Question about Toshiba Satellite M55-S135 Notebook
Touchpad went crazy
I cannot type anything correctly anymore, the letters keep jumping. I have tried disabling the touchpad but it still goes on working (not properly). What can I do. I have been unable to find a the driver for reinstallation. I have even paid subscription to Driver Detective but I still have the same problem.
  • elzamaria Nov 30, 2008
    I have tried your suggestion, many thanks, but it did not work. I have tried disambling my mosepad and it shows as disabled but it still works! and interferes with the typing. I have even tried a subscription to Drivedetectives to install new drives. Nothing works. Thank you in any case, your suggestion was very quick.
  • Toshiba Master
  • 5,568 Answers
You can try this:
- Open the Control Panel - Open System folder - Choose Hardware  - Choose Device manager - Find and open Mice andother pointing devices
First, I would delete it from the list and reboot, forcing Win to find the 'new device' and install the driver from .cab files that are probably on a separate partition. If it is still causing problems, go through the steps above but as the last step, choose Disable to try to put it to sleep.
Posted on Nov 28, 2008
What to do when cursor keeps jumping
Many laptops have a settings window for the touchpad/mouse (look in the Control Panel); after getting this laptop I had the same problem. I went into the options and checked the box that said something like "Disable Touchpad when Typing." Look for an option like that in your touchpad settings.
Mar 29, 2013 | Computers & Internet
While typing on Acer Aspire the typing jumps around constantly...why?
Most of the time disabling the tapping for the touchpad solves the problem. Go to settings and disable the tapping for the touchpad, not the touchpad itself, just the tapping.
Nov 14, 2017 | Computers & Internet
When typing the cursors jumps to the beginning of the sentance
Most often this is caused by your thumb touching the touchpad. If you use a mouse, disable the touchpad. I've had this problem and so have a number of my customers. One lady insisted that I was not right, so I disabled her touchpad and the problem went away!
To test this to see if your problem is caused by a sensitive touchpad, cover it with cardboard and go about your typing.
Oct 11, 2010 | Gateway Computers & Internet
Jumpy cursor , while typing the cursor jumps to another line and adds the newly typed letters somewhere else on the page
The reason this is happening is that as you are typing; you're resting some weight on the thin plastic above the touchpad...which then makes contact and registers a 'click'; thus moving your cursor around. Or you're brushing your thumb against it when hitting the space key.
Some laptops are more susceptible to this than others. Some more modern laptops come with a button to turn the touchpad off to solve this very problem.
The only thing you can do about this is to disable the touchpad through the touchpad driver (down by the clock, usually) and use a mouse instead. Depending on how you use your laptop, this will be more or less inconvenient- if your laptop never leaves the desk; disable the touchpad and use a problem. If you go mobile a lot, you'll have to enable and disable the touchpad all the time.
The other thing you can do is adapt your typing style so you don't put any weight on anything but the key you're pressing. This is quite difficult and uncomfortable, and is not recommended for long sessions.
Mar 22, 2010 | Acer TravelMate 2303LCi Notebook
My cursor jumps back to the beginning when i'm trying to type. i'm constantly having to backspace and correct and reset my cursor. any suggestions?
Disable your touchpad if you consistently have this problem.
When you are typing something, and you suddenly touch the touchpad (tapping this touchpad moves the cursor) then your cursor will suddenly change position which then mess up your typing.
If you don'r have an external mouse connected, better be careful not to touch the touchpad. If you have an external mouse, better disable this touchpad.
Mar 03, 2010 | Compaq Presario 700 470024-192 Notebook
When typing cursor keeps jumping
Generally there is a setting (CONTROL PANEL, MOUSE, Touchpad Tab) to either enable a feature like PALMCHECK or to disable the touchpad while typing. If neither option is shown, then try updating your touchpad driver
Dec 27, 2009 | ASUS Eee PC 1000H Laptop
Typing problem with keyboard
the easy method would be to hook up a USB mouse and disable the touchpad to see if that works. Control Panel -> Mouse (or Printers and other Hardware), then click on the mouse and then click on Advanced or Hardware tab to look at the options. You might be able to have it disable the touchpad when a mouse is present.
Feb 26, 2009 | Toshiba Satellite M55-S329 Notebook
Laptop lenovo 4152 38q
Your touchpad is very sensitive. Be sure to keep your fingers away from it when typing. I have the same problem with my Toshiba laptop--I decided that unless I was in a travelling situation, I would use a small wireless mouse. I just disabled the touchpad.
Jan 19, 2009 | Lenovo 3000 Y410 Laptop
Jumping cursor when typing
Since you have a logitech mouse, lets just disable the touchpad. You should be able to disable the touchpad via one of these methods:
  1. Look on the top row of keys. You should have one that looks like a little mouse. If you do, hold down the "fn" key in the bottom, and press the key with the mouse on it. That *should* disable the touchpad.
  2. Go to the control panel, and find the keyboard and mouse settings. Digging through the menus, you should find a touchpad. You can disable it through there.
Sep 17, 2008 | Microsoft Windows Vista Ultimate Edition
Toshiba Satellite M55-S135 Notebook Logo
64 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
