on that window click options then properties then select the recording button and make sure that the microphone box is checked and anything else that you want to use for recording then click ok and select the microphone when the window comes up with the volume controls and check boxes for each device that you want to choose from to record( only one device can be selected
hope this is worth a fixya as all other ratings hurt our scoring
electech
Posted on Nov 28, 2008
  • 6 more comments
  • jason Nov 28, 2008
    then you did not install the drivers and that rating is abuse! so i guess you don't really want help
    I will report this as abuse , because you are not giving enough info on what you have done or what your computer says about the drivers or anything but" all blanked out ", and that means there is no driver or no audio device or your device just don't work anymore , so do you want help or not?
    do you have a software program for it like real tek audio , ac97 ? because that is what will let you control the audio jacks on the computer , go to control panel and click system then hardware tab then device manager and look under sound video and game controllers , is there a yellow exclamation mark next to any of the audio? and is there a audio software program listed there also?
    and please change the rating as that is insulting when I am trying to help you get the audio properties correct for the microphone and line in
    also what is the name of the audio device that is in your computer?
    is this the audio software drivers for your acer that you have downloaded?
    Realtek Audio Driver vA3.85
    also driver detective only detects for drivers not the audio software
    also make sure that the boxes in the audio properties playback option has the boxes for the mic and line in check or you will not be able to use it untill they are checked in the box
    you will also have to do this for the recording options
My microphone isnt working
First you must check your microphone is muted in your sound card settings in control panel.if it is ok ? you can re install your sound card driver some time your microphone is not detected by sound card driver.
Sep 09, 2011 | Acer Aspire 2930-4661 Notebook
I am using a logitech headset as well as a creative headset. when i am using it in my home PC the mic in headset is not working. i can hear songs an all from the headset but if i talk in it others cant...
it might be as simple as changing your line in device.
in windows xp go to
Start -> programs -> sounds and audio -> voice
and try and change your recording device to an Logitech device.
Mar 04, 2011 | Computers & Internet
Cannot set up microphone on my acer aspire one d255
You don't specify what type of microphone you are using.
The following instructions apply to a microphone plugged into the normal mic/line in (red) jak-plug socket on most computers.
If you are using a USB microphone the process might be slightly different because the system has to actually recognise the microphone first. Most are plug and play so will automatically be detected after a few seconds but some do need drivers installing from the mic manufacturers disk
To use any microphone with your computer you will need to enable it in control panel. The following instructions are for Windows XP but are broadly similar for Vista and Win7
Click START, CONTROL PANEL, SOUNDS & AUDIO DEVICES
In the Sounds & Audio Devices Properties window locate the SOUND PLAYBACK box and click the VOLUME button. Make sure that there is not a tick (check-mark) in the MUTE box against microphone in the list of devices and that the volume slider is at the top of the scale.
Also make sure that the MUTE ALL box isn't checked before closing the window.
Now click the VOLUME button in the SOUND RECORDING BOX. Here you need to SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls).
NOTE if microphone is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK.
That should be it.
Feb 01, 2011 | Audio Players & Recorders
I've got a new Blue Snowball mike that worked great out of the box, but now, a week later, it just gets a "device not recognized" message when I plug it in. I've tried rebooting, and...
I had the same problem with my PC and went to http://www.asio4all.com/ where I downloaded and installed the driver and it worked!! I found the site by reading this FAQ (see below) at Blue under Snowball.
(But I still have the same problem with my MAC).
"If you should experience any problems getting the program to recognize the mic, Adobe recommends the following: If the device does not allow you to record, then your microphone is not being detected as a valid input device in Premiere Elements. You can use an open source program called ASIO4ALL, which is a device driver that essentially wraps existing WDM devices, like USB microphones, as ASIO-compatible sound devices. Use the following steps to utilize this tool:
  1. Quit Premiere Elements.
  2. Visit the following web page and download the latest available version of ASIO4ALL: http://www.asio4all.com/
  3. Install the software, and restart the system if asked to do so by the installer.
  4. Make certain that your microphone is plugged in.
  5. Launch Premiere Elements. Go to the 'Edit->Preferences..>Audio Hardware' menu option. For the Default Device, choose the ASIO4ALL option. Click the ASIO Settings button, then select your microphone from the list of devices, click Exit, and then click OK on the Preferences dialog. Close and then restart Premiere Elements."
Dec 28, 2010 | Blue Microphones Snowball Professional...
I am unablem to use the mic for the internet chat!!!!
First of all find the latest version of the audio driver which is compatible to vista, as most of the drivers that are shipped with sound-card or motherboard cd contain drivers which have support for only until windows Xp.
So it is strongly recommended to download the latest audio driver from the internet for your sound-card or on board audio chipset. Install the vista compatible audio driver (sound driver) for your sound-card or motherboard audio. After this re-start your computer. Half of the work is done.
Now plug in the microphone in your sound-card / motherboard audio pin (generally pink in color for microphone).
After this go to control panel > sound and audio device settings. Check whether the microphone is detected by Vista or not. If not, check whether you have selected the frontal microphone or rear, as vista recognizes them separately unlike windows Xp. Correct the configuration of front/rear mic if needed.
Nov 16, 2010 | Computers & Internet
Hello why the microphone on my aspire 57322 does not work
1. Check with the manufacturer if your model comes with an inbuilt microphone.
Specifications may vary according to sub model.
Uninstall the present sound drivers by following the steps mentioned below.
  1. Click Start vistastartbutton.jpg, type Device Manager in the Start Search box, and then press ENTER.
  2. In the Device Manager dialog box, expand Sound, video, and game controllers.
  3. Locate the audio device that was included with the computer.
  4. Right-click the device, and then click Properties.
  5. Click the Driver tab, and then click Uninstall.
  6. Make sure that the Delete the Driver Software for this device check box is cleared, and then click OK.
After uninstalling the sound drivers reinstall the latest audio drivers for your operating system from the link given below.
http://gd.panam.acer.com/
Note: Choose the correct model and operating system.
Oct 28, 2010 | Acer Aspire 5500 5570-2609 Laptop
A7V600-X mb, Win XP SP3, microphone not working
Skip my reply above; didn't work. The BSOD is very erratic, so its hard to be sure. Try DLing the latest Realtek HD Audio drivers
May 05, 2010 | ASUS A7V600-X Motherboard
Logitech Webcam Pro 9000 -- disables other audio inputs???
ok try this: - insert the old driver not the beta. - go the driver install it's like "step.exe" - right click on and select proprete - go the compatiblité - select "run under compatibilité : win 95 ...win 2000" - select run under win2000 - ok - begin to install
good luck;)
Feb 01, 2010 | Logitech QuickCam Pro 9000 Web Cam
Sound card Driver problem under Win XP
download new drivers from driver detective..
or click bharatgulati.blogspot.com.
i do hv 1 problem..
"iam getting yellow vertical lines at startup screen..the lines are moving.system hangs after few sec. & sometimes it works perfectly.cant even format the system as it hangs.help"
Jul 22, 2009 | Computers & Internet
No Sound on my Acer Aspire M3100 PC
They have the new drivers on their website. Updating the drivers might fix your issues. Just type "acer aspire M3100+Drivers" into google and it should be your first option.
Jun 19, 2008 | Acer Aspire 3100-1405 Notebook
144 people viewed this question
 Grubhead
Grubhead
